Page 2 of 2 FirstFirst 12
Results 26 to 39 of 39
  1. #26
    Feb 2015
    NB Canada
    im looking at this one so I can have a flush look instead of the lock sticking up so much. and ill just put a bolt for the latch to slide under to secure....
    https://www.amazon.ca/FJM-Security-8...49762RYE7&th=1
    2011 RT Limited , White
  2. #27
    Jun 2012
    Nevada
    Quote Originally Posted by _..stiffler.. View Post
    That should work fine, you might have to put a spring on the door so it pops up to grab it open.
  3. #28
    WARRENTON, VA
    If you decided to do this, it would be great to see pics on how it turned out. I also would like a lock that is flush.
  4. #29
    Kansas
    Why would you want to use a key every time you want to get into the frunk?
  5. #30
    Jun 2012
    Nevada
    Quote Originally Posted by KC61 View Post
    That's very true, with that flush lock you would have to use a key every time you opened and closed it.
  6. #31
    Feb 2015
    NB Canada
    you have to use a key every time you want in the frunk of the spyder. so whats the difference.
    Also on the ryker you have the areas on the side where I can just pull up on the frunk cover. no need to add a spring etc....
  7. #32
    Very Active Member Markubis's Avatar
    Jan 2018
    NH
    I like the option of being able to lock it or not lock it. With that flush mount lock, you will need to lock it every time or else it will be flapping up and down when going over bumps.
  8. #33
    Aug 2019
    CA
    Amazon lock is exactly what I was looking for. I used the video from slingmods and guesstimated. Works perfectly!
  9. #34
    Jan 2018
    NH
    Quote Originally Posted by Bredman View Post
    Same here. I made it 1.5 inches from the edge per someones suggestion here, then mounted the angle bracket on the inverse angled section inside the trunk with the edge of it just touching the transition line between the angled and the vertical wall of the trunk. (if that makes sense) O.o
  10. #35
    Kansas
    Difference is it's a Ryker not a Spyder and has no lock at all. Why not do the best thing so you have an option to lock or not lock.
  11. #36
    Jul 2021
    WV
    Found this while I was searching for some other installation instructions:
    https://instructions.brp.com/content...n&title=CAN-AM ON-ROAD KIT - Glove Box Lock - Ryker MY21 and Up&rel_part_number=219401136
    Wonder what locks and unlocks it...
  12. #37
    Quote Originally Posted by oharman View Post
    It locks/unlocks the little glove box/front storage compartment/frunk on MY21 & up Rykers by opening/closing the fuel filler cover.
  13. #38
    Apr 2020
    New Hampshire
    Looks like it unlocks whenever the USB is getting power since it plugs into the harness right there. I'd rather have something like that instead of having yet another key.
    2019 Rally , BLACK
  14. #39
    Jun 2021
    georgia
    is this part available to be purchased from some where? never mind I found it
    Last edited by crazychrismc; 08-12-2021 at 06:41 AM. Reason: found the place to order it
    2021 rally 900 , black and red
