Results 1 to 21 of 21
    Feb 2018
    SC
    Default Time for tires and alignment
    So in Seneca SC which about 30 mins from me they do laser alignment. Said it will cost me $210. Also $89 to run the diagnostic on why it says brake failure. I said it’s because the brake fluid was low but I added more. Anyways. Since my rear tire is bald in middle and the front tires have now gone bald on the inside it’s time for a alignment. What sucks is the rest of the tire have a lot of tread left. Does it matter really does the rear tire name brand don’t match the front? I was on tire rack . Com and found a rear tire I was thinking of. Oh the dealership said it’s a 3 week wait before they would get to it. Which is fine by me because I just delivered my baby a month early so been busy going to and from the hospital. Anyways. Thinking about changing the tires myself and then driving my 09 SE5 to the dealership for the alignment. Here is the rear tire I was thinking about.
    Specifications
    KUMHO
    ECSTA AST
    • Size: 225/50R15
    • Service Description:91H
    • Load Range: SL
    • UTQG: 400 A A
    • Max Load: 1,356 lbs
    • Max Inflation Pressure:51 psi
    • Tread Depth:10/32"
    • Tire Weight: 21 lbs
    • Rim Width Range:6-8"
    • Measured Rim Width:7"
    • Section Width:9.2"
    • Tread Width:NA
    • Overall Diameter:
    Active Member Boilermaker's Avatar
    Sep 2015
    Muncie, Indiana
    $210 sounds way high for a laser alignment. My local dealer quoted $120 and I have heard of some as low as $100.
    Feb 2018
    SC
    Just not all sure who does a laser alignment in SC
    Oct 2011
    Kalamazoo, Mi
    Quote Originally Posted by Stridersr7 View Post
    Specifications
    KUMHO
    ECSTA AST
    • Size: 225/50R15
    • Load Range: SL
    • UTQG: 400 A A
    • Tread Width:NA
    • Overall Diameter:
    I agree that This is too high a price for a laser alignment. Have had two of the Khumo's on the rear, Good tire, fair mileage ~ 16000 miles. Need to keep the inflation pressures below 20 psi for optimal wet weather performance.
    Al in Kazoo
    2018 F3-T
    2018 F3-T , Pearl White
    Sep 2015
    Muncie, Indiana
    I posted this information in your previous thread.
    These are the recommended Spyder ROLO laser alignment dealers in South Carolina. You can check North Carolina or Georgia if you are close to the borders of either of those states.
    SOUTH CAROLINA DEALERS
    Velocity Powersports
    Landson,SC. 843-871-5371 (ask for Byron)
    Performance Powersports
    Seneca, SC. 864-888-8123 (ask for Kevin)
    Redline Powersports
    Myrtle Beach SC 843-236-0758 (ask for Todd)
    Rock Hill Powersports
    Rock Hill SC 803-324-8800 (ask for Vinny)
    Feb 2018
    SC
    Right. I called Seneca like you posted. It’s $210 and Kevin doesn’t work there anymore so you can change that
    Quote Originally Posted by Boilermaker View Post
    Redline Powersports
    Jun 2010
    Las Vegas
    Where were you in August? We, Squared Away, were in SC at the Road Warriors Rally aligning Spyders. We charge $130, and we donated $10 from every alignment to the Road Warriors Foundation
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Sep 2015
    Muncie, Indiana
    This information is from the ROLO laser alignment website, so I don't update it. www.spydercomfort.com/dealers.htm
    Not knowing where you are in S.C., you could check other dealers in S.C. or dealers in Georgia or North Carolina that may be within reasonable driving distance. If not, paying $210 may be your cheapest option. I would just make sure to tell them other dealers are charging half of what they are. Maybe they will negotiate some to get your business. It's always worth a try.
    Feb 2018
    SC
    Dammit. Lol
    Feb 2018
    SC
    So looks like maybe this for the front. And this Michelin for the rear? Or this KUHMO
    KUMHOECSTA AST
    High Performance All-Season
    • Size: 225/50R15 91H
    • UTQG: 400 A A
    Per Tire:
    $100.02
    Availability: In Stock
    Get it tomorrow, 10/19
    Free Shipping
    Navigation
    QUATRAC 5 - SIZE: 165/65R14
    Feb 2018
    SC
    So I called the one in Asheville NC. They transferred me to a Subaru dealership and then they said they couldn’t do it. WTH
    Redline Powersports
    Sep 2015
    Muncie, Indiana
    Sorry about that; just trying to help. Cannot testify to the accuracy of the information on the ROLO website and have never tried using it since I know of a relatively local dealer in central Indiana that does it for $120. I hope you are able to find someone halfway close to you. Otherwise, you may be stuck paying the $210 fee in Seneca. I would at least try to negotiate with them since nationwide dealers do it for much less. Good luck!
    Feb 2018
    SC
    My friend who does alignment on his vehicles is coming over to look at it
    Dec 2015
    Oakley Utah
    I think she was having a baby?
    2014 RTL Platinum
    Active Member RudyB's Avatar
    May 2016
    Abbotsford British Columbia Canada
    Default Re Alignment
    Dammit. Lol
    If you can't get Squared Away to do your Alignment I would be cautious just because a dealer does Alignments doesn't necessarily mean they know what they are doing also to check brake light on probably means one of two things low brake fluid caused by worn down brake pads
    Feb 2018
    SC
    Pads looked great. Fluid was a little low. Topped it off. Be nice if warning would go off on its on. But nope. Got to pay $89 for them to reset it
    Quote Originally Posted by RudyB View Post
    May 2016
    Sorry I have to say this I have had my brake light come on 3or 4 times just added fluid never needed a reset l believe you got ripped off look for another dealer
    Feb 2018
    SC
    I haven’t took to a dealer yet. That’s what they said they would charge me.
    Feb 2018
    SC
    Well the new spyder tires I got PSI is higher then the Kenda
    SoFlo
    So take your accurate air pressure gauge and let some air out until they are the pressure you want.
    May 2016
    Default Re tire pressure
    I am assuming you put car tires on your bike on front what are running for tire pressure thanks
