Results 1 to 21 of 21
    Very Active Member Martin Slovakia's Avatar
    Mar 2015
    Bratislava, Slovakia
    Default Custom made Subwoofer Spyder RT Limited
    Friend of mine has recently improved sound on his spyder by mounting this custom made subwoofer.
    What you think? It plays like a hell, but also it makes him go much slower because of the wind turbulence )))
    Too much?????
    Yep, too much!
    He'd make a much better noise by pulling the air intake plumbing off the front end of the air cleaner & just listening to the induction noise!! And the Spyder wouldn't loose quite so much speed either!
    SpyderLovers Sponsor scooterexpress's Avatar
    Mar 2012
    ft-worth texas
    very gaudy looking way too much box looking he should of looked into putting the sub woofer in the side saddle bags i.m.o. nice try work on it more make it more sleek looking not so boxy
    Tall flag mount, spyderpops skid plate & stainless steel screen mesh, airhawk adjustable cushion, raised white lettered tires.
    Default SUB-WOOFER
    Quote Originally Posted by Martin Slovakia View Post
    Too much?????
    A couple of points ... if you still have the OEM speakers ( F & R ) they are the WEAK link .... they start to degrade at about 1/2 volume ......... I replaced all four ( for less than $150.00 with JBL's ) & changed the rear to 5.25 in. ones .... I can now hear my music at 80 mph .... with a volume setting of 75% ...... crystal clear & Loud ( if you want it to be )... Mike
    Sep 2014
    USA
    Way to much If he wanted more bass what not mount them to the side bags or panels. Kinda like the Harley group does.
    I would be afraid of damage to the rear trunk cover with all that resistance.
    Oct 2013
    Wood Village OR
    Apparently his Mom taught him to share.
    2014 RTL , Black Currant
    Inactive User
    Sep 2014
    mathias,wv
    Default box
    workmanship looks very nice!
    not much on the size and looks tho'
    Keep on with the "out of the box" ideas - very interesting!,
    Tip
    Inactive User
    Default Gotta say....
    that is a lot to put on the rear trunk lid. With the rack above it don't know how long it will all hold together. As stated there are other places to put it and with all that he probably rydes alone so how about the rear seat....
    Aug 2013
    Northern California
    Too much! And I am sure happy that I don't have to be ryding with him!
    Mar 2015
    Default hmmm
    Well if you say so, that you dont know how long it will hold on its place. Then def. i will not rYde behind him any-more
    And usually he drives with his girlfriend, so the back seat was not an option.
    Mar 2015
    Default he did
    Mike, he did same thing as you did in respect to changing the front and rear.. plus he did this.. I am not a big fan of it as well
    Active Member Kredab's Avatar
    Oct 2015
    Iowa
    Mike, I'm interested in this. Whatever you can tell me will be helpful.
    Model #'s, i'm assuming they where marine grade?
    How bad was the changeover ?
    Was there any massaging to the Spyder to make them fit?
    Thank you
    2016 RT-S Pearl White
    BRP Driver Backrest
    Lamonster Spyderdock, (2) Spydercuffs
    Magic Mirror w/Doc Humphreys tethers
    (2) Rokform phone mounts
    FOBO
    SpyderPops Bumpskid,missing belt guard,Rear strobe LEDs
    Lamonster LED headlights & foglights
    Spyder Pockets
    LED front fender kit -running & turn signals
    Custom Back off mudflap
    Vinyl nameplate & 1330 triple decals by New Image Signs
    Custom RLS exhaust
    Hogtunes speakers 5 1/4 front and back
    Memphis Powersports Amp
    Her name is "Purl"
    2016 RT-S , white
    Inactive User
    Aug 2015
    Canton, Ohio
    Quote Originally Posted by Kredab View Post
    Thank you
    Come on Mike fess up. Of course everything is relative, what Mike states was easy requires almost a miracle for most of us to accomplish.
    Joe
    Default SPEAKER INFO
    Thank you
    I bought JBL GTO, 528 ...+ JBL- 508c ..... both are 5.25in the fronts are the same as OEM ..... the rear are a bit larger than OEM - but the ( rear ) OEM's are larger than normal ... so getting the 5.25's in wasn't difficult .... " Beadaholic " ( Laura ) did them and she posted Video's on Her " Laura's MODs page " ....... these aren't so called " marine grade " .... the jbl's have Polymer cones which are waterproof though ! - plastic doesn't absorb anything ........ Mine have been in since 2014 and NO issues at all ...Massaging ?? look at Her video & pics ... TIP #1 - the rear speaker hole needs to enlarged to 4 & 5/8th in..... which is ONLY a little bigger than the OEM hole .......... TIP #2 ... make a template ( circle ) of a 4 5/8th dia. size ... put this on the OEM hole and trace it ....that's the hole you will to get the 5.25 speaker in ..... a few people here have done this after reading my posts about it ......... Mike
    Inactive User
    May 2017
    Boulder City, NV
    I popped the plastic cover off the dash yesterday to check it out on my new F3T (it is just held in place with plastic clips). Easy peasy access to the speakers to unplug, unscrew and upgrade with speakers that a deaf guy can hopefully hear cuz hearing the factory ones at speed isn't an option. Shopping today for upgrade 5.25" 3 way speakers. Like I said, easy peasy job.
    Thank you Mike for the info!!
    Feb 2012
    Southern Indiana
    Thinking outside the box huh? Try putting it inside the rear center compartment.
    DavidC
    Default NEW SPEAKERS
    Quote Originally Posted by tomand View Post
    CAUTION : not all speakers are the same. I chose the JBL's because they are ...2 ohms of resistance ....( aren't effected by water either ) I'm super busy right now ...so I can't give a long technical reason for the 2 ohms ...... check E-bay for the ones I mentioned above ... you might not be able to get 528's , but the 508c is actually better..... the whole " 3 way thing " is mostly HYPE ...almost no one can tell the difference from the " 1 way speakers " .... Mike
    Oct 2015
    Iowa
    Default jbl
    Mike,
    Thanks for the info, just to clarify the 508c can be used in the 4 spots(front & Back). I will look up the video and check it out.......Thanks for making my day with your information
    BRP Driver Backrest
    FOBO
    Spyder Pockets
    Custom RLS exhaust
    Her name is "Purl"
    2016 RT-S , white
    Oct 2015
    Iowa
    Default changing model numbers
    Mike,
    Looking for New jbl speakers, like everything else model numbers change, a couple important things to look for
    1) not cloth components
    2) 4 ohm or less
    Anything else, again thanks for your time... I didn't get a chance to meet you at Spyderfest, I will look you up for Spyderfest 2018
    BRP Driver Backrest
    FOBO
    Spyder Pockets
    Custom RLS exhaust
    Her name is "Purl"
    2016 RT-S , white
    Default JBL SPEAKERS
    Mike,
    2) 4 ohm or less
    Unfortunately ( for all us audio-phials ) the GTO 528 is no longer in production ( but I have seen them on E-bay at really good prices because of this ) I'm not sure about the 508c model ..... but they are still on E-bay ( I have seen them ) the real benefit from using 2 ohm speakers is ...it would be the same as doubling your AMP ... ( kind of expensive way to get this ) .... When I first did this I got a lot of Flack about 2 ohms ....three years later they are stilling pumping out HUGH Clear sounds ..... It's the 2 ohm thing. If I ever get a different Spyder I will be looking for the ones I suggested .......... I think either J&l or J&M makes a 2.3 ohm speaker but they are at least twice as expensive ..... good luck ... Mike .......... I'll at Maggie Valley for their Rally if you go look me up and you can hear mine ..... No one yet has said that they aren't awesome ...... Mike
    Default JBL FITMENT
    Mike,
    Sorry I didn't get this post sooner ........... Initially had 4" JBL's in the rear ..... Then I decided to go Against everyone who said 5.25 " speakers will never fit .... I like a challenge ... So I went with the 508c because I got them dirt cheap ....... This model has a separate Tweeter and a crossover .... I got it all into the rear OEM housing on my RT after enlarging the speaker hole to 4 5/8th in. ... Beadaholic posted video's and pics of How She did it ..... Although they aren't readily available they are out there in someone's stock room ... and I have seen them on E-bay heavily dis-counted ....put in a search with E-bay and they will notify you if they appear ..... Mike
