Results 1 to 18 of 18
    Active Member ff73148's Avatar
    Jun 2018
    New Jersey
    Default Anyone mounted Denali Lights to a 2020+ RT?
    Has anyone mounted Denali lights on a 2020+ RT Limited?
    Last edited by Peter Aawen; 07-16-2023 at 07:53 PM. Reason: Expanded title to briefly ask the question... ;-)
    Frank Ferrante
    2022 Can Am Spyder RT Limited Deep Marsala Metallic Dark
    2016 Moto Guzzi Eldorado
    Aug 2013
    SF Bay Area
    I mounted their Spotlights to the A arms and powered them with a Neutrino Black box fuse block.
    I got another light rocker switch and used it to control them.
    This is my F3 and they’re mounted the same.
    Last edited by Peter Aawen; 07-17-2023 at 03:21 AM. Reason: Fixed attach display ;-)
    2021 F3 Ltd , Magna Red
    Sep 2020
    Middletown, NJ
    I fashioned 'Y' shaped brackets and mounted (sandwiched) them under the front plastics. Flip the template over for left side.
    Last edited by Peter Aawen; 07-19-2023 at 05:16 PM. Reason: Fixed attach display ;-)
    2020 RT base , Chalk White
    Jun 2018
    New Jersey
    How did you hook up the power for the lights?
    Frank Ferrante
    Sep 2020
    Middletown, NJ
    Quote Originally Posted by ff73148 View Post
    I took power from my fuse box (switched 12v) and added a switch in the spare switch slot on the 'tank'. My chin light is on the same circuit.
    Harrington, Australia
    Quote Originally Posted by RayBJ View Post
    Ray, are they Denali? They look great. Which model are they?
    Pere
    Last edited by Peter Aawen; 07-19-2023 at 05:17 PM. Reason: Fixed quote display ;-)
    HeliBars Handlebars
    Kenda Kanine rear.
    Sep 2020
    Middletown, NJ
    They are 9 year-old Denalis. They have been on my last 4 rides.
    Jun 2018
    New Jersey
    I don't want to add a switch. Were did you attach the trigger wire?
    Frank Ferrante
    Just make sure that is legal, ff. Out here in Aus, they will only allow additional driving/spot lights to run off your high beam circuit, and they MUST have a switch, or they will reject the vehicle during roadworthy tests.
    HeliBars Handlebars
    Kenda Kanine rear.
    Jun 2018
    New Jersey
    No problem here in the USA. You have to see some of the light bars that people mount on their trucks.
    Frank Ferrante
    Aug 2019
    Stoughton, WI
    I do have the front guard lights switched
    2022 RT Sea To Sky
    Aug 2013
    SF Bay Area
    The Neutrino Black box has a circuit that allows one accessory to shut on/off another. So I have a wire from when the fog lights connected to this circuit and when it’s hot the power to the Denalis gets turned off.
    In the U.S. we’re only allowed 4 headlights on at one time. (Although law enforcement is questionable)
    Sep 2020
    Middletown, NJ
    No 'trigger wire'. I use a fuse box with 6 12v circuits that can be set for 'key-on' or 'always on'. I connected my switch to a 'key-on' circuit. LEDs can be run as daylight DRLs and/or nighttime added vision.
    Jun 2018
    New Jersey
    RayBJ, I have the Lamonster GPS Plug N Play harness on my 2022 RT Limited. It's a splitter that gives me three positive & negative circuits to run lights and a GPS. It plugs into the factory harness. When I spoke with Denali they told me that in order to make the lights work the trigger wire needs 12V?
    Frank Ferrante
    Dec 2020
    Hartwell, Ga
    What is the purpose of the trigger wire?
    If you only want 12 volts when the switch is on, then use the GPS wire.
    Last edited by Peter Aawen; 07-25-2023 at 05:07 AM. Reason: ... a 12 volts ... ;-)
    Sep 2020
    Middletown, NJ
    The 'trigger wire' they refer to is whatever tells the lights to turn on (deliver 12v). That would be the case if you use a relay to isolate the power to the lights from the CanAm harness (direct to battery with a 'trigger' from the switch you use.) If you run a wire from Lamont's box direct to a switch and on to the lights, you don't use a 'trigger' because the switch is the trigger and power.
    Very Active Member campermac's Avatar
    May 2015
    Etters PA
    you could save yourself a lot of time and aggravation and install the LED light bar from Slingmods or who ever else may have it at a better price. https://www.slingmods.com/canam-spyd...-light-bar-kit
    I installed it in less than an hour and put the switch that comes with it in the blank spot on the control panel where the other switches are located. The switch they provide is an exact equal to the switches from Can Am but the color is not the same, so I went to OTTRAW and contacted them for an exact match replacement. https://www.otrattw.net/
    OH and the light bar is seriously bright.
    2022 RT Limited , Silver w/ Black and Purple accents
    Jul 2023
    S.E. Pennsylvania
    I have Denali lights on my Honda NC750X and the trigger wire there is used to coordinate turning the driving lights on with the high beam switch and off when the low beams are used. The trigger circuit is looking for voltage change. Unfortunately, the Denali circuit I have works well with pre-LED lights, but with the LEDs the voltage change is not enough to trigger the circuit, so I use a switch. Using a separate relay block is the work around.
