Results 1 to 3 of 3
    Jan 2020
    Wales
    Default What's the correct bolt size on the brakes - 2011 RSS?
    I am one of the fools that went to remove the abs sensor on my 2011 rss to change the brakes( i know i know) unfortunatly the head on the nut sheared off, i could not remove it as it appeared cross threaded by whoever put it on last time so i had to drill it out.That went successfully and no damage to the hole so just need to tap it tomorrow.
    Does anyone know what the bolt size is? i know it's a 10mm head.
    Oct 2020
    Arizona
    Maybe this?
    Hex. Forming Screw M6 X 20 PN 210262050
    https://www.brppartspitstop.com/oemp...ories-rear-se5
    Jan 2020
    Wales
    Quote Originally Posted by Snoking1127 View Post
    Maybe this?
    That's the one,thank you.
