Results 1 to 25 of 35
    Apr 2016
    St. Charles IL
    Default Which F3's have Sport Mode?
    I guess the 2019 F3 LTD doesn't have a "SPORT MODE", or if it does, I can't find it....
    Am i missing something??
    Jan 2017
    Bavaria, Germany
    I think you're right. In the F3(-S) data sheet the sport mode is indicated, in the F3-T / LTD documents not.
    2016 F3-S Special Series , triple black
    Active Member monkeyboymorton's Avatar
    Sep 2015
    UK
    Yeah, F3-S only from 2017 MY I think.
    | 2015 F3-S | Heated Grips | USB Ports | RAM X-Grip | RT Sway Bar | '2 Up' Rear Shock | SHAD Bag Kit | Oxford Aqua 50 Dry Bag | BRP Rider Backrest |
    Apr 2016
    St. Charles IL
    Why would they not include the "Sport Mode" on the Limited model? It doesn't make any sense to me. The LTD is the top of the line! Why wouldn't you include all the bells and whistles on the top of the line model??
    Jun 2014
    Schenevus NY
    Because the LTD is supposed to be the luxury cruiser (with a cruiser position.) The S is the sport/hooligan model.
    Trb-- (Roger)
    2022 White Pearl F3T
    Spyder States Visited
    Apr 2016
    St. Charles IL
    Quote Originally Posted by Trbayth View Post
    I'm not disagreeing with you, I just think that if you have the "Top of the Line" you should have all the buzzers and bells. Just because people have the LTD doesn't mean they never want to play a little bit...
    I'm going to all BRP customer service later today and see what reason they give for not having it as an option...
    Greenville Tx
    Only the Sport model has a Sport mode. The Limited model has limited modes. Ha! There is also a difference in rear sprocket size giving the L more advantage on the road or long haul.
    2017 F3 Limited
    Florida Swamp
    Quote Originally Posted by 40Xshooter View Post
    One possible reason they did not put sport mode on the Limited is because it is larger, heavier, and more likely to be ridden 2 up. Cutting back the traction controls on a stripped down sport model does not present the same risks as cutting it back on larger, heavier model that is also often pulling a trailer.
    2019 F3-S , Black & Silver
    Feb 2018
    NorEastern, Washington
    Quote Originally Posted by AY4B View Post
    I see the smaller sprocket on the Limited as a disadvantage. Less torque for passing at HWY speeds, carrying a (2) up load, and pulling a trailer. From post here and on FB, the larger sprocket doesn't seem get worse mpg. Not many are going to max out the top speed advantage of the smaller sprocket either.
    Regards,
    Don
    2017 F3T , Triple Black
    Apr 2016
    St. Charles IL
    I can't believe that's the reason. Think about it; a potential buyer is forced to buy a lesser bike just to get "Sport Mode"?? Not buying it.
    (Can you tell I'm a little upset??)
    Active Member ChicagoSpyder's Avatar
    Chicago
    Quote Originally Posted by dondje View Post
    Regards,
    Don
    The Limited has plenty of torque at speed, it's a little soft coming out of the hole, but a brake torque helps with that
    2018 F3 Limited , Black/Chrome
    Aug 2019
    Stoughton, WI
    When I test rode a 2019 F3-S last week, I never tried the sport mode. Is it a noticeable difference ? Quicker shift points, less shift lag ? Curious...
    Jan 2021
    northeast pa.
    2020 F3 Limited - can't find Sport Mode. Altho it says I have a Sport Mode in my manual, when I push the Mode button, all I get is normal mode - no icon, or eco-mode - eco-icon. I see no Sport Mode?? Is it not available on the Limited model? Probably not, but I have to ask... Thanks.
    Last edited by Peter Aawen; 07-31-2023 at 06:58 PM. Reason: Moved Post title into text after merge - many only see Thread titles, and post titles mess with Searching! ;-)
    2020 F3 limited, liquid titanium
    grip puppies
    Bajaron sway bar
    lamonster belt dampener
    battery tender
    19 in freedom tinted windshield
    matte black daytona frunk wrap
    Quadtrac 165/60's
    Apr 2020
    Edgerton,WI
    Quote Originally Posted by fredgal View Post
    I have a 2019 F3L.... only two throttle modes available...... Exercise Wrist ECO Mode; and Normal with no indicator light Mode.
    Last edited by Peter Aawen; 07-31-2023 at 07:00 PM. Reason: Fixed quote display ;-)
    2019 F3L , Covid Blue
    Feb 2020
    N. Wilkesboro, NC
    I thought Sport mode was only offered on the F3 S.
    Active Member LifeLongRider's Avatar
    Aug 2018
    Florida
    F3L - normal and econ modes only . . .
    2019 F3 Limited
    2019 F3 Limited , Oxford Blue
    May 2013
    Apex, N.C.
    Quote Originally Posted by MONK View Post
    You are correct. There is only an eco and normal mode for the other models.
    We have both 2019 F3L and 2020 F3L. No sport mode. IMO...not needed anyway. If I punch it...I can go plenty fast. Just ask Randy the Sheriff down in the Ponca area. I wrote about that one earlier.
    Jan 2021
    northeast pa.
    ok thanks all you spyder people,, must be the next trim level down has it, must be the manual is for both the F3 and the F3-limited.. page 37 of manual ..shows all 3 modes
    grip puppies
    Bajaron sway bar
    battery tender
    Quadtrac 165/60's
    Jan 2021
    northeast pa.
    yes i looked down on my last ride when it was nice out, and i was doing 75, it was so smooth , i did not notice. like a new car or truck, coming off my 1500 vulcan to this thing is amazing.. no more back pain after a ride..
    grip puppies
    Bajaron sway bar
    battery tender
    Quadtrac 165/60's
    Greenville Tx
    No Sport mode on the limited. You can however get an ECU stage 2 Flash and have all the speed you want and still have your nanny keep you planted on the ground.
    2017 F3 Limited
    May 2018
    virginia cape charles
    Does the F3 Limited have the sport mode?
    2021 f3l , large pedal pad and lamonster lowering rod liquid titanum
    May 2013
    Apex, N.C.
    The only spyder with sport mode is the F3S. The Limited and the F3T do not have sport mode.
    Model year would help. If MY 2020 and later, yes, and it's explained in the operator's guide.
    May 2013
    Apex, N.C.
    you got me on that one. I wasn't aware of any models of the F3 Limited that got the sport mode. I thought that was something that wasn't introduced until 2017, and only on the F3S models. Guess I learn something every day. I am still disappointed that the larger sprocket is not available on the F3 Limited and F3T anymore. A friend just picked up a 2021 F3T, and I am anxious to see how it compares to my 2016 F3T with the larger sprocket.
