Results 1 to 18 of 18
    Mar 2015
    Indianapolis, IN
    Default Tell Tell Signs between 600 and 900?
    So with the Spyder RT there's a few subtle tell tell signs that jump out to a trained eye as to if it's the old 998 motor or the new 1330 motor.
    I'm curious on the Rykers - is there any tell tell signs that someone can see and go - oh, that's a 900 or oh, that's a 600?
    Joshua
    2012 Victory Vision
    2016 Spyder F3S
    2019 Spyder RT Limited
    2016 F3S , Triple Black
    Sep 2019
    Gilbert, AZ
    The 900 has “900” on the front storage lid.
    2022 RT , Petrol Blue
    Mar 2015
    Indianapolis, IN
    Quote Originally Posted by gr8Frank View Post
    Oh, like a decal? Is it on all the 900s (unless the owner has taken it off of course)? Good to know!
    Joshua
    2012 Victory Vision
    2016 Spyder F3S
    Very Active Member SportsterDoc's Avatar
    May 2020
    New Mexico
    900 is molded into the plastic, but numbers are very small. Not likely to be noticed unless walking by while it's parked.
    I'd say the biggest tell-tail sign... is when you twist the throttle!
    Jun 2015
    Ritzville, Wa
    Is the length of the rear fender different between the 600-900? I thought the 600 had a shorter like a mini fender.....
    Nah, in looking at pics, the 600 seems to have the same rear fender design as the 900 ACE.
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
    Very Active Member Markubis's Avatar
    Jan 2018
    NH
    Quote Originally Posted by gkamer View Post
    Close...the rally has a short back fender.
    Last edited by Peter Aawen; 02-23-2024 at 05:44 PM. Reason: Fixed quote display ;-)
    Mar 2015
    Indianapolis, IN
    The Rally (all Rallys are 900s, but not all 900s are Rallys) got a short fender. The idea being that it can do more dirt roads/etc and they didn't want things caught up in the full fender. But humorously, most folks want the full fender when doing more dirt roads/etc so that junk isn't thrown up at them.
    Joshua
    2012 Victory Vision
    2016 Spyder F3S
    Mar 2015
    Indianapolis, IN
    I'm sure you are right about that. But I've actually heard the 600 is surprisingly peppy as well. I'm just more curious when walking around and seeing them parked, etc. if you can quickly tell the difference. Now I know to look for the 900 on the glovebox panel. I install LED lighting/etc. on rides and in the last week I've been booming with Rykers - so was just curious how to tell them apart.
    Joshua
    2012 Victory Vision
    2016 Spyder F3S
    Jan 2020
    California
    I think the biggest difference is the 900 Ryder gets to know the folks at the Chevron better.
    May 2020
    New Mexico
    Quote Originally Posted by Rydernow View Post
    Or Shell!
    Averaging 33-34 MPG most rides.
    May 2019
    Albuquerque NM
    The last two fill-ups on my 900 yielded 39 and 40 mpg. It's all in how you ride.
    Sep 2019
    illinois
    Quote Originally Posted by rakerrykerrider View Post
    My ride this past Tuesday of 80 miles (round trip on county roads) to my Rally dealer was 39.6 mpg. I average around that a lot. I enjoy the county roads more than the highways. btw 50 miles round trip on the high way.
    The 'most obvious from a distance' thing that I notice between the two different machines as they ryde past is the engine noise?!? I generally can't 'see' what they're doing in the way of fuel economy when they ryde on by and I don't always have the time or opportunity to talk to the owner/ryders in that much detail. Buuut, even with what little of my hearing that's still left functioning, there's a distinctive & noticeable difference in the noise & the 'feel' of the sound the different engine's make....
    Not sure I can describe it all that well . but the noise from the 600's sounds & feels like it's coming from a smallish twin cylinder engine, especially when they are revving away
    While just like the 1330's, the noise from the 900's sounds & feels like it's coming from an over-revved sewing machine that's desperately trying to escape the suffocating confines of all the tupperware.... . I guess it's more of a 'feeling' about the vibrations on my skin from the sound waves, but the 900's somehow feel 'rattlier' & more 'frenetic' even as they do get up and go!
    So for whatever that lot's worth....
    May 2020
    New Mexico
    The 600 is peppy. I test drove a new one to figure out if I would be satisfied with a Y roadster.
    The dealer had not yet assembled a 900, so a new 600 off the showroom floor was fueled.
    Being a new motor, I was cautious with revs, but at the end of the 10 mile ride in the south of Las Vegas valley, I got on highway 95, went a few miles, doubled back to check uphill on-ramp acceleration. I would have enjoyed a 600
    However, riding steep grades at elevation, I suspect that less than 900 would not satisfy for long.
    The Ryker 600 is 50 HP @ 7300, idle 1100 RPM, 12:1 comp
    The Ryker 900 is 82 HP @ 8000, idle 850 RPM, 11;1 comp
    https://lam.can-am.brp.com/content/d...heet_EN_LR.pdf
    The bottom line is a 600 has a great price point and satisfaction likely based upon how it will be used: Great commuter.
    Jun 2011
    Alamogordo, NM
    With a CVT transmission that the Rykers have, exactly like most ATV's and Side by Side's, ie same normal clunking characteristics utilize the torque of the various motors rather than Horse Power.
    Dean O
    Gran Pa Hoon
    Founder San Jose BMW
    Alamogordo, NM
    '20 Spyder F3 L
    Jun 2011
    Alamogordo, NM
    I have ridden a 600 2 cylinder up to about 60 MPH, totally surprised on its pep and power. Also really liked the sound and feel, AKA, soul of the machine. Have not had a chance to either hear or ride a 900.
    Dean O
    Gran Pa Hoon
    Alamogordo, NM
    '20 Spyder F3 L
    May 2020
    New Mexico
    Quote Originally Posted by old Timer View Post
    With a CVT transmission that the Rykers have...utilize the torque of the various motors rather than Horse Power.
    With due respect (think you are older than me), I am not following your comment
    The 600 torque is 36.7 @ 6000
    The 900 torque is 58.3 @ 6500
    HP = RPM * torque (at rated HP RPMs) / 5252
    For the 600, HP would equal 7300 * 36.7 / 5252 = 51.01, if torque remained the same at HP rated RPMs. Since Can-Am rates the HP at 50, then it appears that torque is dropping at 7300 RPM. Solving for torque at that RPM 7300T/5252=50. T=35.97 @ 7300
    For the 900, HP would equal 8000 * 58.3 / 5252 = 88.8, if torque remained the same at HP rated RPMs. Since Can-Am rates the HP at 82, then it appears that torque is dropping at 8000 RPM. Solving for torque at that RPM 8000T/5252=82. T=53.83 @ 8000
    The bottom line is that although the torque curve has decreased at the HP rated RPM, the Rotax motors are using higher RPMs to gain HP.
