Results 1 to 5 of 5
    Aug 2019
    Stoughton, WI
    Default Helibars V2 for Spyder F3 models ONLY. NOT RT's
    FS: Helibars for Spyder F3 models only! NOT RT's. These are the newer versions that are 1.5" taller than originalHelibars. More adjustment for fore/aft/height. These are the ULTIMATE spyder handlebars. Of course they won't fit my RTL and no one wanted to trade 🙁 . As you can see, I paid $614/shipped. These bars are mint/like new! I will sell shipped for $450 PP no fees or $465 PP goods. Treat yourself. You'll love them. Will ship in OEM box with all literature and hardware. Mostly assembled. *2022 UPDATE TO OUR HeliBars® Horizon™ HSTX handlebars for 2015-2022 Can Am F3. We've made our adjustable HeliBar for the F3 Spyder (38mm) 1.5" taller for an even greater range of adjustment.
    This bar IS NOT COMPATIBLE with any of the RT models.
    Install video---> CLICK HERE
    30 degree forward and back wrist angle adjustment, fully adjustable reach, height and wrist angle
    1.5" to 5" taller than stock, dependent on adjustment
    1" to 4.5" rearward towards the rider, dependent on adjustment
    Works within the limits of cables, wire looms and hydraulic lines
    Ideal for short riders and beneficial for tall. The update allows shorter riders to find a more comfortable position while still allowing taller riders to dial in their comfort zone as well.
    Simple installation for a competent mechanic, simply swap out the lower bent mounting tube, leave the controls attached to the stock handlebar tubes and just re-attach them to the new mounting pivot
    100% compliant with all factory components
    ***Part numbers are NOT interchangeable by bike model. (HSTX08142 will NOT work with the RT version)***
    2022 RT Sea To Sky
    Mar 2013
    Maumelle, AR
    Why won't they fit on the 2020+ RTs?
    2020 RT Limited , Chalk
    Aug 2019
    Stoughton, WI
    Quote Originally Posted by Copperman View Post
    Not enough cable length.
    2022 RT Sea To Sky
    Active Member BigPoppa's Avatar
    Jun 2023
    CA
    PM sent
    Aug 2019
    Stoughton, WI
    PM returned. Sale pending.
    2022 RT Sea To Sky
