Results 1 to 25 of 37
    Active Member bscofield84's Avatar
    Aitkin Minnesota
    Default Garage door opener.
    20180424_162604.jpgTook a suggestions of putting in the pull down instruction card location. Didn't have to modify anything on the bike. Thanks for the suggestions. Just wanted to add a photo.
    Looking for some suggestions for adding a garage door opener to my Spyder - 2014 STSE5LMT.
    On my Honda, I just have it strapped to the handle bar, but really don't find a good spot to put one on the Spyder.
    If I strap it to the handle bars, it is kinda in the way of the Garmin mount.
    Thought about putting it in one of the blank spaces for the toggles - wiring in the button, but I'm not good understanding wiring.
    Wondering what anyone else has done. Thanks for the input.
    2014 ST SE5 LT , Black Current
    Nov 2013
    Vero beach ,florida
    Default garage door opener location
    I have mine inside top box against the bottom. I can push button easily after opening lid
    Member jmatera's Avatar
    Mar 2017
    Pawling NY
    Default Key Chain Remote
    I purchased a smaller remote that worked with my garage door. My jacket has a small pocket on my left upper arm (don't know what it is really for) that is the perfect size for the smaller remote. I put a small piece of velcro (the hook part) on the back of the remote to hold it in that pocket. It works great, I pull out of my garage touch my left shoulder and the garage door closes. Looks cool too
    2016 Spyder RS SM5
    2016 RS , Black
    Apr 2017
    North Central Florida
    Does your model have the "safety instruction card" that pulls out from the top of the dash board ??
    I found a good use for mine.
    I shoved the bracket/clip on my garage door remote into that slot....firmly.....and it is a tight fit and stays put good.
    Adding a little piece of stick-on door bumper to the button makes it easier to push.
    Default Not that hard....
    I have mine behind the instrument cluster and wired to a button on the dash. You have blank spaces for buttons so somewhat easier. Once you open up the remote you can find the button connections and tap into them to run the leads out to the switch. If not your thing take it to any electronic repair location and have them solder in some leads. Then you have some good suggestions above as well....
    Invalid Emails
    Oct 2015
    morgantown west virginia
    I just bought an additional remote and used Velcro and stuck it in the glovebox on my rt. outta sight outta mind and kinda sorta water tight.
    Houston
    Just put it on your key ring. Much more secure as you seldom leave the keys with the bike.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    I mounted my garage door opener in the glovebox.
    I have saved the foam insert from my original 2010 RT glovebox, and have it mounted in that!
    Active Member Dmetcalf's Avatar
    Jun 2017
    Texas
    Default Too funny ..!
    I’m showing this one to the Mrs’s..!
    2016 RT-Ltd
    Bajaron swaybar
    Spyderpops trunk light
    Elka stage 2 front shocks
    Extra longbrake pedal
    brake modulator
    Rivco dual flag holder
    with American and Texas flags
    Lamonster Magic Mirrors
    missing belt guard
    Lamonster led fog lights
    Baker air wings
    2019 Silverado Duramax dually
    2019 Cyclone 4007 toyhauler
    Rivco brand footrest
    spydermanexhaust.com exhaust
    Pennsylvania
    Default Garage Door Opener
    I purchased an opener from Mo-Door for my ST before I traded it. I attached the control box under the panel by the handlebar and placed the remote button which was about the size of a quarter on top. I moved the switch over to my F3-Limited and did the same thing. I do know that Mo-Door now has openers specifically designed for Spyders.
    Added pictures showing the location of my Mo-Door Garage Switch located beside the handlebars on the right side. This is on my F3 but I used the same switch on my ST-S.
    Last edited by Bruise01; 04-24-2018 at 10:41 PM. Reason: Added Photos of Garage Door Switch
    The WildBat - 2017 Can-Am Spyder F3-L
    Little Bre - 2013 Can-Am Spyder ST-S
    Phantom 2.0 - My SuperSpyder. 2008 Can-Am Spyder SM5
    Apr 2017
    Your remote must be a LOT smaller than mine is.
    And it is not good to have a lot of weight dangling down from the key while it is in the ignition switch.......with ANY vehicle.
    That tends to wear out the switch prematurely AND also tends to scratch whatever the extra stuff comes in contact with.
    Jul 2015
    Dorr, michigan
    Quote Originally Posted by quasi View Post
    did the same thing. Works great. Stuck it on the front wall in a vertical position so it would not interfere with the 380 and extra mags
    2020 RT Limited , Petrol Blue
    Active Member Spyder601's Avatar
    Jun 2012
    Brandon, MS
    Quote Originally Posted by bscofield84 View Post
    I have been looking at these but for my F3. I have a friend who has one on his slingshot and he loves it.
    http://www.mo-door.com/Can-Am_Spyder_Toggle_Switch.html
    17 F3 Limited (Pearl White), Sena 10C intercom, X Grip iPhone mount, IPS key, spyder to go cup holder, Lamonster Highway Center Lane, TricLED engine lights, TricLED night rider, LS2 Helmets, Lamonster Bypass pipe, 2 Brothers Exhaust, mirror relocator kit, Bluetooth radio module, OEM Backrest, Rear LED Light Kit
    2017 F3-T , Pearl White
    Mar 2018
    Oregon
    Quote Originally Posted by Bruise01 View Post
    Goodness!
    Mine stores in the top box. Jacket pockets do not work for me as I change jackets to often. Have left the remote in the jacket a few times.
    I don't want them visable due to worry about theft.
    Houston
    This is the one I have but the other brand openers have similar key fob remotes.
    https://www.amazon.com/gp/product/B00715DTGY
    Danbury Connecticut
    You beat me to it.
    IBA #47122
    2020 RT Limited Asphalt Grey
    At least we're all thinking alike!
    Dec 2015
    Tropical Island ____________of Staten
    buy an updated opener that has Bluetooth and you can then control from an app on your phone.
    Very Active Member al0vely's Avatar
    Apr 2016
    Indiana
    Default Chamberlain MyQ
    Quote Originally Posted by siny10309 View Post
    I have a small remote on the keychain for my F3 but recently added the Chamberlain MyQ which allows me to control the door from my phone which I always use when riding the RTS. The MyQ is nice because it will alert you if you leave the door open after leaving and you can open and close it from anywhere.
    Love my Spyders
    2016 F3L Steel Black purchased 7/16/2016 Sold 3/11/2023 (22,500 mi)
    2014 RTS Circuit Yellow purchased 3/2/2018
    2020 RTL Petrol Blue purchased 1/27/2023
    Girls on Spyders #3195
    No more 2 wheels
    2020 RTL , Lamonster floor board riser Petrol Blue
    Harrington, Australia
    Like several others above, I have an opener about the size of JC’s velcroed to the front wall of my F3-L glovebox. Works a treat and is a very cheap option.
    HeliBars Handlebars
    Kenda Kanine rear.
    Very Active Member zuni's Avatar
    Mar 2014
    JAX FL
    Fairly easy mod. I opened the controller case and attached leads to the battery connections in the controller and used the accessory 12v from the bike. No more worries about replacing batteries and it only works when the bike is on. Two more leads attached to the push button in the controller and hooked to a momentary switch mounted on the bike. Even if you aren't mechanically or electrically inclined I bet if you ask around one or more of your friends will have a soldering iron.
    CJ JAX
    Jul 2011
    Mitchell, Ontario, Canada
    Default No glove box
    Before anyone else suggests putting the opener remote in the glove box and how well it work there. I will point out the OP has a ST model and it does not have a glove box. So really not an option.
    I hardwired one of the remotes that came with my openers. Used a double throw switch, momentary both ways, installed into a empty accessory switch location. The double throw switch allows me to control both my garage doors. This may be above your head but you may have a friend or relative that could help you.
    Invalid Emails
    Oct 2015
    exact remote I have. fits nicely in the front of the glovebox.
    sorry didn't catch the st model part. let the flaming begin
