RT Oil Change video suggests using a different sized Torx!? - was it wrong?
I was watching a video on changing oil on a '21 RT. The rider said to use a 45 Torx on the left side and a 40 Torx on the right side. I am currently on my third Spyder and the right-side plug has always been a 6-point Allen key. Was this guy mistaken?
Reason: Expanded title to briefly ask the question... ;-)
2020 F3 Ltd
Spyderpops Bumpskid Spyderpops Brake/Run/Turn Signal LED's
Lamonster Garage LED Fog Lights and Headlights 2013 ST-S retired 1/9/16 at 25,061 miles
Yes, he was mistaken. And that's how drain plugs get stripped out. Clearly a Torx - T45 - and clearly an Allen - 6mm. Otherwise referred to as a hex bit.
Yes he is wrong. It may work for him, but sooner or later he is going to have to deal with a stripped-out Allen head (hex key) plug.
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
One of the supporters of this forum sells hex head magnetic oil plugs at a very reasonable price; I recommend a set.
2020 Spyder RT Limited; Deep Marsala/Chrome
Formosa AZ01 165/50/R16's on PPA Recluse wheels up front
General Altimax RT43 215/60/R15 on factory rear Primary exhaust: RLS Cat delete w/ his baffle; secondary, custom built w/ Flowmaster HS2
Suspension: BajaRon swaybar (highly recommended!), M2 coil-overs, front & rear (also highly recomended!)
Extra LED lighting and misc. to suit my needs/wants
Of the three Spyders I have owned I have immediately changed out the OEM plugs to hex head plugs from goldplug.com. Worth the money and headache.
2020 F3 Ltd
If it was a YouTube video see if you can find it. Add a comment letting viewers know they need to use an Allen wrench.
