Analog gauges
Looking for analog gauges for my 2014 RT gas and temp., I just cannot see those readings in the center cluster
Good luck with your search!
Try and find a set of gauges out of another 2014 RT... Cruzr Joe reported that there were some changes to the electrical connections with his 2015, and the prior year gauges just weren't nearly as accurate.
That is correct the 15 & up use different plugs, there are several people that have removed the gauges, maybe they will offer them up.
Cruzr Joe
I have a set make an offer
gauges
I have a 2015 sts special series, I was just wondering if all spyders are missing a kph on there analog speed gauges mine does not have one and I thought coming from Canada it would have one. I do have a place on the computer for a kph setting on the digital.
Analog gauges
I really have no idea what they are worth. Wonder why many folks took them out ? I would think they would be fairly accurate and easier to see, at least in my case........
I am wondering if you switch the digital gauge to KPH then the analog gauge will switch too to KPH. The same MPH numbers are then read as KPH.
Yes, that's correct. At least on the RT, I can't imagine it's different on the ST.
IBA #47122
2020 RT Limited Asphalt Grey
Cruzr Joe
x2
EDIT: I CAN'T FIND THEM; I PROBABLY THREW THEM AWAY...SORRY
you can have mine gratus...if you can, I'd preciate ya pay shipping however you want it...a USPS flat rate box is like $15
lemme know
I found mine...you are welcome to them for cost of shipping
