Results 1 to 19 of 19
    Active Member iridenow's Avatar
    Sep 2019
    Phoenix, AZ
    Default I broke the windshield
    I assume something was loose. Then I hit a big bump and that finished it off. It's no longer standing upright. Now it's just leaning back towards me and the button won't raise or lower it. Too late to look at it tonight.
    Fred is a 2010 RT SM5 - Sold.
    I am not a mechanic. When I have a tool in my hand, 911 needs to be on Standby.
    Bossier LoUiSiAna
    Sounds like the flimsy plastic arm that has broken on many others
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Nov 2016
    Upstate NY
    Sounds like. Broken dogbone for sure. Upgraded part is available for this but can be complicated install.
    2021 Sea to Sky RT , Highland green
    Dec 2013
    I'm not sure if Lamonster Garage sells the replacement alloy windscreen arms, but if they don't, you can always send noboot (that's Ron's username here ) a PM. The 'replacement kit' comes with all the necessary wedges & a good set of instructions to fit the new 'unbreakable' arm!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Feb 2012
    Spring City,Utah
    It sounds like your the bar that attaches your windshield is broken. I think Lamonster has one and you can also buy from BRP now with out having to buy the whole system. You can get just the arm. noboot from Australia invented the billet replacement. You can also buy straight from him.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Sep 2014
    USA
    Yep just went thru that myself last October. Dam thing snapped at 70 mph and folded back and down towards me while driving. I got Noboots arm comes with everything needed to install. Just have to take off a few things to get to that arm. He does have a video on how to change it.
    Sep 2019
    Phoenix, AZ
    Thanks all. Is this something somebody who shouldn't play with tools can do?
    Windshield Arm .... From BRP is still the SAME crappy part they used originally ..... so it will break also ..... good luck ... Mike
    Active Member noboot's Avatar
    Sydney Auustralia
    If you PM me I can give you details about my replacement arm
    Sep 2014
    USA
    Do you have someone that can help you? Noboot has a video too to watch.
    I would not go back to the stock arm IMO.
    I note you are driving a 2010 RT. Those first couple years did have some issues with the arms on the windshields breaking. It had something to do with the casting. Have not heard much since 2012 or so about the problem.
    The recommendations for a fix above are all good.
    Sydney Auustralia
    We have supplied to people with 2015,16,17 and 2018 one of my replacement arms due to breakage.
    Dec 2013
    Quote Originally Posted by noboot View Post
    Don't forget my 2013 RT too!! Anyone got a 2014 so we can make it a clean sweep??
    I was just lucky that I noticed the cracking in the OEM lower arm before it fully collapsed.... . But it was probably only hours away from doing so - it literally fell apart in my hands once I got it off the shaft!
    The Billet replacement arm has been doing the job without issue ever since - it's done so for about 3 times as long as the OEM arm so far, and I can't really see it EVER being a problem regardless of how long it does the job! Something to do with it being made from an alloy billet I reckon, instead of being made from the flimsy OEM stuff that's further weakened by carving out all the supporting structure!!
    Dec 2016
    Gold Coast, Australia
    Yep, got 2014RT.
    Replaced my arm a year ago. Wasn't broken but not taking any chances.
    Bit more fiddly as my screen has screws not c-clips. Got it done anyway.
    Cheers and beers
    Frank
    Sep 2014
    USA
    Yep add me to the 2014 rt list
    Dec 2013
    Don't forget my 2013 RT too!! Anyone got a 2014 so we can make it a clean sweep?? ...
    Quote Originally Posted by Fearless View Post
    Yep, got 2014RT. ..... Frank
    So really, with Iridenow's 2010 & the above, all we need is someone who broke/replaced the windscreen arm on a 2011, 2012, 2019, 2020, and a 2021 to show that every year/model RT has this problem..... still..... Despite BRP's continued assertion that 'we haven't seen this on any other Spyder before?!'
    Sydney Auustralia
    we have supplied plenty to 2011 and 2012 but nothing for 19,20 and 21 although they are now Black when fitted by the factory and you can no longer see the crack appearing.
    Apr 2016
    Emmaus, PA
    Mine is a 2012 RT-s SM5... broke that dog bone about 5 years ago. Noboot to the rescue!
    Dec 2016
    Had my 2010RT as well.
