Results 1 to 7 of 7
    Jan 2024
    Texas
    Default Ball-mount QuadLock turning when removing phone - can it be done One handed?
    I just switched my ram-ball mount x-grip for a quad lock because I don't like the slop in the x-grip, and I cannot install or remove the phone one handed. And I also like the idea of the vibration dampener in the quad lock.
    I've cranked the ball mount down pretty darned hard, yet the whole quad lock wants to turn when I try to twist the phone to remove it. Also, it seems quite the trick to get the phone aligned with the quad's slots without looking at the back of the phone.
    What are your experiences? Does it get easier as the mount "loosens"? Can you attach/detach your phone one hand? Can you get the ball grip tight enough to not turn with the phone?
    Last edited by Peter Aawen; 04-30-2024 at 04:13 PM. Reason: Expanded title to briefly ask the question... ;-)
    2019 Spyder RT Ltd. Bought in Jan 2024. Can-Am states only.
    Slingmods USB and QuadLock phone mount with vibration dampener
    Highway pegs
    Rear GENERAL ALTIMAX RT45 SL 225/60R-15 tire
    Drink2Go front/rear Cupholders
    3D printed Turn Signal/Shifter caps
    KOTT Grill covers
    LED Headlights + LED Foglights
    High Mount Trunk brake/turn lights with brake strobe
    Pedal Box+ w/BT
    Show Chrome gas shock for rear trunk
    Foam Grips
    Red Rim Covers
    VIOFO MT1 Front/Rear Dash Cam system
    Upper Radiator Exhaust Block (SpyderPops)
    ShowChrome Heavy Duty seat shock
    Linden, CA
    Quote Originally Posted by Allen42 View Post
    Try this next time:
    All Aluminum, machined, and using stainless steel springs for gripping.
    Only need one hand...
    Call for yours today 209-608-2141 or 209-887-3283
    Active Member Two2Three's Avatar
    Mar 2023
    Missouri
    For what it's worth, I have the X-Mount and if I squeeze it together (i.e., wide open I guess) once before putting the phone in, it is locked and doesn't have any slop at all. I don't know if it's a design feature or what.
    2022 Spyder RT Ltd Petrol Metallic
    ________________________________
    Jan 2024
    Texas
    Quote Originally Posted by Two2Three View Post
    Mine gets slop if it expands enough to hold the iPhone Pro Max. By slop, I mean I can turn it 10-15 degrees either direction. It doesn't do it when "collapsed".
    Highway pegs
    KOTT Grill covers
    Pedal Box+ w/BT
    Foam Grips
    Red Rim Covers
    Jan 2024
    Texas
    Update: After spending a day or two on the bike this weekend, the QuadLock is working great, even one handed. Just took some learning and doing.
    I took a closer look... it's the way the X works.... if it's fully open or fully closed, it's locked against the edge of the slot the arms expand in. If it's anywhere in between, the phone can rotate. Odd design, in my opinion.
    Last edited by Peter Aawen; 05-06-2024 at 06:04 PM. Reason: Merged immediately consecutive posts... no need to double up!
    Highway pegs
    KOTT Grill covers
    Pedal Box+ w/BT
    Foam Grips
    Red Rim Covers
    Bossier LoUiSiAna
    More reason phone stays in pocket. Bluetooth to headset for comm & tunes. Oem Garmin GPS on bars for visual (can have audio Bluetooth or stereo, visual assist good enough) Have had run multiple GPS for incorrect addresses/coordinates in which case phone <Google Earth >was audio & Garmin the visual keeping on pavement. Odd but worked
    Aug 2019
    Stoughton, WI
    Try this next time:
    Dave, What RAM arm is that?
    2022 RT Sea To Sky
