Ouch! I hate when that happens....
I have ridden out to Julian and beyond several times when I had my Monster or Thruxton down there with me, when visiting the fam in Canyon Lake. Do you go on thru Julian and run the 78 out to Ocatillo Wells? That road is simply amazing. Not sure if I ever ended up on Sunrise Hwy (S1)....
![](signaturepics/sigpic22819_2.gif)
Chuck
![Quote](images/misc/quote_icon.png) Originally Posted by hypurone
That we have all the way to the Salton Sea. Sunrise runs into 79 about 6miles out of Julian. Most times on the short run we will just take the 78 back thru Ramona. All great roads the 76.78.79, 0ld 80 Old 94 just to mention a few. Great place to ryde....
Your troubles go back to some inconsiderate jerk messing with your ryde. Haven't had any big problems other than a "friend" dragging my RT-S out of Ir's parking spot at work not knowing about the parking break. I made the mistake of leaving the key in it when I ran into the office. Would not have helped the parking brake if he managed to take off on it. What is it that makes people think they have the right to do such things? I have more respect for another person's property than they do, I guess.
Coke
Did the Julian circle trip on the Yuma Ryde-In a couple of months ago. Beautiful road trip. Glad everything eventually worked out for you. Too bad some people have to look with their hands..... Jim
Semper Fi
![](https://www.spyderlovers.com/forums/maps/map.png?states=WA.ID.MT.WY.CO.UT.TX.NM.AZ.NV.CA.OR.OK)
![Quote](images/misc/quote_icon.png) Originally Posted by BLUEKNIGHT911
Always hit the kill switch when parked as an extra precaution but it does not help with the electrics. Just need to switch to an after ignition power source....
You might want to consider rewiring those lights so that they do not go on without the ignition on. For accessories, I'm going to get a fuse block that is energized only with the ignition on.
![Quote](images/misc/quote_icon.png) Originally Posted by Chupaca
On my 2015 RTS in the right side fuse box F6 is switch powered, F7 is always on for the accessory plugs. Changing the fuse position, not in both.
Interesting thanks for this info …… Mike
