Page 4 of 5 FirstFirst 12345 LastLast
Results 76 to 100 of 106
  1. #76
    Sep 2014
    Madison AL
    Quote Originally Posted by Doc - Riverside View Post
    Weekend project complete. Looks sharp and reduces the heat during the hot days of southern summer.
    I have a 2013 RT Limited, BRP installed those scoops and other panels as part of the factory recall, the retrofit made a BIG difference in how cool the Spyder now runs and fuel vapor odors were also reduced; BRP a new evap cannister was part of the retrofit. I'm definitely happier with my Spyder now!
  2. #77
    Active Member The Bee!!'s Avatar
    May 2014
    Eureka, MT
    Default Heat vent kit
    Hello,
    Am trying to get this Heat vent from my dealer. BRP is stating that these are already on the 2014's. NOT on mine. I have a 2014- RT-S. What should part should i tell the dealer that i need???
    2014 RT-S
    YELLOW
    BajaRon Anti Sway bar
    Adjustable handle bars
    SpyderPops Skid plate
  3. #78
    Nov 2014
    TriCities, WA
    Quote Originally Posted by The Bee!! View Post
    Hello,
    Your dealer is a moron, IMO never take your bike in there. I don't remember the part #, but don't let anyone charge you more than $67, that is BRP's MSRP. You get the 2 vents, some insulating pieces and 2 bars to replace the acoustical panels and you NEED to do that too.
  4. #79
    May 2014
    Eureka, MT
    Do you have a dealer around you or the Spokane area. The Kalispell dealer (Jesco) is no longer going to service the Spyder after 2 years. They have discontinued selling them as they weren't selling enough of them. Now i need to find a new dealer... Live in NW Montana.
    Quote Originally Posted by pitzerwm View Post
    2014 RT-S
    YELLOW
  5. #80
    Nov 2014
    TriCities, WA
    There is Ride Now, here but I don't take my bike there. If is something big, I'll trailer it to Vancouver. There is a dealer in Coeur d'Alene that is suppose to be decent.
  6. #81
    Very Active Member M109Dreamer's Avatar
    Mar 2011
    Jackson, MS
    Hello,
    The BRP Part number is....
    219800388 they run around $67 for the kit.
    Sent from my SAMSUNG-SM-G920A using Tapatalk
    2007 M109R LE - To many MODS to list. Its cheaper that way!!!
  7. #82
    May 2014
    Eureka, MT
    Thank you, Teri
    2014 RT-S
    YELLOW
  8. #83
    Nov 2015
    Myerstown, Pennsylvania
    Default Heated...
    Sounds like I might be putting this on my 2016 RTS. First ryde out I noticed that the glove box got very warm along with my butt & crotch. Hope this helps. Would putting on the cat bypass on help too?? Thanks.
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
  9. #84
    Nov 2013
    Oro Valley Arizona
    This post requires you to click the Thanks button to read this content. This post requires you to click the Likes button to read this content.
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
  10. #85
    Nov 2013
    Oro Valley Arizona
    2015 BMW R1200R LC
  11. #86
  12. #87
    Nov 2012
    Ft Rucker
    Default Approved!
  13. #88
    Nov 2013
    Central Texas
  14. #89
  15. #90
    Someone's gone & done it again!!
    There's now a string of 6 posts above this (at time of posting) that no-one can see UNLESS they click both Thanks & Like!
    I'm sure that I'm not the only one who just won't bother to do that, so if you actually want your posts to be read, you might want to go back & edit them in the advanced edits to un-check those boxes in Additional Options under Miscellaneous!!
    It seems that once someone does it, either on purpose or inadvertently, then every post thereafter defaults to include those options until someone turns it off again!! With any luck, this post will have turned it off for all the following posts, but all the posts above this & after SteveLaoysters post will remain hidden to most until their original poster edits them.....
  16. #91
    Nov 2013
    Central Texas
    You can either like me or hate me, I really don't care much which you choose. But to have to "like" a post in order to read it? Come on, If you have something to say, then say it. By that very definition of "like", I don't "like" you. If you don't have the courage to post openly, then stay off of this forum. I'm sure that there are other forums that you can be "liked" on. JMHO.
  17. #92
    Quote Originally Posted by oldguyinCT View Post
    Your comment is mystifying. Your post above is one of them that requires a thanks to read it!
  18. #93
    Mar 2019
    NEBRASKA
    Hi Doc, I was hoping to get pdf instructions on the RT venting information. I sent a friend request as I haven't been able to PM you with my email and a request for your write up on the RT vent information. My email is dvuch1@msn.com Thanks Dave
    2012 RTL 14 RTS , Pearl White @ Pearl White
  19. #94
    Nov 2018
    Claremore, Ok.
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
  20. #95
    Quote Originally Posted by davev1pa View Post
    I have a copy. Sent you an email.
  21. #96
    Active Member P.W.'s Avatar
    Mar 2018
    IA
    Will these work on a 2019 RTL?? Just want to make sure before I order a set.
    Thanks for your time and help!!
    P.W.
  22. #97
    Central Oklahoma
    2020 RT Limited , Petrol Metallic Dark
  23. #98
    Jun 2020
    Illinois
    Hi all, new member here. Just bought a 2012 RT-S. Went to the local dealer and checked on the vent kit and it is available, price as listed above - $67 and change. Would appreciate if someone could email me a copy of the instructions. TIA. Splat1520@juno.com
  24. #99
    May 2018
    Chateauguay, Qc, Canada
    Done!
    Eckhard
    Spyder RT Ltd, 2011
    2011 RT Ltd. , Pearl White
  25. #100
    Jun 2020
    Illinois
    Eckhard
    Did not recieve
