RT won't start or even turn over
Yesterday morning it started just fine. Got off of work and it was dead. Tried to jump it. I got power but when I tried to start it, it just clicked one time and was dead. Today I put a a battery charger on it. Went back a few hours later and no difference. I am leaving the charger on all night and try again tomorrow. I am sure there will be no change. It looks really complicated getting the battery out. Is there anything else I need to look at?
Hi Bob,
Always helps if we know year and model------ but battery connections have caused all kinds of problems in just about all years and models of s.
Best guess..... Battery died. They do that and sometimes very suddenly. Good luck..... Jim
Semper Fi
Originally Posted by Lew L
Hi Bob,
I'm with these guys. Likely culprit is the battery(how old is the current one?), but I'd check both terminals for tightness for peace of mind.
Here's some help on getting to your battery > https://www.youtube.com/watch?v=aCsNYNU6eYo
This is the battery it came with and for the money it can't be beat > Yuasa YTX24HL Factory Activated AGM High Performance Battery
You can shop around but likely won't find it any cheaper and these folks ship free & fast > https://www.revzilla.com/motorcycle/...ce-agm-battery
Keep us posted.
Oh too. I based this post on info in your bio > 2012 Can Am Spyder RT SE5
when they go, they're gone. They kind of give a couple hints first, like lights brightening
as revs increase, or doesn't spin over as smoothly as normal. So if it is a battery, fear not,
it will not be traumatic, and a relative cheap and easy fix
The battery on a 13 or newer us very easy to change. The older years are a bit more challenging but look for a YouTube video to help you.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Sorry ya'll. It is a 12 RT Limited. I just now got it to start on my lunch break....once. After that it was totally dead, no light, radio, nothing. I don't know how it did it but it did. Guess I'll investigate a little more. Thanks
SpyderLovers Ambassador
Battery
Sounds like a new battery might be the trick. The Yuasa oem is a good choice......
ENJOY YOUR TIME ON YOUR SPYDER
Ryde with a Friend and Stay Safe.
Sounds like the battery but there is a large fuse on the positive cable you can check
Battery....
My RS 2012 just had the battery go out. Seems you may have picked up a surface charge but that is it and once you use that it's dead. If you tried to jump it and only got a click connections were not good or source was not good. If it is the original battery it is on the high side of life in a spyder. Regardless of if you can get it charged or working you are best getting on with a new one...
Our 2018 RT suddenly wouldn't start after a ride and when turning the key it just had a clicking sound. We found it was a fuse that had went bad. It was the F5 fuse. don't know why it blew but hasn't happened again.
