Results 1 to 20 of 20
    Richmond Virginia
    Question 2014 Limited - 2K miles, tachometer needle light is out - how do I fix this?
    I have just over 2K miles on a 2014 Limited. We've had it one month now and last night I noticed that the tachometer needle is not lit up.
    Anyone have instructions on how to pull the gauge pod and replace that light / LED ?
    Thanks in advance.
    Are you sure that your warranty has expired? Lots of the 2014s ended-up with four years worth of warranties, and an incentive to purchase.
    Check with your dealer about this... Good Luck!
    Richmond Virginia
    When I bought it from the dealer they said "no warranty". Is there a site I can check for warranty status? I was the first owner, and really love the bike, but the "no warranty" did irritate me some. Not enough to pass up a fully loaded limited with only 2K miles, with the Garmin, the adjustable handle bars, the touring seat with backrest and a few other add-ons for $20,000 though.
    I don't know if the original warranty died with the transfer of title; somebody else in here can probably advise you better about that...
    Apr 2013
    Atkins, Arkansas
    When I bought mine from (Honda House) the warranty started on the day the dealer signed over the title and 1 year and 9 months later purchased the BEST extended warranty. I would make a call to BRP Customer Service.
    Quote Originally Posted by WhiskeyThief View Post
    If it was truly a demo and not titled until sold to you, the warranty started when you bought it! I think the dealer was jerking you around.
    Mar 2013
    Maumelle, AR
    My understanding is the warranty clock starts the day the Spyder is labeled a "Demo".
    2020 RT Limited , Chalk
    Sep 2015
    Chilliwack, BC. Canada
    Default 2014
    When I bought mine, 9 months ago, it was a used unit. The previous owner had purchased it as a demo. When I took possession it still had 13 months of New warranty, period. I have since purchased the extended warranty. You may still have warranty. Check with another dealer, or BRP themselves.
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
    Richmond Virginia
    Quote Originally Posted by Bruce785 View Post
    Nope!
    From BRP -- Thank you for taking the time to contact BRP.
    In response to your request, if a unit is used as a demo unit, then it would have to be registered. The unit was registered - Registration 2015/12/22
    and the Regular Warranty End 2016/01/13.
    So, to the original question - anyone know how to fix that light?
    Default DEALER DEMO UNITS
    Nope!
    I have gone to plenty of dealerships and TEST drove cars ....... NONE OF WHICH WERE REGISTERED ..... The Dealers had Plates registered to the Dealerships that could be placed on any vehicle they had POSSESSION OF ( not registered ownership ). So maybe they are appling Canadian rules to U.S. veh's ........Mike
    Sep 2012
    Stetson, Maine
    I bought my 2011 RTs in 2012. It was a demo. The warranty started on the day I bought mine. Bruce
    Richmond Virginia
    anyone have a solution to the problem of the tach needle not lighting up????
    anyone????
    anyone????
    I think your choices are to live with it or replace the cluster at something like $700 I'm guessing. I don't know that there is any way to open it up and repair it. You could try I suppose since you have nothing to lose, if you just can't live with it. I don't recall reading of any other one that has failed like that, so there's no history for you to fall back on.
    Active Member GearHd's Avatar
    Mar 2015
    Connecticut
    anyone????
    It's got to be under warranty still so bring it to the dealer and let them take care of it. Unless the two year warranty is done already?
    Wife has a 2014 ST-L
    2014 ST Limited , Silver Platinum Satin
    May 2015
    United States
    Nope!
    BRP should fix the light.
    If the bike was registered on 12/22/2015 then the 2 year warranty would end on 12/22/2017 according to my 3rd grade math teacher.
    Good luck getting it fixed.
    2010 RTS-SE, Orbital Blue
    Sep 2009
    illinois
    [QUOTE=WhiskeyThief;1165501]anyone have a solution to the problem of the tach needle not lighting up????
    The speedometer is back lit from the factory, the tach is not!
    Apr 2015
    Brockville ONT
    Since there is no warranty and no one knows of a fix.Find a buddy who does have warranty switch the cluster have him go to dealer get it fixed then switch back.Give him 50 bucks for his troubles.Every one happy.
    Bill
    2018 RT Anniversary , Brake pedal extended
    Houston
    Nope!
    How can the warranty expire less than two WEEKS from when it was first registered unless this was a flood recovery or some other salvage unit that voided the warranty? If it was, it had to be disclosed at purchase. There is more to this story that you are not telling us.
    On the original question, it will require cluster replacement.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    May 2015
    United States
    Quote Originally Posted by Ex Winger View Post
    Bill
    I would not do this. This would be a good example of felony fraud.
    And to say who would find out is not the point.
    As an adult you should know right from wrong and this is wrong.
    Dec 2008
    Jacumba, CA
    I bought a 2014 RTS at year end, got 4 years warranty. The dealer telling you "no warranty" does not nullify the BRP warranty. Call BRP, get the right info and return to the dealer with that info. See where that goes.
    2008 GS SE5 in 2008
    2010 RT SM5 in 2011
