Results 1 to 25 of 25
    Active Member Fjrwillie's Avatar
    Jul 2015
    Mass
    Default Lazer Adjustment - What exactly are we aligning
    I have meaning to ask this for 3 years and always forget to post the question
    Willie
    The Future is Not Today (Motorcycle Blog) http://nomadwillie.blogspot.com/ IBA 32847
    2015 RT-S
    2015 RT-S , White
    Wheels.
    SoFlo
    Yes wheels...
    Actually, first the belt is aligned if needed. Then the front wheel toe in is set or aligned as it is often called.
    Spyders are pretty primitive in the front suspension / steering design. No adjustments to correct caster or camber angles, only true adjustment is toe in. However, altering front ride height does alter camber slightly, but technically is not adjustable.
    Dec 2009
    West Oz
    Wheels.
    HOLY SMOKE - that's the shortest answer you ever posted. Keep up the good work.
    Yes!
    Jul 2019
    UK
    Quote Originally Posted by Fjrwillie View Post
    Willie
    If you were looking from above your Spyder, the adjustment is how much the front of the wheels angle in or out from being parallel. If they're closer together at the front that is referred to as toe-in and if they're further apart at the front it's referred to as toe-out. Toe-in is considered negative and toe-out is positive. It's often set as a distance, say 3mm toe-in but it can also be given as an angle, say -0.1 degrees. In this example the 3mm refers to the distance between the wheels being 3mm closer together at the front than at the rear of the wheel. The exact point of measurement at the wheel is normally given in the service manual, but not in BRP's case (Why am I not surprised!?) I use the edge of the wheel rim as a datum distance and 3mm toe-in is what I set.
    For info, I use two lasers to set the toe-in, one on each side, rather than move the Spyder, which is prone to serious error, I move the target.
    I hope this was useful to you Fjrwillie.
    Mar 2015
    forrest above Reno, Nv
    Ann and Joe will also center the handlebars if necessary.
    Lew L
    2014 RTS , Circuit Yellow
    May 2018
    Chateauguay, Qc, Canada
    Wheels.
    Less is more. 7 keystrokes less to arrive at perfection.
    Eckhard
    Spyder RT Ltd, 2011
    2011 RT Ltd. , Pearl White
    Default Well...
    As stated above.... you are aligning, rear wheel, the toe in/out along with setting the handlebars to center and re-setting the steering sensor with the buds program. Seems prior systems used the frame as the alignment point but this does not take into consideration the difference in the rear wheel...
    Thinks out loud
    Apr 2012
    We've come a long way from the days when we would sprinkle a little flour on the garage floor, spread it around with a broom, before rolling the front wheels through it to take our measurements from.
    Jun 2010
    Las Vegas
    Quote Originally Posted by Jeriatric View Post
    I think there are still some dealers using that method!
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Thinks out loud
    Apr 2012
    Little doubt. Or at least some antiquated form. But hey, that's not bad for business
    Oct 2014
    Fort Mill, SC
    Are we also aligning the tracking of the rear wheel to the toe in of the front wheels? What I mean is, if the rear wheel must point slightly to to left or right for a proper belt alignment, do the front wheels and handlebar compensate for that?
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    Member: American Legion
    Sep 2014
    Scotland
    Quote Originally Posted by Grandpot View Post
    I don't think that's possible. The bike can be set up to feel correct, bars central etc, but if the rear wheel is not parallel to the frame, the bike will travel slightly sideways though the wheels will be parallel. It's just a function of the design and an out of alignment rear steers the bike, the bars are turned to compensate until the front wheels are parallel with the rear wheel then the bike follows a straight course but is slightly sideways.
    A better design would have the wheels properly aligned and the engine adjusted for correct belt tracking. IMHO, of course.
    Thinks out loud
    Apr 2012
    Quote Originally Posted by Spyderlass View Post
    Excellent point, and it wouldn't be as difficult to engineer as it may sound. imo
    Oct 2014
    Fort Mill, SC
    If the rear wheel was not on centerline and front wheels were aligned straight ahead the handlebars would need to be turned in order to go straight as you said. This would effect the yaw compensation. Oh, this gets deep.
    1998 Honda Valkyrie
    US Navy Veteran
    Thinks out loud
    Apr 2012
    The rider is doing the compensating. Sometimes knowingly - if it's out a lot, and unknowingly if it's just slightly out of align.
    Jul 2019
    UK
    Yes I think that's right and it's probably happening all the time we ride on a cambered road whether the bike is set straight or not.
    May 2018
    That's been gnawing at me for awhile that the angle of the rear wheel wasn't taken into account. Looks like it doesn't need to be. Not can it be it seems.
    Eckhard
    Spyder RT Ltd, 2011
    May 2017
    Perry Hall, Md
    I actually had my lasers aligned. Well, they're really phasers...for those ******* cagers
    2011 RT , Yes Blue
    Quote Originally Posted by Docster View Post
    Phasers would sorta work, but a blinding flash of light & no more cage just wouldn't work for me!! I think I'd rather like to SEE a string of holes get punched into the doors and the resulting twisted metal and broken bits flying off the cages as a burst of 50 Cal slugs hit it & plow on thru everything!!
    It's such a shame that doing that sorta thing would be frowned upon!
    Jul 2019
    australia
    after lazer alignment do you have to put it on bubs for any reason
    Nov 2012
    North Las Vegas, NV
    Quote Originally Posted by flea View Post
    If you mean BUDS, yes to reset the steering sensor.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Jul 2019
    UK
    after lazer alignment do you have to put it on buds for any reason
    Maybe aye maybe no. If the original alignment was central as it should be, then (even though it had toe-in or toe-out) after correct and equal adjustment of the tie-rods on each side the steering sensor will still be correctly aligned. I guess it depends on how much you trust the original set up and how much you trust the person doing the realignment.
    Jun 2010
    Las Vegas
    We put every Spyder on BUDS after we align them. Why would you want to roll the dice and not? Anyone doing alignments should have BUDS.
    2010 RT- 622
