Results 1 to 12 of 12
Thread: clock
    Aug 2015
    Michigan
    Default clock
    just got a new leftover 2018 rt limited. is there a way to set the clock on 20.8 update to 12 hour time verses 24hr?
    Florida Swamp
    Quote Originally Posted by pjlcdl View Post
    Should be able to set it manually and change between 12 and 24 in the settings. Click through settings until you get to 'clock', press and hold. I just set mine.
    2019 F3-S , Black & Silver
    As mentioned above. It is as easy as going through the settings. When you get to 12/24 hour....just click on the 12 section.
    Mar 2015
    forrest above Reno, Nv
    You guys can see the clock???? I added a dash rack and have ananalog clock on it. Easy to see.
    2014 RTS , Circuit Yellow
    Bryant, Arkansas
    Quote Originally Posted by Lew L View Post
    Clock is visible and works on 2018 & above
    Cruzr Joe
    Apr 2015
    Tucson, AZ USA
    I have a 15 RTL. My clock runs fast. I'll gain some number of minutes over a week or so. Do you have this? Is there a setting in BUDS or other way to get it more accurate?
    Rob
    Florida Swamp
    Yeah, I can see the clock. The numbers are small, but I can still see them most of the time. If the sun is glaring on the screen I can't see much on it, but soon as the road curves it is visible again.
    I am retired anyway...... the only reason I need to see a clock is to know when it is time to eat.
    Sep 2016
    Chillicothe, Oh.
    Quote Originally Posted by robhowen View Post
    Rob
    Same issue on my 2015, but retired so don't care I have the base RT and put a voltmeter in the right gauge pocket and I may add a decent clock to the left some day.
    2015 RT , Black
    Very Active Member SpyderConvert's Avatar
    Catonsville, MD
    I got tired of resetting the clock on my '15 RTL, so I bought a $20 Casio "diver's watch" at Walmart. It sits nicely on the right side of the handle bar and keeps great time.
    2015 RTL, BajaRon Swaybar, LaMonster LED Headlights and Foglights, LaMonster Spydercuff, LaMonster LED mirror wrap, Magic Mirrors, HMT Brake Light
    2015 RT Ltd. , $" extension Black
    Aug 2015
    Michigan
    Thanks Gwolf holding changed it but no 12 hour was present. Dealer tried setting it before I left but could not get anything but 24 hour format.
    Active Member brerrabbit's Avatar
    Jan 2015
    Colorado
    When you make changes to the clock settings you have to verify the changes by hitting the check mark moving the 'mouse' button to the right. The check mark will blink and settings will be saved. Hope this helps. The check mark will show up as you move the highlight to the minutes. The check mark doesn't show in the picture but it is in the white dot on the right.
    =bob=
    2018 RTL--------------------------------2018 RTL
    Champagne Metallic-------------------Oxford Blue
    Lamonster Pegs------------------------Lamonster Pegs
    Motorcycle Dave Gel seat inserts----Motorcycle Dave Gel seat inserts
    Big Bike Parts Backrests--------------Big Bike Parts Backrests
    Magic Mirror mounts------------------Magic Mirror mounts
    Tri-Axis Handlebar---------------------Tri-Axis Handlebar
    KurYakyn Grips-------------------------Foam Grips
    2018 Limited , Champagne Metallic
    Nov 2018
    Claremore, Ok.
    Quote Originally Posted by Gwolf View Post
    I'm retired also, and the only thing on the dash I need to see is the gas gauge and speedometer.
