Results 1 to 25 of 43
    PA
    Default What 36mm wrench to remove rear tire?
    My local dealer has raised his prices to $125 to remove, install and assemble the rear tire on the bike. I know most dealers will not even install car tires but mine does as long as I supply the tire. It was $55 plus tire disposal 2 years ago. For $125, I might as well try removing it myself. They will mount the tire for $30 if not on bike. That is my plan. Remove it myself, have them mount the tire and I re-assemble. This will also allow me to check the front sprocket. I have no problems understanding how to remove it after watching a couple videos. My question is……. I have a good set of snapon axle nut sockets and both flex and standard 1/2” long drive ratchets. So the 36mm socket it no problem. I have never had a reason for a 36mm wrench. I really don’t want to spend $160 on a 36 mm snapon wrench and only use it 2 or 3 times in its lifetime. I looked on amazon and eBay. They range from $25-$50. Sunex to prono to gearwrench, More expensive Mac and even Williams. What wrench are you guys using to remove your rear tire? I’ve read a bunch of threads and several said buy off eBay and amazon. Are you using a $25 sunex wrench, $50 prono or gearwrench or $70 Mac or Williams wrench. Everything I also saw is 12 point which I am worried about stripping with a cheap wrench if that sounds right. Which wrench do you use to remove the rear tire axle nuts?
    Very Active Member M109Dreamer's Avatar
    Mar 2011
    Jackson, MS
    Quote Originally Posted by Wmoater View Post
    The is the one I purchased for $16
    https://www.amazon.com/Sporthfish-Wr...NsaWNrPXRydWU=
    I use it with a breaker bar and a torque wrench without any issues.
    2007 M109R LE - To many MODS to list. Its cheaper that way!!!
    Clinton, MS
    I purchased the Sunex https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Finish no quite up to Snap-on or Mac standards bit fits fine and it will outlast me.
    If you have a pair of channel locks you can use that to hold the end of the bolt or even better have any plumbing wrenches ???? .... The nut side is the critical piece and you have the 36mm socket ..... jmho .... good luck ..... Mike
    Mar 2016
    north dakota
    I have an evercraft 36mm combination wrench bought at Napa $35.99
    PA
    If I was on the road I’d use channel locks or pipe wrench but since I’m in a garage and have tools I’d rather use a standard wrench. Just the old school dad taught me and I passed on to to my kids also. I agree it will work, but I prefer a wrench over channel locks. There is a place and time for those tools. Thanks
    Active Member arkyleo's Avatar
    Jun 2021
    N. Central Arkansas
    Quote Originally Posted by sfcarn View Post
    I already had a 36mm socket, but it was 12 point--so I ordered a shallow 6 point 1/2" drive from e-bay and it looks great. For the tightening torque (nut side) I think the 6 point should be better and just hold the other side with the 12 point socket.
    2021 Spyder RTL Red, 2024 Triumph Speed 400, blue
    Oct 2015
    Lynden, WA
    I use this Buell 6 point wrench from Ebay.
    https://www.ebay.com/itm/112489151930
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Linden, CA
    Any local tire shop will dismount and remount the tire for you and I bet it will only run about $20 they may be able to balance it as well
    Harrington, Australia
    You say you will only use the new 36mm wrench 2 or 3 times, Wmoater, and you have a dealer who will do ALL the work for $125 and will install aftermarket car tyres. It sounds like you trust the dealers work. I know what I would be doing…….get the dealer to change the tyre 2 or 3 times, and let them handle any issues that arise like damaged “o” rings, alignment, tension, checking front sprocket etc etc etc…… but that’s just me.
    HeliBars Handlebars
    Kenda Kanine rear.
    Mar 2008
    Hesston, PA
    I don't have a 36 mm socket in my 3/4" drive set but I use the 1 7/16" one and it works fine...just a little loose...larryd
    Active Member redrazor's Avatar
    Mar 2020
    Martinez, CA
    Sounds like a really good deal to me. Great way to avoid a real 'PITA' job. I've done it once by myself; but would gladly pay $125 for someone else to do it.
    2014 RTL bought in 3/20 with only 6,000 mi.
    Came with Garmin 660
    Car tires in 5/20; Elka stage 2 front shocks in 10/21
    Feb 2019
    Portland, Oregon
    + I agree with what Peteoz said. You are very fortunate to have a dealer shop you trust and will mount car tires for that price - I don't. So I do it myself. Well....read this: https://www.spyderlovers.com/forums/...os-got-er-done
    + Not being a tool snob, I bought a very long combination 36mm wrench at my local used tool store for $7. It's probably made in Lower Slobovia, but it does the once-in-a-blue-moon job very well.
    + I bought Bajaron's 36mm shallow socket he sells for oil filter caps, but they work just fine on the rear axle too.
    + My 1/2" super long Harbor Freight cheater bar, alng with Bajaron's socket gets 'er done too.
    + I almost forgot....my newly acquired HF ICON Split Beam torque wrench - $117 with coupon - is a fantastic tool for that job. It comes with a test result certificte - it's more accurate than the Snap-On that costs 3X the price.
    + I buy quality tools that will get very frequent use and since the 36mm wrenches will collect dust most the time, I did the bang for the buck thing. But I "splurged" on the torque wrench, as it will see duty on other parts of the bike and elsewhere. I also help others with their Spyders.
    ./... However He was looking for the " least expensive alternative " .... Channel lock pliers will hold the head of the bolt just fine, so will a pipe wrench. A rachet for the NUT is the better way to go .... and He has that ..... just sayin ..... Mike
    Aug 2019
    Stoughton, WI
    Is the price of $125 for removing the rear tire from the machine, dismounting-mounting the new tire and reinstalling the tire on the bike? If so, $125 is a steal...
    2022 RT Sea To Sky
    INDIANA, USA
    Default Rear Tire Replaced
    That is a good price for $125.00. Let us know if this is true.
    My dealer charges $150.00.
    ENJOY YOUR LIFE WITH A SPYDER
    Aug 2020
    Georgia
    If you have a Northern Tool near you they sell a 36mm combo wrench for $25. If you have a coupon, you can save $5 each. They are excellent quality. My local Harbor Freight didn't have one that big but surprisingly my local Northern Tool had a vast selection of large sockets and wrenches.
    I bought 2 of the wrenches and cut one of them in half which I use to adjust the belt with a dead blow hammer on the right side axle nut.
    The one I didn't cut in half I use when torqueing the axle nut down: Wrench on left side, torque wrench and socket on the right side.
    Sold: 2020RT base with numerous improvements and farkles
    Previous 2 wheels: 3 BMWs, 1 Honda, 1 Yamaha and 1 Husqvarna
    Sep 2016
    Chillicothe, Oh.
    If you have a Tractor Supply store nearby they will have an inexpensive 36mm wrench. I also have Snap On primarily, but the TS wrench works just fine for the Spyder.
    2015 RT , Black
    PA
    Yes it is $125 for me to pull in to dealer on spyder, leave it there for the day, them take and remove entire rear wheel/hub/tire assembly from the spyder. Then remove the tire from hub/wheel. Install the new tire I have to supply. Balance and reinstall wheel/hub/tire. I drive away. The $125 is only labor plus $5 tire disposal and tax. I have to supply the $115 tire. I would have Netzley do it but my rear tire is just starting to show the remove lettering so in all honesty I have about 3-4 k left. My dealer was/used to $55 and now is $125. Netzley is still or was $60 last summer for rear/ $30 for fronts. I might be wrong compared to other dealers, I just figured that was a bit steep for an hour job. So are you saying yours is $150 labor plus the $120 for the tire so $260-270 total?
    PA
    I admit the new icon stuff is pretty good. I watched a video on YouTube where the guy destroyed one beside the snapon ratchet and it carried the same torque specs. I started with snapon in the 80s so once I invested then I just kept going. I have nothing against any tool. I used to use my tools 60 hours a week so the warranty and instant replacement was the priority. I agree that’s why I don’t want a snapon 36mm. It will just collect dust.
    Feb 2012
    Spring City,Utah
    Like you I already had a 36mm (from Mac) but not the wrench. I bought mine from Summit Racing, don't remember the brand but it was under $20. Works great.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Quote Originally Posted by M109Dreamer View Post
    It also works great as a torque multiplier so you only need about 120 lb-ft of torque to achieve 166 lb-ft on the axle nut.
    May 2018
    millsboro,delaware
    I already had full set of Snap On sockets but getting a socket to fit between the muffler and the axle nut is tough so thats why I found a cheap pair of 6 point, closed end wrenches with 1 ft handles. I carry both in the bottom of my frunk along with an Allen wrench for the adjustment blocks. I can still fit my Can Am suitcase on top of the wrenches no problem and if for some reason I have to pull wheel or adjust belt while on trip Im ready. Now I just need some kind of portable jack and I'm all set.
    Last edited by Peter Aawen; 02-24-2022 at 08:26 PM. Reason: Spaces after punctuation - so that text to voice can read it! ;-)
    : 2017 RTL ORBITAL BLUE
    Quote Originally Posted by spyder01 View Post
    I bought a few scissor jacks ( including an Alumin. one ) at a wrecking yard for cheap ( $ 5-6 ) they work great ..... Mike
    May 2018
    millsboro,delaware
    That would probably work but would take up too much space. I was thinking of the kind of airbag that you put inside of a coil spring on trucks, it will collapse down to nothing and weighs nothing, and I always carry a tiny compressor.
    Last edited by Peter Aawen; 02-24-2022 at 08:27 PM. Reason: spaces after punctuation....
