Ball-mount QuadLock turning when removing phone - can it be done One handed?
I just switched my ram-ball mount x-grip for a quad lock because I don't like the slop in the x-grip, and I cannot install or remove the phone one handed. And I also like the idea of the vibration dampener in the quad lock.
I've cranked the ball mount down pretty darned hard, yet the whole quad lock wants to turn when I try to twist the phone to remove it. Also, it seems quite the trick to get the phone aligned with the quad's slots without looking at the back of the phone.
What are your experiences? Does it get easier as the mount "loosens"? Can you attach/detach your phone one hand? Can you get the ball grip tight enough to not turn with the phone?
Reason: Expanded title to briefly ask the question... ;-)
2019 Spyder RT Ltd. Bought in Jan 2024. Can-Am states only.
Slingmods USB and QuadLock phone mount with vibration dampener
Highway pegs
Rear GENERAL ALTIMAX RT45 SL 225/60R-15 tire
Drink2Go front/rear Cupholders
3D printed Turn Signal/Shifter caps
KOTT Grill covers
LED Headlights + LED Foglights
High Mount Trunk brake/turn lights with brake strobe
Pedal Box+ w/BT
Show Chrome gas shock for rear trunk
Foam Grips
Red Rim Covers
VIOFO MT1 Front/Rear Dash Cam system
Upper Radiator Exhaust Block (SpyderPops)
ShowChrome Heavy Duty seat shock
SpyderLovers Sponsor
![Quote](images/misc/quote_icon.png) Originally Posted by Allen42
Try this next time:
All Aluminum, machined, and using stainless steel springs for gripping.
Only need one hand...
Call for yours today 209-608-2141 or 209-887-3283
For what it's worth, I have the X-Mount and if I squeeze it together (i.e., wide open I guess) once before putting the phone in, it is locked and doesn't have any slop at all. I don't know if it's a design feature or what.
2022 Spyder RT Ltd Petrol Metallic
________________________________
![](https://www.spyderlovers.com/forums/maps/map.prov.png?states=ON)
![Quote](images/misc/quote_icon.png) Originally Posted by Two2Three
Mine gets slop if it expands enough to hold the iPhone Pro Max. By slop, I mean I can turn it 10-15 degrees either direction. It doesn't do it when "collapsed".
Highway pegs
KOTT Grill covers
Pedal Box+ w/BT
Foam Grips
Red Rim Covers
Update: After spending a day or two on the bike this weekend, the QuadLock is working great, even one handed. Just took some learning and doing.
I took a closer look... it's the way the X works.... if it's fully open or fully closed, it's locked against the edge of the slot the arms expand in. If it's anywhere in between, the phone can rotate. Odd design, in my opinion.
Reason: Merged immediately consecutive posts... no need to double up!
Highway pegs
KOTT Grill covers
Pedal Box+ w/BT
Foam Grips
Red Rim Covers
More reason phone stays in pocket. Bluetooth to headset for comm & tunes. Oem Garmin GPS on bars for visual (can have audio Bluetooth or stereo, visual assist good enough) Have had run multiple GPS for incorrect addresses/coordinates in which case phone <Google Earth >was audio & Garmin the visual keeping on pavement. Odd but worked
![Quote](images/misc/quote_icon.png) Originally Posted by Motorcycledave
Try this next time:
Dave, What RAM arm is that?
2022 RT Sea To Sky
