Page 16 of 80 FirstFirst ... 61213141516171819202666 ... LastLast
Results 376 to 400 of 1999
  1. #376
    Active Member rmag's Avatar
    Jun 2015
    miamisburg, ohio
    Finally got my PPA wheels on. Like the look much more than the oem wheels and are much easier to clean.20200822_175002.jpg
    2014 RT Limted, platinum, with matching 622 trailer.
    Ultimate tall boy seat w/adjustable back rest, Corbin armrests, Spyderpops bumpskid & missing belt guard, BRP side air vents, Lamonster lidlox, cargo nets, Stebel air horn, Wrap my spyder accents......and more
  2. #377
    Sep 2018
    greensburg,pa
    UNFARKELED IT! No more accent lights,heated gear cords.
    I smell a 2021 coming soon
    2018 RT-L , Blue
  3. #378
    Jan 2019
    Toowoomba Qld Australia
    Removed rear wheel and took it down to have a Hankook Kinergy eco 2 215x60x15 fitted. Whole process was easier than I first thought. An extra set of hands definitely helped out too.IMG20200825085416.jpg
    2014 ST-S SE5 Cognac
    2014 ST-S , Cognac
  4. #379
    Oct 2015
    Lynden, WA
    Rode in the RAIN...in Northern Nevada.
    Re-installed the old/original gas cap. The gas smell is gone.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
  5. #380
    Aug 2019
    Stoughton, WI
    Quote Originally Posted by rmag View Post
    They're on my winter 2020/21 mod list
    2022 RT Sea To Sky
  6. #381
    Active Member scorpion56's Avatar
    Jun 2020
    Boston
    Re-routed the dealer-installed Battery Tender cable from the compartment where the radiator reservoir sits, to near the left shock. Now, instead of having to open the frunk and removing the panel above the reservoir each time I want to hook up the tender, I can just kneel down by the left wheel and connect to the lead. Made sure to use tie-wraps as strain reliefs and to protect the cable from chafing as it routed through the "wall" behind the battery. If you have a battery tender you know that the cable has a protective cap when it's not in use, so that takes the weather/washing question into account.
    2019 Can Am F3 Limited
    Spyder Upgrades/mods:
    F4 Windscreen,
    Ultimate seat and Driver's backrest,
    Lamonster Fog lights,
    Lamonster Brake Rod kit,
    CanAm Short Reach Handlebar
    Other Current Bike: 2009 Honda Shadow 750 Aero
    Past Bikes:
    2018 BMW C650CT
    2013 BMW C650GT
    2011 Honda SH150i
    2019 F3 Limited , Oxford Blue Metallic
  7. #382
    Mar 2015
    forrest above Reno, Nv
    Built some hwy foot rests for long distance ryding. $7 in steel ( 1/4" thick x1 1/4" wide). Just couldn't see paying $150+ for just the mounts. Why didn't I do this years ago?????hwy foot rests.jpgInstalled Hwy footrests.jpg
    I would sometimes rest my feet on the splash deflector ( feeling guilty every second) BUT no more.
    Lew L
    2014 RTS , Circuit Yellow
  8. #383
    Aug 2019
    Stoughton, WI
    Cut/shaped some wheel spoke accents using red reflective 3M outdoor decal tape. This will do until I get some new PPA wheels over the winter..
    2022 RT Sea To Sky
  9. #384
    Mar 2013
    Today I washed it for the first time since May.
    Then I added KNOTT grill covers (with filter material behind them)
    LED brake/run lights from Spyder Pops
    Powerlet Power socket to feed my heated liner as well as for a battery maintainer
    Last was the pad switch for my Mo-Door garage door opener. The control unit is in the right speaker well.
    Not allowing me to post pictures:gaah:
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
  10. #385
    Linden, CA
    I put 135 miles on it and it was super smoky because of all the fires here in California
    if any more burns, we will not have to worry about fires for years because there will not
    be anything left to burn
  11. #386
    Mar 2018
    north georgia
    removed front pulley on my 2017 RT due to red rust, pick up new pulley tomorrow and complete this project
  12. #387
    Active Member RudyB's Avatar
    May 2016
    Abbotsford British Columbia Canada
    Quote Originally Posted by PW2013STL View Post
    Picked up gas to top off the tank for the winter storage and received a K&N air filter to put in. This will complete my maintance work which was new spark plugs, oil and filter change, transmission filter replaced, gas filter changed, and sea foam added to the gas tank, battery tender hooked up.
    How many miles on your Spyder when you changed the plugs mine is still going strong with 54000miles on original plugs
  13. #388
    Durham,Maine
    What did I do to my spyder today?? Tried to get it back from the shop!! Darn water pump went and they needed a pump shaft and had to order it!!! The darn virus has everything screwed up and I am still waiting for parts!!
    2012 RTL , Pearl
  14. #389
    Feb 2015
    Southern Maryland
    Yes, the F3L has a stop/brake light in the trunk. It's fun to put a flasher on the brake light element. Here's the one I used:
    https://www.banggood.com/12V-LED-Con...r_warehouse=CN
    Hi RICZ. Can you provide more details on installing this unit?
  15. #390
    Feb 2019
    Portland, Oregon
    Quote Originally Posted by jmurray View Post
    Remove the trunk light by pulling out the two push pins. Determine which two wires supply the brake light and simply splice the flasher unit into the brake light circuit.
  16. #391
    Jan 2019
    New front tires so all 3 have been replaced now at 18,800 ks. Fronts now are 175x50x15 Hankook Kinergy eco K425 (215x60x15 K435 on the rear). At the moment 22 in the rear and 20 in the front.
    2014 ST-S , Cognac
  17. #392
    Mar 2015
    Thumbs up " WE ryde at dawn"
    Gave the the inspection for our trip to the NON-NorCal NON- rally. Lights, fluids, tire pressures, ect. It will be 1000 miles ++ total and a week on the road. We'll be going through Red Bluff on Sunday--- supposed to be 110*F ---- " WE ryde at dawn"
    Lew L
  18. #393
    Aug 2008
    Maryland
    I love the look
    2020 RT Ride Frequent Stay Safe
    Aftermarket Aux Light, GPS mounting/wiring, Lamonster Garage Mirror Lock, Lamonster Garage Belt Tensioner
    Backrest Home Brew Mod
    2008 RS from 2008 through 4/2015, 2015 F3-S from 4/2015 through 9/2020
  19. #394
    Feb 2019
    Portland, Oregon
    My turn, my turn!!!
    Had Federal Formoza tires put on the front today, although I have but 4K miles on the bike. All the positive comments about switching to car tires, prompted me to do it. And I am so glad I did. First thing I noticed was far less rolling resistance. Then, on a straight stretch, I set the cruise and took my hands off the bars for the first time without drama. There were but a few curves and corners on the way home, but it's obvious these Formoza tires bite the road a lot better than the Kendas. They required only 3/4 of an ounce to balance. Nice! I'm starting out with 18.5 psi, figurung I can always let some air out easier than put some in. Oh, and I had them put in valve stems that were a bit longer so I can check the tires and air them up without having to use an extension.
    In case you are wondering why the Federals, I like to trade locally and my go to shop could only score those tires in the appropriate size.
    Thanks to all, who before this, posted the good results of switching to car tires - at least up front.
  20. #395
    Quote Originally Posted by Lew L View Post
    Lew L
    Queue Music: "The Good, The Bad, and The Ugly"
    Jun 2015
    miamisburg, ohio
    Quote Originally Posted by BeRight View Post
    I love the look
    Thanks, I'm really happy with em.
  22. #397
    Feb 2019
    Portland, Oregon
    Hey Lew....Are you going to ride infamous Highway 36 to Fortuna on the coast? If you've never ridden it, be prepared for a real workout.
    https://www.youtube.com/results?sear...nia+Highway+36
    https://www.google.com/imgres?imgurl...MygSegUIARC5AQ
  23. #398
    Durham,Maine
    I think I am getting it back from the doctors today!! This water pump job was a real LONG ordeal waiting for parts!! But my new knee and my fixed bike are ready to roll!!
    2012 RTL , Pearl
  24. #399
    Very Active Member Bangorbob's Avatar
    Jun 2018
    Pahrump NV
    You'll love your new knee. Had my right one done 8 yrs ago. I get on from the right side (as you're sitting) as I have trouble sometimes bending knee getting on the other side. Good luck and enjoy both (knee & ride)
  25. #400
    Mar 2015
    Thumbs up Yes on 36
    As a matter of fact---- YES. I live in the mountains and road signs like " curvy roads next 20 miles" are common. This one is just longer and we are ready for it. Not in a hurry---- only going from Red Bluff to Leiota that day, Just so I don't get stuck behind a lumber truck or motorhome. " Brakes are good-- Tires fair" Actually both are excellent.
    Thanks for the warning though,
    Lew L
