clock
just got a new leftover 2018 rt limited. is there a way to set the clock on 20.8 update to 12 hour time verses 24hr?
Should be able to set it manually and change between 12 and 24 in the settings. Click through settings until you get to 'clock', press and hold. I just set mine.
You guys can see the clock???? I added a dash rack and have ananalog clock on it. Easy to see.
Clock is visible and works on 2018 & above
Cruzr Joe
I have a 15 RTL. My clock runs fast. I'll gain some number of minutes over a week or so. Do you have this? Is there a setting in BUDS or other way to get it more accurate?
Rob
Yeah, I can see the clock. The numbers are small, but I can still see them most of the time. If the sun is glaring on the screen I can't see much on it, but soon as the road curves it is visible again.
I am retired anyway...... the only reason I need to see a clock is to know when it is time to eat.
Rob
Same issue on my 2015, but retired so don't care I have the base RT and put a voltmeter in the right gauge pocket and I may add a decent clock to the left some day.
I got tired of resetting the clock on my '15 RTL, so I bought a $20 Casio "diver's watch" at Walmart. It sits nicely on the right side of the handle bar and keeps great time.
2015 RTL, BajaRon Swaybar, LaMonster LED Headlights and Foglights, LaMonster Spydercuff, LaMonster LED mirror wrap, Magic Mirrors, HMT Brake Light
Thanks Gwolf holding changed it but no 12 hour was present. Dealer tried setting it before I left but could not get anything but 24 hour format.
When you make changes to the clock settings you have to verify the changes by hitting the check mark moving the 'mouse' button to the right. The check mark will blink and settings will be saved. Hope this helps. The check mark will show up as you move the highlight to the minutes. The check mark doesn't show in the picture but it is in the white dot on the right.
=bob=
2018 RTL--------------------------------2018 RTL
Champagne Metallic-------------------Oxford Blue
Lamonster Pegs------------------------Lamonster Pegs
Motorcycle Dave Gel seat inserts----Motorcycle Dave Gel seat inserts
Big Bike Parts Backrests--------------Big Bike Parts Backrests
Magic Mirror mounts------------------Magic Mirror mounts
Tri-Axis Handlebar---------------------Tri-Axis Handlebar
KurYakyn Grips-------------------------Foam Grips
I'm retired also, and the only thing on the dash I need to see is the gas gauge and speedometer.
