Page 17 of 76 FirstFirst ... 71314151617181920212767 ... LastLast
Results 401 to 425 of 1881
  1. #401
    Oct 2019
    South Africa
    Hi all
    Fitted the Tri-Axis handlebar
    2019 RTL , white
  2. #402
    Oct 2016
    Sebring, FL
    Those look great, will the Tri-Axis work on the 2020 RTL for heated grips?
  3. #403
    Feb 2020
    CT and ME
    Installed the RLS cat delete. Wow nice sound with stock muffler. Deeper, a little not too much louder. Makes the bike seem "bigger" or beefier in some way.
    I tried it first without the additional baffle piece but now put that in. I'm on a stepping path to getting Stage 2 tune eventually.
    My Mods:
    Elka Stage 5 rear shock with spring preload adjust
    Monster Stage 2 ECU
    Pedal Commander
    RLS cat delete
    Baja Ron sway bar
    Baker Air Wings upper and lower
    Viking saddle bags
    Third pegs
    Vredestein tires front and rear
    Mad Stad windshield
    X-creen windshield deflector
    Front and rear drive cam
    Garmin Zumo XT
    Heated gear wiring
    Lamonster LED headlights
    Lamonster LED foglights
    Lamonster frame mount cupholder
    BRP heated handgrips
    Lamonster drivers backrest
    BRP passenger backrest
    Lidlock handlebar end helmet locks
    Barkbusters Storm handguards
    2020 F3S-SS , Titanium/Black
  4. #404
    Feb 2019
    Portland, Oregon
    Quote Originally Posted by Yabbadabbadoo View Post
    Is this the cat delete with the resonator? Could you describe the difference in sound between baffle and no baffle?
  5. #405
    Oct 2019
    South Africa
    The Tri-Axis fit up to 2019.
    2019 RTL , white
  6. #406
    Sep 2017
    Durham,Maine
    Finally put on my led headlights and fogs, I got from Lamont almost two years ago now!!!! Don't want to jump right into things you know!!
    2012 RTL , Pearl
  7. #407
    Aug 2019
    Stoughton, WI
    Mounted up my PPA wheels and added on some low cost risers..
    2022 RT Sea To Sky
  8. #408
    Aug 2008
    Maryland
    Rode her home from the dealer (new 2020 RT) - 1hr + mostly winding back roads - great to be riding again.
    2020 RT Ride Frequent Stay Safe
    Aftermarket Aux Light, GPS mounting/wiring, Lamonster Garage Mirror Lock, Lamonster Garage Belt Tensioner
    Backrest Home Brew Mod
    2008 RS from 2008 through 4/2015, 2015 F3-S from 4/2015 through 9/2020
  9. #409
    Feb 2020
    CT and ME
    Yes this is the RLS cat delete with the resonator, black powdercoat. I went for a little over an hour ride with it this morning. Installing the baffle piece really made quite a difference. Quieted it down a lot. The sound is now more reasonable, deeper than with the stock catalytic converter but not too much louder. I definitely noticed reduced low end torque without the baffle. With the baffle installed the torque feels pretty normal again. I need to do some more riding with it - I haven't been on the highway yet with the baffle in. I also want to see how it feels running with a heavier 2up load. I'll update again maybe after the weekend.
    My Mods:
    Monster Stage 2 ECU
    Pedal Commander
    RLS cat delete
    Baja Ron sway bar
    Viking saddle bags
    Third pegs
    Mad Stad windshield
    Garmin Zumo XT
    Heated gear wiring
  10. #410
    Feb 2019
    Portland, Oregon
    thanks for that input Yabby. I have the delete with the resonator, but not the baffle and did not notice and loss of power or torque. She runs like a scared rabbit even 2 up. I may be old, but I certainly am not slow. I ride fast and take the curves fast and so far, she puts out more than enough suds for me. Maybe in winter, when I'm looking for things to do, I'll slip the secondary baffle in to see what it does.
  11. #411
    Feb 2013
    Edinburg, TX
    I re-blacked all the graying black plastic that's now 5 years old. Looks great!
    I don't know what it is, some stuff that looks and feels just like white milk. Given to me by a neighbor lady who says it only comes in 1-gallon cans for about $25. She learned about it from her golf-cart servicer... her cart trim looks good & shiny too.
    NEW - 2015 RT Limited SE6 Intense Red Pearl - 07/21/15
    Retained the old mirrors with TricLed Signals
    General Altimax RT43 rear tire (at...17,000 miles) Ran for 36,500 miles
    Michelin Defender.......rear tire (at...53,500 miles) Ran for 60,700 miles
    Riken Raptor HR.........rear tire (at 114,200 miles)
    Vredestein Quatrac 5 front tires (at 70,500 miles, first new fronts!)
    Gear Brake Decelerometer Module
    OLD - 2012 RT Limited SE5 Pearl White - 01/31/13 - Traded in at 32,600 miles.
    BajaRon Anti-sway Bar
    Kumho ECSTA AST rear tire (at 14,200 miles)
    TricLed Turn Signals in Mirrors
    2015 Limited , Intense Red Pearl
  12. #412
    Aug 2008
    Maryland
    added sling mods (bigbikeparts) backrest
  13. #413
    Apr 2019
    PA
    Installed Lamonster Belt tensioner with XL roller. I tried everything. I tested the flex. Loosened the belt a touch and it went from 68-72MPH to 65MPH vibration. I tightened even more like a couple people on other threads said and it went back to 68-72MPH vibration. I tightened it even more and it still vibrated it. Loosened it back to BRP SPECS again and Installed the belt tensioner and GONE! I have no problems changing the bearing every other oil change. I ride 2 up a lot and my wife was even feeling it. I got into a habit at 72 to go past to 74MPH it and then relax throttle and it would go away. Now I don't have to worry about it anymore! She noticed it right away and I didn't even tell her.
  14. #414
    Aug 2020
    Ohio
    Added a Battery Tender cable to my battery. Figured out where I'm going to add a USB charging port. And narrowed down my fog light issue to what I think are bad bulbs, everything else checks out.
  15. #415
    Aug 2008
    Maryland
    while measuring polarity of aux light socket (lower front connector) - I shorted my leads together - didn't see sparks/wires not warm - but zero voltage
    One might ask why did I try to measure polarity - well I've found wires crossed from factory before.
    Discovered (now) no headlights (running lights/brake/turn ok-brp connect 5v usb ok - dash display ok- bike running ok) - plan to replace headlight relays (2) tomorrow and hopefully that fixes my oops moment!
  16. #416
    Aug 2020
    Ohio
    Installed my volt meter/phone charger today. I know it's not much but it's somethingIMG_20200914_191010553.jpg
  17. #417
    Mar 2015
    forrest above Reno, Nv
    Insulated the "glove box" on the '14 RTs.Took of tupperware and didn't see any good places to apply the insulated " wrap" . It's thin ,so I lined the inside. I also have had a 1/2" of foam on the bottom of the box to keep the .38 from bouncing around.
    Lew L
    2014 RTS , Circuit Yellow
  18. #418
    Feb 2019
    Portland, Oregon
    I don't call 911, I call 9mm. Where I live is getting as bad as Chicago when it comes to shootings. Gotta be prepared.
  19. #419
    Mar 2015
    When the police are minutes away-----------Or if they don't come at all.
  20. #420
    Sep 2017
    Durham,Maine
    Quote Originally Posted by Zanico View Post
    You got small arms, will be a easy job!! Good luck!!
    2012 RTL , Pearl
  21. #421
    Sep 2015
    Chilliwack, BC. Canada
    Well, I haven’t Installed them yet, but I did just order a set of LED headlights for my 2014 RT-S from Pierre at CanAmSpyderAccessories.com
    Bruce
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
  22. #422
    Dec 2014
    S.E. Michigan
    Replaced "meep meep" horn with a car horn.
    ~Sandee~
    ~Sandee~
    2016 RT-L (Purchased used in February 2018)
    RT Dash Mount (from JT's Spyder Store)
    Kuryakin Trident Highway Pegs
    Hopnel Pouch
    Magic Mirrors
    Spyderpops Foam Handgrips
    Iron Butt #35273
    Girls on Spyders #2779
  23. #423
    Sep 2017
    Durham,Maine
    Put a comfort seat on the RT today!!! Now to see what difference that makes!
    2012 RTL , Pearl
  24. #424
    Aug 2008
    Maryland
    Yesterday installed 2018 F3 Limited handlebars on 2020 RT - love it. Super easy install.
    On another day I forgot to mention installed GPS and rode to MVA
    Need to get some lights for front fenders - may wait till winter to install - little time left for riding
    Ride frequent and Stay Safe
  25. #425
    Aug 2019
    Stoughton, WI
    Installed (3) sets of EBC HH brake pads today. Now to "break" them in as best as possible...
    2022 RT Sea To Sky
