Results 1 to 21 of 21
Thread: Air Compressor
    Jun 2018
    Alabama
    Default Air Compressor
    I know my air is not working so I aired it up manually it want hold air long is this normal and what’s the best entry to take old compressor off and change
    Oct 2014
    Fort Mill, SC
    Doc Humphries likes to get at it from the bottom by removing the rear wheel.
    I like to go in from the top by removing the rear storage compartment module. I puts less strain on my body.
    Go to YouTube and search for Can Am Spyder compressor and you will find both of our videos.
    It's like the difference between taking out a hemorrhoid or a tonsil.
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    Member: American Legion
    Faribault, MN
    Chuppy, I did it removing the entire rear section, followed the video, there is more in the threads
    Only 8 months after replacement, ACS failed again
    and ACS Rebuild and Rear shock, airbag etc
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Mar 2008
    Hesston, PA
    Default Options
    Quote Originally Posted by Chuppy View Post
    If you unplug the air ride dump valve you can manually air it up and the air should stay in unless you have a BAD leak...Do a site search and you should find some pictures and directions to unplug it...This will get you by until you get the compressor replaced...
    Mine has failed twice and I put a quick unplug connection under the seat so I can just air it up manually and ride it home while out riding double...If you ride single you should be able to ride it without any air in the bag...larryd
    Jan 2017
    ohio
    Default air compressor
    This is happening to us too. Had the bike 3 years and it started happening. After putting air in it for years we thought we should have it looked at. Pretty pricey I must say. It seems we are all having issues and they should do something!
    Oct 2014
    Fort Mill, SC
    If you are willing to try, it's not that hard a job. You'll save a pile of dough. Search YouTube for Can Am Compressor videos.
    1998 Honda Valkyrie
    US Navy Veteran
    Apr 2018
    Russell, MA
    Angry Self Adjusting Passenger Shock Compressor Failure
    Looks like I have joined the failed compressor club.
    Stopped into my dealer today.
    They plugged in and attempted to inflate/deflate with no luck.
    Funny thing is no faults detected in past history but I know I saw shock failure fault.
    My 2017 F3 Limited has only 4,000 miles.
    Watch it be warranty part and $500 in labor.
    Active Member kamper's Avatar
    Apr 2016
    Elkton South Dakota
    Easy to do and get the aftermarket compressor online save big and works great
    May 2013
    Stanton, ca
    The stock pump is cheap.... Get this one and it will last a lot longer.
    And by the way... One of the biggest reasons the pump goes out fast, you have a leak so it is always cycling.
    Jan 2019
    Western PA
    Just installed the VIAIR compressor purchased from Amazon. Required moving the brake fluid reservoir a bit via spacers, but generally fit pretty well.
    2022 RT-L , Silver
    Oct 2014
    Fort Mill, SC
    Good job.
    1998 Honda Valkyrie
    US Navy Veteran
    Active Member RudyB's Avatar
    May 2016
    Abbotsford British Columbia Canada
    How do you get at the air ride dump valve to disconnect it waiting for compressor replacement thanks
    Jul 2010
    Las Vegas, NV
    Rudy,
    Just remove the right bits: mirror, upper, middle, side and lower panel, and wind deflector. Follow the line from the Schrader valve under the seat to the valve. Disconnect. Then follow the line from the airbag to the compressor. Disconnect at the compressor. Then connect the lines and you end up with a direct line from the Schrader valve to the airbag. All the parts to do this are already on the bike. Air up the bag, measure from the rear fender to the ground. Go ride. Measure again tomorrow. If it has not dropped, bag ok. We did a lady months ago, and hers is still holding air. Lots of Spyder's don’t have compressors. Check it weekly, and air it manually. Best part? No cost! You can buy a compressor for $50 or less that plugs into your battery tender, carry that with you, and be fine. If you need help, call. Easy job. Joe
    Joe Meyer
    Active Member Big Juice's Avatar
    Jul 2017
    Hot Springs Village, AR
    Yep, mine quit working about a month ago, but the pump seams to still work, but the bag won't hold air, so hope to take it in next week to see what's going on........oh, and I'm out of warranty by one month when it happened, no they won't back date it, but have an extended warranty that will hopefully cover it......I may even consider an 2up shock, have heard good things about it.
    O. J.
    Ridin' "Lucille", the MusicMaker
    a 2017 F3 Limited (Pure Magnesium Metallic)
    Wife, Jan, riding "Ruby Jane"
    a 2016 F3-T (Intense Red Pearl)
    2017 F3-Limited , Magnesium (light grey)
    May 2016
    Thanks Joe still have extended BRP warranty going to shop in the morning hopefully they will fix everything Thanks again
    Quote Originally Posted by Big Juice View Post
    IMHO - the Air bag and the shock spring don't really accomplish the same thing ….. The two-up shock can't re-place a functioning Air bag ….. good luck .… Mike
    May 2016
    Thanks Joe all is good new compressor and air bag
    Sep 2022
    TX
    Wink
    2011 Can Am Spyder RTS - SE5
    Since the air compressor seems to fail normally from BRP and there is a replacement suggested - VIAIR 097C (Part # 00097 from 12 Vac), you would think Spyder would want or suggest as an alternative to their failed product. I understand that modifications are needed to brake line to clear the VIAR unit, which requires bleed brakes?
    Question - does anyone know the process of checking support equipment that may have failed - when it is not the compressor? I.E. Fuse; air compressor limit switch; check valve; etc. before taking down everything?
    There must be a simple check method as a process of elimination as to the real cause of the failure to not air up? If there is an answer - need to determine how to retrieve this from the forum (directly or indirectly) once answered without searching and searching the posting????? And I don't know whether it can be sent directly to us once posted... HELP!
    Last edited by Peter Aawen; 10-18-2022 at 04:49 PM. Reason: Removed multi 'requires to view' demands & the 'post title' that many don't even see (info should be in sig line! ;-) )
    Sep 2015
    Chilliwack, BC. Canada
    Quote Originally Posted by hensmanj4220 View Post
    -= Hidden Content =-
    Sorry, but I will NOT be held hostage. You are now on ny IGNORE list.
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
    Harrington, Australia
    Quote Originally Posted by bigbadbrucie View Post
    Looks like we might have a troll in our midst, Brucie …..
    HeliBars Handlebars
    Kenda Kanine rear.
    It's not necessarily a troll Pete; & BBB, it could've been an inadvertent mistake, or an unknowing tick of the 'Requires Thanks & Likes' boxes to see the post by either hensman OR by maybe by RudyB (cos those triggers carry forward until removed! ) .... altho those demands plus the demand from a new member (with no posting history to enable people to judge their veracity) for others to use an untested email address to reply rather than replying here DOES make it a little more suspect!!
    But we all really should give new members &/or posters the benefit of the doubt! So if you see a questionable post (like hensmanj's was before the editing that removed those demands ) then rather than responding at all let alone as requested & so risking spam/scam/worse issues; or replying harshly &/or arbitrarily blocking them from your view, just Report the post so a Mod can check it all out
