Results 1 to 15 of 15
    Very Active Member campermac's Avatar
    May 2015
    Etters PA
    Default 2020+ Arm Rest observation - there's a flat spot for a Ram Ball mount!
    Not sure if anyone else that has the newest version of the OEM RT Arm Rests, but on the underside of each arm rest in the front there is a flat spot that is clearly set up to mount a Ram Ball Square Base to the arm rest to add any kind of Ram Mounted option you want. I mounted bases to both of my arm rests this past weekend and am waiting to find out what the wife wants mounted to them.
    Last edited by Peter Aawen; 05-22-2023 at 06:34 PM. Reason: Expanded title to briefly state the reason for this thread! ;-)
    2022 RT Limited , Silver w/ Black and Purple accents
    Apr 2023
    TX
    This? It hasn't always been there? Do you know what thread/screw size?
    Durham,Maine
    Break out the tap and die set and check it out.
    2012 RTL , Pearl
    Apr 2012
    Florida
    Quote Originally Posted by campermac View Post
    Can you post a pic of what you have done? Tom
    2020 Petrol Blue Metallic RTL
    Apr 2023
    TX
    The holes aren't threaded - it's a composite material underneath the rubbery cover. So use some 3/4-1" coarse thread stainless screws that fit through the ram mount holes...I just pulled some from the loose screw jar so not sure on exact size.
    Last edited by Peter Aawen; 05-24-2023 at 03:31 PM. Reason: Fixed attach display ;-)
    Apr 2012
    Florida
    Thanks for the pics javajaws. Tom
    Dec 2020
    Hartwell, Ga
    Quote Originally Posted by javajaws View Post
    I'm pretty sure that you mean 1/4" x 1" bolts/screws. 3/4" is a bit overkill.
    Apr 2023
    TX
    3/4" to 1" LONG - not 1/4 x 1". 1/4" thick screw would be too large I think. These would be closer to something like #6-8 maybe?
    Active Member Davgill2002's Avatar
    Apr 2017
    Brant Lake, SD (our Golden Pond)
    Thanks for sharing, that is so cool to know. I will likely add both a phone mount and a drink mount. Does either materially obstruct your rear view mirror vision? I would recommend adding Ram Mount's security feature so someone cannot just unscrew and steal $50+ of accessory hardware. It replaces the thumb lever with a wheel lug nut style nut that requires a special tool to loosen or tighten. I keep that tool secured in one of my trunks.
    Apr 2023
    TX
    I haven't noticed anything with mirror interference - but I just installed them yesterday. Thanks for the tip about the security option for the arms.
    Dec 2020
    Hartwell, Ga
    When purchasing screws/ bolts it is normally listed by size 1st followed by thread pitch then the length. As you had already stated that they were course threaded then I just assumed that this was what you meant. I agree that it is probably a #6, 8 or 10 screw also.
    May 2015
    Etters PA
    I could not determine if there was a threaded insert in the arm rests so I used some coarse thread tap screws I had left over from a previous installation that I do not remember where they came from. They threaded right in and tightened down with no issue. I mounted the wife's cup holder on one side and a tacform phone mount on the other side.
    Apr 2017
    Who sells that drink holder?
    Apr 2023
    TX
    That's from RAM
    May 2016
    Shoreline, WA
    RAM Mounts RAP-B-417BU Level Cup XL 32oz Drink Holder with Ball with B Size 1" Ball
