View Poll Results: How often do you check your windshield mount?
Voters
347. You may not vote on this poll
  • Windshield mount, what are you talking about, I NEVER check it.
    132 38.04%
  • I only check it durring routine maintenance.
    115 33.14%
  • Mine hasn't broke, but I still check it before every ryde.
    77 22.19%
  • Mine broke, so I check the new one every time I go for a ryde.
    23 6.63%
Page 7 of 8 FirstFirst ... 345678 LastLast
Results 151 to 175 of 190
  1. #151
    Oct 2007
    Default RT 2010 Windshield Problem
    Mine broke and I'm out of warranty. See my post "RT 2010 Windshield Problem"
  2. #152
    Mar 2016
    Dunedin, New Zealand
    Default new to forums
    Quote Originally Posted by Pandy View Post
    It's fugly as mentioned in another post, but it is re installed and action is normal.Will remount windshield shortly and test action fully.
    Now, what's this about updated mounting hardware? I was going to shim around the pins with Teflon washers to reduce some inherent slop(at least on my 2011) and reduce what has always been some side to side movement. Yes, I intend to live with this awhile. And a Laurel and Hearty handshake to those who have braved this before me! Patrick
    thankyou for photo I have a friend that is going to try to sort a new arm for mine, it snapped in the middle just like this photo, unsure how to follow this thread so thought if I replied it would save it somehow,
    Kind Regards
    J
  3. #153
    Jun 2014
    Southern New Jersey
    Thanks for the info. I will check mine when I get home from work today.
  4. #154
    Mar 2016
    Default Well thank goodness didn't take advice from can am and spend 2000.00
    Thankyou to this forum I was reading thru and can get a dog bone arm sent for nzd 170.00 including postage from Australia, so now feeling a lot happier, just hope fitting it will not be too much of an issue
    I have kept the contact persons name and e/mail if anyone would like it
  5. #155
    Active Member noboot's Avatar
    Sydney Auustralia
    I currently have some of the Billet RT Arms available if anyone is interested.
    You can PM me if interested
  6. #156
    Active Member Border Rider's Avatar
    Aug 2015
    Derby Line Vermont
    Default Border Rider
    Thank you for the heads up I checked my 2011 RT today and mine is cracked. Went to my local dealer and got one
    ordered today, warranty runs out 6/16,
  7. #157
    Active Member wanderingman's Avatar
    Dec 2014
    Ave Maria, Florida
    Default Winshiel bracket breakage.
    This subject was brought up previously and one poster mentioned that raising the windshield up slightly off of the lower stop seemed to reduce this possibility from occurring.
  8. #158
    Sep 2014
    Argyle, Texas
    Quote Originally Posted by noboot View Post
    When it goes, it goes QUICK. Got my attention!
    I bought billet from NOBOOT, and LOVE IT!!!!
    If you have a STOCK arm, BUY a billet from NOBOOT, and put it in your toolbox for WHEN yours breaks, not if...
  9. #159
    Gatineau, Quebec
    Default RENECON
    very interested
    What would be the price plus shipping
  10. #160
    Apr 2018
    Webster, NY
    Thank you for the heads up, will check today as I am installing my air intake vents/scoops.
    2018 RT , Larger pedal Pearl White
  11. #161
    This thread dates back to 2011. We have not heard of windshield arm issues for a long time now. No problems with my 2011 or 2014.
    Nov 2017
    San Francisco Bay area
    21,000 miles and mine is fine. Guy who sold me the bike warned me to not leave it lowered or raised all the way though and I think that's in one of the new owner stickies too.
    2015 Pearl White RTL
    Baja Ron Sway Bar
    Russell Day Long Seat
    Strobe Brake Light
    2015 RTL , Yes Pearl White
  13. #163
    Quote Originally Posted by LeftCoast View Post
    I do the same.
    Before " No Boots " designed the Aluminum ones, I took mine apart and added 22mm metal sides and a strap that went completely around the arm …. I then welded the three pieces together , it's now almost indestructible ….. Something I did discover was when the ARM is fully down, it doesn't actually rest on anything ….. while testing my ARM I put a piece of paper on the metal part under ARM when it is lowered. I could easily take the paper out, the ARM wasn't touching it...… some Myths need to be debunked, like the " remove key and walk 20 ft. away for 10 minutes to re-set the computer " and you should be able to re-start the Spyder …. Billy Bovine has written a few post on this …… Mike
  15. #165
    Sydney Auustralia
    The arms still appear to be breaking "now and again" as we get someone wanting a replacement.
    A lot of people seemed to have moved onto F3 Spyders
  16. #166
    Danbury Connecticut
    Is it too early to know if your arm fits the 2020 RT ??
    Upgrading to your arm was the first mod I made to my 2014 RT.
    I'm thinking the 2020 isn't going to be any better.
    IBA #47122
    2020 RT Limited Asphalt Grey
  17. #167
    Sydney Auustralia
    We in Australia don't get to see a 2020 model before March / April and there are no parts lists available on line so we don't know what the 2020 model windscreen arm looks like.
    But if it's the same as previous years, yes it's available.
  18. #168
    Apr 2012
    Arizona
    Great information! Thanks for sharing. I'll keep an eye on mines.
  19. #169
    Jun 2021
    NE
    I realize this whole discussion was a long time ago but I am needing the arm to lift my windshield. Any idea where I can locate one? Mine broke while trying to fly home in the start of a storm and high wind....that was a thrill! LOL
  20. #170
    Dec 2015
    Oakley Utah
    Quote Originally Posted by farmgal View Post
    Go to this thread instead https://www.spyderlovers.com/forums/...the-windshield
    2014 RTL Platinum
  21. #171
    Apr 2020
    Edgerton,WI
    Quote Originally Posted by Lamonster View Post
    I think that is the third of forth one I've seen now.
    ********* He’s BACK!!!**********👍
    2019 F3L , Covid Blue
  22. #172
    Quote Originally Posted by bikerchris1270 View Post
    Sorry...
  23. #173
    Sydney Auustralia
    Have sent you a PM to farmgal
  24. #174
    Northern Kalifornia
    A few weeks ago I had a long slow ride on a very rough road. I normally ride with my windshield up about 1" off the bottom. I noticed a lot of flex going with the windshield and the arm in question. When I dropped the windshield all the way down I could see the arm absorbing all the flex. Same when I raised it up all the way. So, I think there is a bit of truth and good advice from those who say don't ride with the windshield all the way up or down.
    Thanks to those of you who brought this to my attention.
  25. #175
    Sydney Auustralia
    It's excellent advice and well worth doing but as you mentioned "you could see the arm absorbing all the flex" and that's where the problem lies in that the arm finally gives up on all that absorbing and tends to crack and eventually break. So it's worth checking the windscreen arm at least once a month and look for the tel tale signs of any cracking.
    Safe Riding all
