Page 2 of 2 FirstFirst 12
Results 26 to 43 of 43
  1. #26
    Aug 2019
    Stoughton, WI
    Quote Originally Posted by Cobwebs View Post
    Just guessing here but the Powervision doesn't give you the ability to bypass the mode button fiasco ???
    Not that I'm aware of. Mine doesn't.
    2022 RT Sea To Sky
  2. #27
    Harrington, Australia
    You must have lucked on the ''bank robbers model'' Pete. Mine I get hate mail for holding up the queue at the discount fuel station. 6 attempts isn't uncommon, I'm going to spend the money just to get rid of the son of a b.........!
    So you have to hit the mode button quite a few times before the safety message disappears, Cobwebs? Now THAT’S a bugger. I now understand your frustration
    HeliBars Handlebars
    Kenda Kanine rear.
  3. #28
    Northern Kalifornia
    I've never had mine apart, so I don't know what the connection is or how it functions behind the mode button. Have you tried holding it down and hitting start? Maybe someone else here has had that button housing apart. Before I went to the sledge hammer fix-it method I'd give a tiny shot with WD40. I'm sure you've done everything except turn the Spyder upside down and press the mode button to make it work. Could it be connected to your brake light system and that's causing the problem?
  4. #29
    Mar 2015
    Tacoma WA.
    Pretty close, but I believe you do the flash yourself, at home, using the MyGenius, which comes with the new tune loaded, Terry. Only you can make the call as to whether you believe it is of value to you. For me, it was worth every penny.
    Thanks Pete, but I was just reading what they had to say on their email reply to me, regarding how to get the flash and also the MyGenius. So I am guessing that you have to pay for the flash file plus the MyGenius. It looks like a $900 hit total.
    2017 F3-S Daytona , Yellow and black
  5. #30
    Feb 2022
    New Zealand
    Himm. Interesting reading. I have been looking at Lamonster's PedalBox. $289 us.
  6. #31
    Sep 2018
    Australia
    I'll pull it apart and see what makes it tick. I do like the extra advantages the Powervision offers, pricewise about $750 here v Monster tune stage 2 $700. New l/h switch block about $700 yikes!
  7. #32
    Dec 2022
    Florida
    Power vision is only $450 if you buy from fuel moto,will include the tune, just call them
  8. #33
    Aug 2019
    Stoughton, WI
    Quote Originally Posted by Isopedella View Post
    Pedal Box ( and pedal Commander) only quicken throttle response. Neither units have anything to do with ECU tuning. That said, maybe that is all you'd want? I use a pedal Commander along with my PV mapping.
    2022 RT Sea To Sky
  9. #34
    Feb 2022
    New Zealand
    Well, I am a little under impressed with having a 3-cylinder 1330cc that needs to be 1/2 way up through the rev range before it wakes up and actually delivers some power. Reminds me of the two strokes back in the day - Blu blu blu with almost nothing, to waaaa wwaaaa and it's all on in the upper 1/2 of the rev range.
    So if it cures that, well yes, that's what I am after. For me, the engine has enough oomph, but 1/2 the time its unavailable. Shouldn't have to go down 2 gears to wake it up. Make sense?
    I guess the answer is if it cures that, then yes, I think so. The Spyder is fast enough for me and my riding over-all, but I don't want to have to wring its neck to access some low rev power.
  10. #35
    NorCal - Northbay
    Hmm, so are you saying it's a built in feature of the Dynojet to shortcut the message (I didn't see that stated on their website) or are you and Peteoz recruiting for your next heist?
    I have the Stage 2 from Monster/WickIt and I can start the bike WITHOUT pressing the mode and drive off!! BUT, I still have the stoopid message scrolling, so at some point I do have to press the Mode button if I wanna see anything else on the dash. But at least I have made a clean get-a-away....
    Chuck
  11. #36
    Quote Originally Posted by TerryTheSpyderRyder View Post
    Yes….$700usd for stage 1 and the Genius. $900usd for stage 2 and the Genius. However, as Auspost have lost 2 shipments of mine recently (one sent and one received - NOT ), I am less than willing to ship my ECM through them any more
    PETE
    HeliBars Handlebars
    Kenda Kanine rear.
  12. #37
    Sep 2018
    Australia
    Quote Originally Posted by hypurone View Post
    Ah right, didn't know it was like that.
    Officer: How fast did you think you were going?
    Me: A bit under safety card.
    Think I might contact the dudes that sell the Powervision units, they claim custom tunes but whether that extends to me having a pile of unexplained wealth or not might the clincher.
  13. #38
    HeliBars Handlebars
    Kenda Kanine rear.
  14. #39
    NorCal - Northbay
    Now that's funny!!
    Chuck
  15. #40
    Mar 2021
    Arizona high country
    my stock 2018 F3L - i turn the key hit the mode button then starter all within a couple of seconds. No message or anything. Spyder is ready to go. So I don't see the mode button as causing me much inconvenience.
  16. #41
    Active Member thereverend's Avatar
    West Monroe, LA
    I had the reflash with stage 2 from wick-it and also own a buds system, no problems found in the bud's system.
  17. #42
    Sep 2018
    Australia
    Quick update for anyone wondering. Dynojet replied to tell me they can't delete the bank robbery button function with their unit and they've done no testing around Silicon Valley lately.hidesbehindsofa.gif
  18. #43
    Mar 2015
    Tacoma WA.
    Come to think of it , on my trike (F3-S) I just have to hold the brake, press the mode switch and it's ready to start. No waiting for any messages.
Tags for this Thread
