Results 1 to 20 of 20
Thread: Maps
    Mar 2018
    Ontario ,way up north
    Default Maps
    The wife and i are going for a trip east this June .I have not used map quest or google maps for some time .What the h@ll happened it has all changed ,you need to log on to chrome ( which i already use ) and use free map apps .In the fine print it says it will change a whole bunch of stuff that i do not feel comfortable doing .
    Have you used on line maps lately ,do you feel comfortable to use these maps .
    2018 RTL , dark blue
    I used to use Map Quest .... But I like Google maps better ...... haven't ever had an issue ....except sometimes it's slow .... Mike
    Jan 2015
    southern WI
    IF you're just looking for maps, Google Maps is great. If you want to create a route to load onto a GPS, take a peek at the MyRoute App. Very easy and free. Just plot the points to create the route you wanna travel, then connect and upload to your Garmin or TomTom
    2016 RTS , Pearl White
    Mar 2018
    Please Install the new free Map Finder for Google ChromeŽ
    to get your maps and driving directions.You're almost done!
    Click "Add to Chrome" to complete the installation.
    it can
    read and change all your data on the web sites you visit
    replace the page you see when opening a new tab
    manage your app extensions and themes
    Does not sound to safe to me ....
    Jul 2011
    Mitchell, Ontario, Canada
    Quote Originally Posted by stmike 1800 View Post
    it can
    STOP STOP STOP and one more for good luck STOP.
    I don't think you are installing a google maps into chrome. Sounds more like a adware trojan.
    Are you sure you are in google maps. Look at the address bar. It should look something like this. https://www.google.com/maps/
    Feb 2015
    NB Canada
    Actually I just started playing with the app Rever. It's a motorcyclist app and lets you make routes on the computer etc and also works with brp connect and your gauge. Maybe take a look at that and see how it is.
    2011 RT Limited , White
    Dec 2014
    S.E. Michigan
    Also take a look at "Waze". Been using it when I can't find my GPS.
    ~Sandee~
    ~Sandee~
    2016 RT-L (Purchased used in February 2018)
    RT Dash Mount (from JT's Spyder Store)
    Kuryakin Trident Highway Pegs
    Hopnel Pouch
    Magic Mirrors
    Spyderpops Foam Handgrips
    Iron Butt #35273
    Girls on Spyders #2779
    Mar 2018
    I clicked on your version and it works perfect .How do i move the routed map to my zumo 550 ?
    Thanks Mike
    Mar 2018
    When i enter google maps ,it goes to Maps Now.billybovine yours works and does not go to Maps Now .It does seem it is some add trying to screw around with my putor.
    Jul 2011
    I don't know how to move to Zumo sorry. Someone else should be able to help.
    To fix Chrome. Click on menu. 3 vertical dot top right. Choose "settings". Scroll down and click on "advanced". Scroll down and choose "restore settings to their original defaults". Warning all your changes to chrome will be gone. So will your auto login to sites like Spyderlovers.
    Nov 2018
    Des Moines IA
    Quote Originally Posted by _..stiffler.. View Post
    Rever is just OK. It is good for tracking where you have been but navigation to a location is pretty lame. Also, if I am going to pay a monthly fee to get the usable app, I would just buy Genius Maps. It isn't perfect, but it works better than the cellular based apps in areas where service is an issue. Ran into that in Virginia within 40 mile of Richmond last summer. Talk about feeling helpless. I needed a paper map.
    2018 Spyder ST Limited , Asphalt Gray
    Mar 2019
    Belgium
    Can you also import GPX files directly on Rever ? Doesn't seem to work with Sygic or Genius Map...
    Nov 2018
    St Pete Beach
    Quote Originally Posted by F3LTDBelgium View Post
    Not sure on Genius, but you can import a route into Sygic. You can either use their mapping program (https://www.sygic.com/blog/2018/web-...n-smarter-ways) and send a mail to yourself, or create a GPX and use ITN Converter to convert the file to a sygic format. Both work well. If using ITN Converter, set Sygic to use a web based server (e.g. Dropbox) and it is super easy.
    I've found that using Honda Trip Planner is a pretty easy way to create a GPX file, although allot of options as discussed above.
    2018 RT , Asphalt Grey
    Dec 2015
    Oakley Utah
    I use Google maps. I don't have a problem with giving up some personal info, as part of a community effort to expand the functionality of online mapping.
    2014 RTL Platinum
    Mar 2018
    I do not have a smart enough or new enough phone to use brp connect .
    Nov 2018
    Des Moines IA
    The 80's called and they want their phone back.
    May 2012
    Southern California (Oceanside)
    I have been using a Iphone 3 with BRP connect/Genius....works ok.
    Mar 2018
    I had to work with garmin yesterday to get my GPS and base camp maps working . All is good now ,i can load maps to my gps .I had work done on my computer last summer and never use base camp for highway maps till now .Garmin found my maps loaded to the wrong driver ,it was in f instead of c .
    Active Member ChicoFowler's Avatar
    Omaha, NE
    You need to convert the Google GPS to GPX. Try https://mapstogpx.com/ it's free and it works. Once the file is converted you can easily import to the Garmin via computer cable. Easy, peasy
    Feb 2015
    NB Canada
    Rever does GPX import and export. Or senic app (iPhone only for senic)
    I have genius mps as well.
    I think I have about 15 different apps lol.
