Results 1 to 11 of 11
Thread: Oil filters
    Apr 2015
    Titusville, Fl USA
    Default Oil filters
    Are the oil filters on the rs sm5 the same.... I have a 2015 RS sm5 and I'm having trouble finding a oil filter for it
    Default oil filters
    Quote Originally Posted by foolish View Post
    Go to Home Page ....find BAJARON in the Vendors ...... He sells them plus other great stuff at all good prices ..................Mike
    Houston
    I agree with Mike. But, to answer the original question, Yes all Spyders with manual transmission V-twins use the same engine oil filter.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Nov 2012
    North Las Vegas, NV
    http://www.spyderlovers.com/forums/s...rs-amp-Helmets
    http://www.lamonstergarage.com/oil-change-kit-3/
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Default All of the above....
    You can also go to ebay or amazon and buy oil change kits that come with all you need. They are EXP oil that BRP uses in their Rotax engines and have used it in my RS Sm5 since I got it back in 2012. Only the Se5 has two filters and they are not the same size. If shopping get the engine filter only
    Jul 2011
    Mitchell, Ontario, Canada
    Just add to this. All Spyders with the V-twin engines take the same engine oil filter. Does not matter if it is manual or semi-auto. But if you buy the oil change kit. The kit for a semi-auto will have an extra filter you do not need.
    Apr 2015
    Titusville, Fl USA
    Thanks for the info... Spyder Ryder's are awesome
    Mar 2015
    United States
    Angry Stripped transmission cover bolt!
    So I decided to do the oil change myself. Everything was going great until I was replacing the last bolt. The bottom bolt on the transmission filter. Turns out that the threads had previously been stripped and repaired with what appears to be a heli-coil.
    Really could use some repair options and it would be great if someone knows the size of the bolt.
    Thanks!
    Jul 2011
    Quote Originally Posted by Heinerken View Post
    Thanks!
    Sorry to hear about your issue. May I suggest that you start your own thread and not hijack someone else's. Start your your thread in one of the forums that you think closly matches your question. I would suggest Spyder Shop Talk. Asking a question like yours in the 4 sale forum is not going to receive as many good quality answers as your question deserves.
    If I was having your problem I would remove the HCM cover. Install a new helicoil and reassemble.
    PS I will assume that you are asking about a SE5 model. But it is good practice to always tell us what year, model and trans type when asking questions.
    Some pictures may be of some help as well.
    Mar 2015
    United States
    Default Thanks
    Sorry I thought I was in an oil filter section!
    Thanks!
    Not to encourage hijacking a thread. But this can be a serious and not so uncommon problem which is easily avoided with just a bit of care.
    First, the bolts holding the filter caps are very small and threaded into very soft metal (aluminum).
    Second, the O-Ring does all the work. All it needs is a moderate amount of EVEN pressure all the way around to seal.
    Third, to get this even pressure you need to turn each bolt in a few turns and then do the same with the other bolt.
    Some turn one bolt all the way in and then attempt to tighten the other bolt to match. This is a very bad way to install the filter cap. At the very least you risk pinching the O-Ring doing it this way (which will leak volumes of oil when you start your Spyder). At worst you will strip the threads out of the 2nd bolt trying to get it to the same point as the 1st bolt.
    Use a short handled wrench so you don't get these bolts too tight. They just need to be snug. I've never heard of a oil filter cap coming loose. (Other than stripped bolt issues)
    Get even pressure and go easy on the torque and you'll never have a problem.
Tags for this Thread
