Results 1 to 25 of 25
    Very Active Member ArmyJoe's Avatar
    Jul 2009
    Columbus, Ohio
    Default Downshifting to slow down?
    I've carried over the (bad?) habit of downshifting (aka, engine braking) the Sypder to slow down from my days of driving a maunual transmission car. The other day I was taking my wife's Buell Blast for a test ride and absent-mindedly downshifted in a turn. I can't exactly describe what the rear end did, but I know I won't be trying that again.
    Does anyone else downshift?
    2009 Yellow SM5 with BRP R35 saddlebags, CHAD windshield, ESI Up & Out Mirror Extensions, ESI 4" Handlebar Risers, Hindle muffler, Green Filter, Juice Box Pro, Throttlemeister, Crampbuster, Cortech Sport Tailbag, trunk liner, trunk spring, 12V trunk outlet, Eastern Beaver PC8 Fuse Panel, and two dashboard Powerlet outlets.
    Certified Huligan
    The user formerly known as GIJoe
    Registered User groundeffect's Avatar
    Dec 2009
    Newfoundland, Canada
    Jul 2009
    Surry, Maine
    Always, I don't use the brakes until the bike is under 20MPH usually.
    Active Member Burt's Avatar
    Nov 2008
    Griswold IA
    I regularly downshift to reduce speed for cornering and stopping.
    Spyderless Member
    Dec 2008
    north/central n.j.
    Quote Originally Posted by Burt View Post
    Just don't drop it into 1st at 55 mph.
    Very Active Member YPILOT's Avatar
    Aug 2009
    Johnson City,Tennessee
    When your pushing through the twisties you gotta down shift and brake and accelerate and shift and repeat. Oh what fun it is to go go go.
    "Stupid is as Stupid does"
    Don't Drink and Drive or Ryde!
    Each Day is a Gift
    Sep 2008
    Oak Creek, WI
    I just brake. I will manually downshift if I need speed up again and am at a gear to high for the speed I am currently.
    I just use the brakes to get to a complete stop.
    Banged Up Member
    Dec 2009
    Sanford, Florida
    All the time.
    Feb 2009
    Ceresco, Michigan
    Not a bad habit at all... I do it all the time... even use the clutch sometimes.....
    RT-S PE#783
    Mar 2010
    Illinois Valley in Southern Oregon
    Default braking vs down shifting
    Quote Originally Posted by GIJoe View Post
    It is said that brake pads are cheaper than pistons and rings, but shifting, up or down is also a means of control. I down shift to slow my motorcycle or Spyder, but I don't do it in place of braking when braking is necessary. When I go into a turn, I want to be in the gear that is going to take me through the turn. Down shifting in a turn can cause the rear wheel on a motorcycle to break loose or 'hop' like you probably did on the Buell.
    2010 RS , custom home made billet Red/Black
    Very Active Member jnt's Avatar
    May 2008
    Minneapolis
    Quite effective. I got in the habit many years back of blipping the throttle to equalize engine to road speed as releasing the clutch in the lower gear. ALSO - if I am engine braking only, following traffic has no ready knowledge of my speed change. I always at least touch the brake to activate the brake lights.
    08 RS/SM5 (Hers) (sold)
    15 RT-S (Mine)
    2015 RT-S , Metallic Black
    May 2009
    Connecticut
    1-Downshift into tight corners to get a better grip on the turn!
    2-Downshift from 3rd to 2nd because its smoother when I do.
    3.Down shift AND have my foot a half inch over the brake when I,m going through an intersection and theres a least bit of chance someone is going to do the ole"Pull out in front of you routine?"
    Sea Doo GTI-SE 90 Jet Ski!!
    Apr 2009
    New Mexico
    Default SE5
    Downshift? Usually.
    To make coming to a stop smooth - Quadmaniac recommended: Keep the throttle open, just a little. As he said, "smooth as silk".
    Of course, if you are powering through curves, you have the throttle open.
    This works like magic on my SE5, never did it on a SM5.
    Tom
    May 2008
    Clearwater, FL
    Quote Originally Posted by VaughnCat View Post
    It is said that brake pads are cheaper than pistons and rings...
    Add here: front sprocket with screw and main shaft...
    Motorbike Professor
    Mar 2008
    Allegan, MI
    Engine braking is fine. The key to using it is to be smooth. If your RPM is high, backing off the throttle is all that is necessary, then downshifting progressively as the RPM drops. If the rpm is already low enough, go ahead and down shift. Drop to the lower gear too early, and you risk eventual drivetrain damage, and could lock up the rear wheel, as you have already discovered.
    Jun 2008
    Fort Knox, Kentucky
    Default Yep, I downshift
    I downshift a lot when slowing down. I usually glance in my mirrors to see if anyone is following and tap the brake to alert the driver following that I'm slowing down. Hopefully, the brake light flashing will distract the driver behind me from sending the text message they are working on and actually drive for a change.
    Major Finder
    Using engine braking coupled with proper friction breaking is a great idea and a skill that should be practiced.
    It is not generally a good idea to downshift DURING a turn. The sharper the turn the less of a good idea downshifting IN a turn is.
    As you probably found that your 2 wheeler breaks the rear wheel loose much easier than your Spyder, giving you all kinds of E-Ticket Issues!
    Downshifting while in a turn is not so critical on the Spyder but still not a great practice.
    The idea is to downshift/break BEFORE the turn (while still in a straight line) so that you enter the turn; (these are NOT multiple choice!)
    A- At the correct speed
    B- In the correct gear to travel through the turn without shifting
    C- Prepared to accellerate out of the turn without downshifting
    You can break while in a turn but be very careful and ready to deal with any sudden loss of traction no matter how slight. (advise for 2 wheels, Breaking, like downshifting, is not usually a problem with the Spyder).
    May 2008
    Shawangunk, NY
    Wink What is this of which you speak?
    Brakes? These come with brakes?
    Ride on.
    Roadkill
    2008 GS Roadster , Roadster Red
    Feb 2009
    Ceresco, Michigan
    Good advice all around.
    Also a good time to mention... if you are NOT using engine braking when coming to a stop - you should still be downshifting with your clutch pulled in-- stay in the relative gear to your speed until you are back in first gear as you come to your final stop. This is better than waiting until you're at a complete stop and then downshifting all the way.
    Oct 2009
    Martin, SC
    Quote Originally Posted by Roadkill View Post
    Ride on.
    Roadkill
    That is how I usually ryde. I only use the brake just before coming to a complete stop, or an emergency braking situation. I have thought about getting one of those mercury switches that flashes the brake lights when you decelerate to warn other drivers that I am slowing down some.
    Quote Originally Posted by docdoru View Post
    Seeing the recent posts about the failed shafts and sprockets also has me rethinking my ryding style a little now. I don't want to baby my Spyder, but at the same time I don't want to knowing cause major damage to it either. Decisions, decisions.
    Quote Originally Posted by Firefly View Post
    Hopefully, everyone knows this. But for many the Spyder is their first "Motorcycle" so maybe not.
    Jul 2008
    Natchez, Ms
    Quote Originally Posted by Sarge707 View Post
    On the money, Sarge
    Very Active Member sabunim5's Avatar
    Jan 2008
    Pensacola Beach, FL
    and I always downshift into a gear that is appropriate for my road speed at a sensible engine speed (rpm).
    Happy owner of Silver PE #1232
    All The Gear All The Time - ATGATT
    Gulf Coast SpyderRyders
    Feb 2008
    South Jordan, UT (Salt Lake)
    I always downshift... as in the case of your 2 wheeler though, sounds like you weren't very smooth with the clutch and the rear wheel got squirrely on you... it happened to me a few times on my Ninja. Also forgot I didn't have ABS while on the Ninja once and locked up the rear wheel... that's the tricky part about going back and forth between the Spyder and a traditional 2 wheeler.
    2008 GS , ISCI Quantum Blue
    RT-S PE# 536 scudrunner's Avatar
    Mar 2010
    La Marque, Tx
    I learned at a very early age to use engine-speed matching down shifting on a car (heal & toe method) and have carried that over on a motorcycle. On the sports cars I've owned, I've learned the sounds of the engine/gear and could tell you how fast I was going without the speedo. I'm learning that with the Spyder now too. Fortunately, the SE5 does all the speed matching for you when you downshift. My method is to put my foot on the brake to activate the light and downshift on the high side of the gear range to slow down. And always brake before you get into a turn, engine braking while in the first half of the turn, and accellerate through the last half. Generally speaking. Concept is the same for car or motorcycle, method is different.
    Jay on Omega Bay Texas
    Spyder RT-S PE# 536
    http://www.spyderlovers.com/forums/album.php?albumid=715
