Results 1 to 12 of 12
    Apr 2024
    Northwest Ohio
    Default Where are my Trunk & Frunk power supplies? What is needed to add them?
    I have seen some RT's with power supplies in the trunk and forward storage compartment. My 2023 does not have any, and I wish to add some.
    Do Lamonster or Slingmods have what is needed to add 12 volt access?
    Last edited by Peter Aawen; 04-27-2024 at 06:51 PM. Reason: Expanded title to briefly ask the question/s... ;-)
    Nov 2015
    Chardon, OH
    You have it, you just need to find it. The 2023 has two places you can grab 12v power. One is on the right hand side where BRP got power for the factory installed GPS. Lamonster has a power cable that you can use to plug into that and I believe there is a video. Called Plug and Play I think. Lamonster’s cable is nice because the connector goes right into the factory connector holder. And Yes, the polarity issue got fixed.
    The second is on the left side of the battery, in the battery compartment, behind the front storage compartment wall. Removal of the battery makes it easier. It’s designed to power up a standard auto type accessory plug that goes into that hole with the rubber plug in it. But, you can tap into those and add whatever you like.
    In the top case is a USB outlet.
    Pic 1 is the GPS power wire with the Lamonster cable, pic 2 is the front accessory connectors.
    Doug
    ”Freedom is not a loophole”
    Jun 2020
    iowa
    Do you mean you want to add a 12-volt supply? Such as to make your stock battery larger? Or are you wanting to put in a 115-volt inverter? Either way, you should be able to plug one in, in the trunk - if you have a 12-volt lighter socket in there like mine does. I have not seen anything in the frunk to allow this.
    Apr 2024
    Northwest Ohio
    If I understand correctly, the top case as you call it, is that the small box in front of the handlebars? I have read that does NOT charge a phone.
    As for the GPS power that is also something I want to do... just didn't see the power cable on the web page.
    I really want to add the ability to charge my phone somewhere... Trunk or Frunk, it doesn't matter but there is nothing in my trunk just a plug where there is a hole for something like a cigarette lighter plug.
    Apr 2024
    Northwest Ohio
    Quote Originally Posted by pedalyurassoff View Post
    Yes, for a GPS and another for phone charger.
    Nov 2015
    Chardon, OH
    Hey NoTyme. Sorry about the terminology confusion. When I say top case, it was referring to that big, storage case that sits on the top rear, behind the passenger. As shown in my signature photo. What you are probably calling the trunk.
    So, let’s start over. Opening your top case (trunk) lid, look all the way to the front and up under the top lip area. Right above the storage area for the case removal tool. (Bend down and look up) You should have a little protruding plastic area. On the right is a light and on the left is a rubber dust cover. Yes, this whole thing faces downwards, oddly. Lift the dust cover and there’s your USB charging ports. Turn on the key, and the light comes on and the ports turn on. To my knowledge, this was standard equipment in every top case. For charging only. No data. You don’t have this? You do have the BRP OEM case, right? You’re under warranty. See pics.
    Up front, the most convenient place to grab 12v switched power is on the right side accessory harness. Here is a video from Rick on how to access it and remove that last panel. I prefer Lamonster’s harness over his, though, because it’s a little neater and that female connector clips into the fixture that I showed you up above.
    https://www.youtube.com/watch?v=99AJzb10Kas
    https://www.lamonstergarage.com/gps-...-am-spyder-rt/
    Doug
    Active Member WRCLVR's Avatar
    Nov 2022
    Georgia USA
    So just to summarize the USB ports on the 2020+ - the rear trunk and the front frunk ports provide power charging only. The glove box unit USB port provides connectivity as well as some charging. According to the 2023 S2S manual (Oh yes, I know they are all the same crappy manuals. lol) if using the BRP Connect app (no comments here) you must pair the phone via Bluetooth AND with the USB port in the glove box...
    Pretty sure that when the 2024 ACP finally gets fixed, it will require the BT/USB port glove box usage as well as the helmet pairing!
    2024 RT Sea to Sky screen now working but codes will remain until BRP releases the ACP update.
    Apr 2024
    Northwest Ohio
    Thumbs up
    Thank you, I would have never looked up in the trunk for this. Nice having a USB charger for the phone. Use the XM app, and plug in the phone to the USB charger and tunes that will never end... at least till I stop.
    I will look again at LaMonster for the cable.
    Active Member PJveetwin's Avatar
    Oct 2022
    Peoples Republic of Calif. Upper Mojave Desert
    I installed a fuse panel under the left panel to power my GPS, 2 electric vest and a SAE plug for my battery charger. The GPS plug is tied off on the bars, with the other 3 stay under the seat till needed. I can still access the air filter and quick access to the fuse's if needed. My phone uses the USB port in the small glove box. All has been working fine for 20K miles
    2021 RT LT
    Faribault, MN
    Helped a buddy use Lamonster's cable to add a Garmin GPS and his heated gear connection on his '23 RTL. +1 for using that.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Apr 2024
    Northwest Ohio
    I ended up purchasing a 10' USB cable with a mini plug end, ran it from the trunk up to the small box in front of the handlebars. My ball mount won't fit so I will have to by one to fit the RT's bars, but I saved myself a few bucks doing this.
    Feb 2024
    Tennesse
    I have a Garmin Zumo XT mounted to the handle bars of my 2024 Spyder RT Sea-to-Sky using an Arkon MC25MMB handlebar mount.
    I power it through the USB cable in the "glove box" in front of the handle bars.
    I have the GPS paired via bluetooth with my iPhone and the Sena 3S Plus bluetooth headset installed in my helmet.
    I put the iPhone in the top case and plug it into the USB port there for power.
    The Arkon mount is the ring around the handlebars and the ball on top of it.
    racoon
    Middle Tennessee
    2024 CAN-AM Spyder RT Sea-to-Sky - Vegas White Satin
    2023 Honda Ridgeline Sport - Sonic Grey Pearl (aka Baby Blue)
    2024 RT Sea-to-Sky , Vegas White Satin
