Results 1 to 5 of 5
    minnesota
    Default "BAD KEY" after I replaced battery
    I installed a new battery in my 2012 RTS-SE5. I charged the new battery before I installed it. When I attempt to start it everything lights up like it should, but the read safety card message doesn't come up. When I push the mode button a few times the orange screen reads "BAD KEY". I tried the second key with the same results. I should add that it doesn't start.
    Active Member plescaille's Avatar
    Jun 2012
    New Egypt
    I know this is an old post but how did you resolve your issue? I am having similar issue on 2012 Limited
    Fortune Favors The Bold!
    Vermont
    Quote Originally Posted by scott16119 View Post
    Call your dealership explain what happen. Can you push your spyder on to a trailer? Take it to your dealership get the D.E.S.S module replaced and have them reprogram your keys.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Sep 2014
    USA
    There was issues with the 2012 model DESS module??
    Vermont
    I had a 2012 RTS-SE 5 I did not get the D.E.S.S error.
    I got the D.E.S.S errors in 2014, when I bought my new 2014 RTS-SE6. I started a tread about the D.E.S.S errors that I had at the time.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
