Results 1 to 15 of 15
    Nov 2018
    Altamonte Springs, Fl
    Default Can I change the Transmission Filter without dumping the oil?
    I have a 2019 RT Limited SE6. Can I change the transmission filter without dumping the oil? The Tran filter is due to be changed but I don’t need an oil change yet. Also what service interval do you use?
    Apr 2020
    Edgerton,WI
    Quote Originally Posted by dg110270 View Post
    You can......if you want to go through the bother of carefully measuring the amount of oil drained while performing the task. then adding new oil to replace the oil drained.
    **** I believe it would be best to wait for oil change time to do it.......the shop manual gives you the specific amount to add when changing the filter while doing an oil change.
    Follow the manufacturers recommendations .
    2019 F3L , Covid Blue
    How long until the oil change? I'd say if it's less than 5000 to 7000 wait until then to change the trans filter.
    Jan 2021
    Descanso, CA
    Lightbulb Here's my experience
    I purchased my 2014 RT-S SE6 77K miles as 3rd owner and didn't have access to service history so established maintenance baseline for everything.
    The 1330cc engine is dry sump when running with the sump refilling slowly after shutoff.
    I back the Spyder's front wheels up car ramps which provides easier access. The first oil change was part of a larger service and exploration of a new machine so the Spyder was on the ramps for about a week before I did the oil change. I drained the sump, removed the engine oil filter and then the HCM filter. Very little fluid came out of the HCM filter. The next two oil changes (I've done three in 8K miles finding the right oil -- Motul 7100 15W50) I changed the oil the same day I put the Spyder on the ramps -- about 8 oz of fluid came out.
    YMMV.
    Northern Kalifornia
    Wait until the next oil change. It's not a mess but it's that dam little screw at the bottom next to the frame I believe that is a PITS to get out. Once you get the cover off and have the filter in your hand you are going to wonder what the he!! is this going to filter? Well, it's simply a chunk catcher and for the price, I guess it's worth it. I kept my old one because it looked exactly like the new one. No debris and no chunks no nothing. So, if I ever need one I have an extra, the original one. Why, because it looks exactly like a new one. My spyder is a 2014 RTS SE6 so I'm sure your 19 is the same.
    .... IO did mine a few years back and felt the same way ..... I'm about to change it again and this will in all likely hood be the last time. .... I will only CLEAN the filter, and put it back ..... JMHO .... Mike
    Northern Kalifornia
    Yea me too. After seeing that thing and surmising what its purpose is, gives me the willies.
    Nov 2018
    My next oil change is at 30,950. Can I wait till then to change Tran filter for the first time?
    Nov 2018
    Thank
    I would.
    Active Member obiwanbill's Avatar
    Apr 2009
    toledo ohio
    this is asked in pure ignorance; Aren't you supposed to change filters each time you change oil on Rotex engines?
    Former Navy LT, Retired Chemical Dependency Therapist, Retired Widower, "Do, or do not, there is no try"... Jedi Master Yoda.
    Proud member of AA, PGR, and a Navy Shellback!
    2020 RT Limited Chrome , matte black trim, Green/gray Charcoal? depends on the lighting
    May 2021
    Alabama
    If its anything like my 2014...I was in the same spot...needed to change the trans filter but not do the almost $80 oil change...thought
    I would just pop it off, clean up maybe a dribble of oil...put the new one on and poof...well..........that dribble turned out to be a huge pool
    on the garage floor.
    Mar 2017
    Salisbury,NC
    Quote Originally Posted by obiwanbill View Post
    the oil filter is different than the transmission filter. its on same side, but down lower and more in front of round filter. its a flat type filter that filters oil thru the transmission for shifting. i changed mine at 30,000 miles with oil change. supposed to be 28,000 and every 28,000. close enough
    Not on the 1330 engines! The Rotax 1330 ACE engine is one of the best they have introduced. It does not use oil. It has longer service intervals than the V-twins. The best thing a new owner can do is memorize the maintenance schedule that appears in the operator's guide. One can change the fluids more frequently than the maintenance schedule if one chooses, but it's a waste of $$ IMNSHO.
    Jan 2021
    Descanso, CA
    Lightbulb Ya gotta Check Valve
    And here's the reason for your huge pool "Check valve prevents draining of engine oil from oil tank into engine clutch side when engine is OFF."
    The first time I changed the HCM filter the Spyder had been on ramps for a week as I explored my new machine. Very little oil came out of the filter when I removed it. The next two times I removed the filter the same day as I put the Spyder on ramps and I too had a huge pool.
