Pierre from www.canamspyderaccessories.com has a color-matched front fog light casing replacement that extends across the hood as well. Really sharp and not too expensive.
I've sent several product requests to the above re: gloss black housings with zero replies. Maybe I need to call them but not impressed, at all, with their CS
2022 RT Sea To Sky
Merry Christmas. I installed a set of LED semi trailer side marker lights (orange) in this location. They come with a rubber gasket for mounting and fit perfectly in this location. I carefully cutout the hole to fit them. They just slide in an are held tight on their own. They are the extra bright 5 element LED type and cost about $10.00 a piece online or at Northern Tool. I don't know how to add a picture but you can see them in my signature picture. Enjoy!
Just throwing out the link. Probably not right tho
That's fine Rattlebars. You could've even thrown in a description telling us it was a link to the Blazer Incandescent Round Clearance Marker Lights that you've used or found.... It's 'adverts' or 'quotes of adverts' that are frowned upon.
Open them up and duct more air into the cowl area.
If you are going to make vents of the opening, get the OEM shrouds. I'd give a link to them but I sure as gosh don't wanna get scolded for nothing again.
