Low speed rubbing noise
I have a 2015 F3 SE6. At slow speeds I hear a rubbing noise. It rubs and stops, rubs and stops and continues until I stop. I checked my tire pressure all is ok. I suspected my belt tensioner (idler pulley). Took that off and the problem is still there. The belt looks ok and I don't see any damage. Any ideas? Thank you.
John F.
Tallahassee, FL
2015 Spyder F3 SE6, black
BRP Driver/passenger Footboards
BRP Adjustable Passenger Backrest
Blue Ridge Windshield
MRA X-Creen Tour, clear, clamp-on
H4 LED Headlights
F3 LED Fog Light Kit, LED Amber Halo Ring Kit, LED Tail Lights, F3 Rear run/brake/turn LEDs
Easy Brackets
Leatherworks, Inc. 120 Special Slight Angle Saddlebags
Custom Dynamics Front Mud Flap LED lights, Street Magic Front Fender Tips, Double Feature Lens
2-up rear shock
Idler pulley kit
I have the same issue. My ride is a F3-S SE6.
My bet is the brakes pads rubbing the rotors slightly. With the front wheels being open and setting to the sides you can hear the pads rubbing at slow speeds. Does the noise stop when you apply the brakes lightly? If so than it's the pads. Nothing to worry about as long as they don't rub hard enough to cause the rotor to get hot. This is common with disc brakes and lots of vehicles including your car has this going on, just not as easy to hear it in your car.
I usually push my spyder in the garage when i get home from a ride and can hear a rubbing noise with the engine not running. I always figured that was normal.
2017 F3 Limited
SpyderLovers Sponsor
![](signaturepics/sigpic963_3.gif)
![](https://www.spyderlovers.com/adserver/www/delivery/avw.php?zoneid=13&cb=7845674567)
Are you sure that the belt is not rubbing against the inner flange on the rear sprocket? If you can't tell if its rubbing or not put a little grease on the rear sprocket flange and see if the rubbing noise goes away. I had that happen on a 2015RTS and it was the belt rubbing against the flange on the rear sprocket. If the noise goes away then, the belt tracking needs to be adjusted some.
2008 Triumph Rocket (SOLD)
2002 Honda VTX 1800 C ( SOLD)
![Quote](images/misc/quote_icon.png) Originally Posted by Ex-Rocket
I would not put grease on the pulley or the belt, that’s asking for trouble. Grease attracts dirt & debris, that will ruin your belt & sprockets. Don’t put oil on your brakes either if they are squeaking.
![Quote](images/misc/quote_icon.png) Originally Posted by JS3535
This was actually something BRP recommended on the earlier Spyder. Putting a small dab of synthetic grease on the belt will hurt nothing. It was for a squeaking sound on acceleration.
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
This does sound counter intuitive. But is, in fact, a good practice if done correctly. Not necessary unless your drive belt is squeaking. But be sure the squeak is not due to the belt rubbing on the inner or outer flanges on the pulleys. This needs to be corrected before any additional steps are taken.
![Quote](images/misc/quote_icon.png) Originally Posted by AY4B
It is absolutely "normal" for disc brakes to make a slight "rubbing" noise when turning really slow.
ALL vehicles do it to some degree or another.
You just aren't close enough to the wheels on other vehicles to notice it.
I did say a LITTLE grease.
Customer Support
Same rubbing sound in left front wheel since brakes and rotors were done. Slight burning smell for a minute or two after a ryde which does concern me a bit but brakes are operating normally otherwise.
2015 Pearl White RTL
Baja Ron Sway Bar
Russell Day Long Seat
Strobe Brake Light
![](https://www.spyderlovers.com/forums/maps/map.png?states=AK.NV.CA.OR.WA.MT.HI.ID.WY.CO.UT.AZ.NM.TX.OK.ND.MO.MI.GA.FL.NY.DE.NJ.MD)
Belt dressing is different than grease.
![Quote](images/misc/quote_icon.png) Originally Posted by LeftCoast
It should concern you MORE than a bit.
One of your calipers might be sticking......and the brakes may not operate "normally" for very long.
|Try a little liquid Dish soap on the belt to stop squeak.
I have a rubbing noise at ...ready for this ...6mph not 5 or 7 mph. I took it to the dealer and sure enough they hear and feel it at 6mph only as well. They checked belt tension and gap and both were ok. Reported to BRP and no answers from either dealer or BRP. Its documented in case this leads to something else....very strange.
What year and How many miles? could be a rear wheel bearing getting dry kind of like the sound of a U-joint just starting to go. that rubbing squeaking sound, that comes and goes. mostly heard at low speeds. that's my vote.
LeftCoast, sometimes the pads get canted and bound on the pins they're supposed to "float" on. Those pins do need a light lubing especially if they have some roughness to them.
Safe Rides,
David and Sharon Goebel
Both Retired USAF Veterans
IBA 70020 |
![](https://www.spyderlovers.com/forums/maps/map.png?states=AZ.MN.ND.SD.IA.NE.WI.MI.MO.IL.IN.OH.KY.AR.TN.MS.AL.FL.GA.NC.KS) |
One way to stop the noise is to loosen the axle nut one flat (not turns! )at a time. Just a 3-4 "flats" should do it, and it doesn't loosen the axle enough to be a concern.
![Quote](images/misc/quote_icon.png) Originally Posted by TerryTheSpyderRyder
One way to stop the noise is to loosen the axle nut one flat (not turns! )at a time. Just a 3-4 "flats" should do it, and it doesn't loosen the axle enough to be a concern. ![bowdown](images/smilies/bowdown.gif)
REALLY ??
NOT !!!!!
That has to rank right up there with some of the WORST vehicle advice I have ever seen.
![Quote](images/misc/quote_icon.png) Originally Posted by Navydad
Thanks, I will try that.
John F.
Tallahassee, FL
H4 LED Headlights
Easy Brackets
2-up rear shock
Idler pulley kit
Customer Support
![Quote](images/misc/quote_icon.png) Originally Posted by DGoebel
Thank you for that, I will need to learn how to do it though. At least there was no burning smell after my 120 mile ride home.
Baja Ron Sway Bar
Strobe Brake Light
