Results 1 to 12 of 12
    Very Active Member SLICE's Avatar
    Aug 2022
    manatee county Florida
    Default Radiator Grill Guards install - any easier if shark fins removed first??
    I'm just wondering if it would be easier to remove the shark fins (tupperware) to make the install easier, it only takes 5 minutes a side to remove them versus who knows how long trying to work around them??
    Last edited by Peter Aawen; 12-28-2022 at 08:23 PM. Reason: Expanded Title to briefly ask the question ;-)
    Clinton, MS
    They don't pose the problem that you think they would. Besides, you need them in place to help line everything up.
    2019 RTL Phoenix Orange
    Harrington, Australia
    EdMat got it in one, Slice. You need them in place for alignment. It’s a bit tricky, but not too hard. I must admit that I did cuss a little
    HeliBars Handlebars
    Kenda Kanine rear.
    Aug 2022
    thanks guys.
    Active Member USAF's Avatar
    Aug 2022
    NY
    Quote Originally Posted by SLICE View Post
    What ones did you get ?
    2022 Spyder RTL
    Aug 2022
    Quote Originally Posted by Rick28 View Post
    spyder pops, because free shipping and no added graphics or paint to add cost
    Aug 2022
    NY
    Thats the ones im going with also, Going to order them soon.
    2022 Spyder RTL
    Feb 2020
    Minnesota,USA
    The radiator grill protectors were my 1st mod and most necessary improvement to the 2020+ RT's in my opinion. These bug eating Spyders consume a very large amount of insects and wind blown vegetation.
    If in Doubt, Don't Do It!
    Jun 2021
    Bossier City, LA
    Consider purchasing a 90-degree attachment for your drill. It makes driving the screws in that hold the screens a hell of a lot easier. The one I have linked is just an example, they're available for a bit cheaper.
    --Exco
    2021 RT-L only has a few cosmetic mods
    Active Member Jesster72's Avatar
    Oct 2021
    IL
    I did the Can Am Accessories grills, just because of the color availability. But I did look at the installation instructions for SpyderPops. Looks almost identical. I will say, when you go to fit the grill don't forget the Windex lube on the rubber. That makes it so much easier.
    That, and no matter how many accessories I have mounted on any of my bikes, I have to get over drilling into the bike every time. EVERY TIME.
    2022 Sea to Sky
    Quote Originally Posted by Excoastie View Post
    --Exco
    Yes, very wise advice, Exco
    HeliBars Handlebars
    Kenda Kanine rear.
    Oct 2021
    Wichita, KS
    Be sure to spray some Windex on them. They will slide over the fins much easier. I did not do that on one side and cut my hand pretty bad. Just use some kind of lube on the rubber surround.
    Peter Pan has struck again!
