Results 1 to 23 of 23
    Active Member deer30084's Avatar
    Tallahassee, FL
    Default Low speed rubbing noise
    I have a 2015 F3 SE6. At slow speeds I hear a rubbing noise. It rubs and stops, rubs and stops and continues until I stop. I checked my tire pressure all is ok. I suspected my belt tensioner (idler pulley). Took that off and the problem is still there. The belt looks ok and I don't see any damage. Any ideas? Thank you.
    John F.
    Tallahassee, FL
    2015 Spyder F3 SE6, black
    BRP Driver/passenger Footboards
    BRP Adjustable Passenger Backrest
    Blue Ridge Windshield
    MRA X-Creen Tour, clear, clamp-on
    H4 LED Headlights
    F3 LED Fog Light Kit, LED Amber Halo Ring Kit, LED Tail Lights, F3 Rear run/brake/turn LEDs
    Easy Brackets
    Leatherworks, Inc. 120 Special Slight Angle Saddlebags
    Custom Dynamics Front Mud Flap LED lights, Street Magic Front Fender Tips, Double Feature Lens
    2-up rear shock
    Idler pulley kit
    NOVA
    I have the same issue. My ride is a F3-S SE6.
    2015 F3 , Gray/Black/Orange
    Sep 2016
    Chillicothe, Oh.
    My bet is the brakes pads rubbing the rotors slightly. With the front wheels being open and setting to the sides you can hear the pads rubbing at slow speeds. Does the noise stop when you apply the brakes lightly? If so than it's the pads. Nothing to worry about as long as they don't rub hard enough to cause the rotor to get hot. This is common with disc brakes and lots of vehicles including your car has this going on, just not as easy to hear it in your car.
    2015 RT , Black
    Greenville Tx
    I usually push my spyder in the garage when i get home from a ride and can hear a rubbing noise with the engine not running. I always figured that was normal.
    2017 F3 Limited
    Though I would check into it further to be sure. Another option is to raise the front of the Spyder and spin the wheels by hand to replicate the condition. Then you'll know for sure.
    Mar 2013
    Marion, Arkansas
    Are you sure that the belt is not rubbing against the inner flange on the rear sprocket? If you can't tell if its rubbing or not put a little grease on the rear sprocket flange and see if the rubbing noise goes away. I had that happen on a 2015RTS and it was the belt rubbing against the flange on the rear sprocket. If the noise goes away then, the belt tracking needs to be adjusted some.
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    western Colorado
    +1 for brake pads!!
    Clovis, CA
    Quote Originally Posted by Ex-Rocket View Post
    I would not put grease on the pulley or the belt, that’s asking for trouble. Grease attracts dirt & debris, that will ruin your belt & sprockets. Don’t put oil on your brakes either if they are squeaking.
    2015 F3S-T , Black Black & Black
    Nov 2012
    North Las Vegas, NV
    Quote Originally Posted by JS3535 View Post
    This was actually something BRP recommended on the earlier Spyder. Putting a small dab of synthetic grease on the belt will hurt nothing. It was for a squeaking sound on acceleration.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    This does sound counter intuitive. But is, in fact, a good practice if done correctly. Not necessary unless your drive belt is squeaking. But be sure the squeak is not due to the belt rubbing on the inner or outer flanges on the pulleys. This needs to be corrected before any additional steps are taken.
    Apr 2017
    North Central Florida
    Quote Originally Posted by AY4B View Post
    It is absolutely "normal" for disc brakes to make a slight "rubbing" noise when turning really slow.
    ALL vehicles do it to some degree or another.
    You just aren't close enough to the wheels on other vehicles to notice it.
    Mar 2013
    Marion, Arkansas
    I did say a LITTLE grease.
    Nov 2017
    San Francisco Bay area
    Same rubbing sound in left front wheel since brakes and rotors were done. Slight burning smell for a minute or two after a ryde which does concern me a bit but brakes are operating normally otherwise.
    2015 Pearl White RTL
    Baja Ron Sway Bar
    Russell Day Long Seat
    Strobe Brake Light
    2015 RTL , Yes Pearl White
    Clovis, CA
    Belt dressing is different than grease.
    Apr 2017
    Quote Originally Posted by LeftCoast View Post
    It should concern you MORE than a bit.
    One of your calipers might be sticking......and the brakes may not operate "normally" for very long.
    Active Member wingit3611's Avatar
    Dec 2016
    Louisville, KY 40214
    |Try a little liquid Dish soap on the belt to stop squeak.
    Can Am 2013 RTL SE5
    May 2012
    Southern California (Oceanside)
    I have a rubbing noise at ...ready for this ...6mph not 5 or 7 mph. I took it to the dealer and sure enough they hear and feel it at 6mph only as well. They checked belt tension and gap and both were ok. Reported to BRP and no answers from either dealer or BRP. Its documented in case this leads to something else....very strange.
    May 2017
    Douglas Wyoming
    What year and How many miles? could be a rear wheel bearing getting dry kind of like the sound of a U-joint just starting to go. that rubbing squeaking sound, that comes and goes. mostly heard at low speeds. that's my vote.
    2016 F3 Limited , Crimson RED
    Faribault, MN
    LeftCoast, sometimes the pads get canted and bound on the pins they're supposed to "float" on. Those pins do need a light lubing especially if they have some roughness to them.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Mar 2015
    Tacoma WA.
    One way to stop the noise is to loosen the axle nut one flat (not turns! )at a time. Just a 3-4 "flats" should do it, and it doesn't loosen the axle enough to be a concern.
    2017 F3-S Daytona , Yellow and black
    Apr 2017
    Quote Originally Posted by TerryTheSpyderRyder View Post
    REALLY ??
    NOT !!!!!
    That has to rank right up there with some of the WORST vehicle advice I have ever seen.
    Tallahassee, FL
    Thanks, I will try that.
    John F.
    Tallahassee, FL
    H4 LED Headlights
    Easy Brackets
    2-up rear shock
    Idler pulley kit
    Nov 2017
    Thank you for that, I will need to learn how to do it though. At least there was no burning smell after my 120 mile ride home.
    Baja Ron Sway Bar
    Strobe Brake Light
