Results 1 to 10 of 10
    Active Member budvoss's Avatar
    Dec 2010
    S.C.
    Default Anyone with DESS removed/disabled on a 2022 RT?
    Has anyone had the DESS disabled on a 22 rt?
    2022 RT Limited
    Mar 2015
    Indianapolis, IN
    Will be interested to see if anyone chimes in and says yes. I've not heard of anyone removing DESS on one that new. For what it's worth - you don't actually remove the DESS, you go into BUDS with a Megatech License and disable it.
    Joshua
    2016 Spyder F3S
    2019 Spyder RT Limited
    2022 Ryker Rally
    2016 F3S , Triple Black
    Clinton, MS
    Quote Originally Posted by Jdr00ejr View Post
    2019 RTL Phoenix Orange
    Dec 2010
    S.C.
    I'm sorry, I meant disable it..
    2022 RT Limited
    Mar 2015
    Indianapolis, IN
    Quote Originally Posted by budvoss View Post
    I'm sorry, I meant disable it...
    Are you having issues with it? Just curious why you are wanting to disable it.
    Last edited by Peter Aawen; 03-21-2023 at 05:05 PM. Reason: Fixed quote display ;-)
    Joshua
    2016 Spyder F3S
    2022 Ryker Rally
    Dec 2010
    S.C.
    Not yet. I'm just thinking of taking out one more kink in the system. I see a few folks on some forums that have had problems with it when trying to get a new key. Heck, I don't want to be out and for some reason find the key does not work because of some silly code that leaves me stranded, or I lose the key. I'd rather add another after-market security system!
    2022 RT Limited
    Active Member Scotts8826's Avatar
    Jun 2014
    Kansas
    Before I went on a long trip last year on my 2020 RTL I needed a new rear tire. I went down to LaMonsters for the tire and while I was there I went ahead and had the DESS disabled. I was going into some remote areas on my trip and while I had no prior issues with it, I decided it would be one less thing to worry about. It was relatively cheap if my memory serves me at about $65.
    Dec 2010
    S.C.
    Quote Originally Posted by Scotts8826 View Post
    That is why i want mine disabled. I plan on mine to be done in April..
    2022 RT Limited
    Feb 2016
    Haven't disabled mine but this is a screenshot from BUDS2 keys page...
    2020 RT Limited , Marsala Red
    Vermont
    Hi budvoss,
    If you do get the DESS error, post it on the long DESS thread that I started.
    https://www.spyderlovers.com/forums/...highlight=DESS
    Deanna
    Current Spyder - 2023 F3 LTD Special - Mineral Blue
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Front Fairing Service Access Door Covers (Carbon Fiber Domed Black)
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    A-arm Daytime Dual Color LED Running Lights with Blinker Module
    Marinco 12 Volt Power Receptacle with polarized leads & slide lock
    Show Chrome Trunk Shock
    LED'S - Run/Turn/Brake Rear
    Former Spyder - 2014 RTS SE6 Cognac - SOLD
    First Spyder - 2012 RTS-SE5 Quantum Metallic Blue - TRADED UP
