How far out?
When you had the laser alignment done, how far out was your alignment?
Don't remember the numbers, but it was way out and the jam nuts were loose.
mine was less then a half inch, but i don't remember what side was really off
My left tire was out 5/8 In. and the right was out 7/16, Lamont did mine while I was at Spyder Fest,,
2013 Viper Red RT S-SE5 All 48 states on a Gold Wing now I'm working on getting all on a
I was told mine was out 1 1/2" on both sides.
Mine was 1 3/4 inches, in on one side and out on the other. Mike Loescher of Spyder Comfort did mine and said it had a lifetime guarantee.
David
I don't remember the numbers...
But Ron Netzley aligned mine, and he said that it was "almost" close enough to not need much tinkering...
But one side was toed-out further than the other.
Both times..??
don't remember the figures. Squared Away did it both times but the second does confirm that messing with the rear wheel, changing shocks and front tires does mess with the alignment...
Close counts only in horseshoes and hand grenades!
And Field Artillery too.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Mine was Laser Aligned by Lamont when it came off the Showroom floor at PitBull PowerSports and i had it checked at 7500 miles and it was still good.
Cruzr Joe
Mine is still going straight after 61,000 miles.
2010 RT- 622
On three Spyders, all were toe-out by about 1/8" in 6' - going to slight toe-in fixed tire wear and greatly improved the handling. The shop manuals state the measurement is +/- 3' from axle center line. The LASER alignment systems are a much greater distance (11 to 12'), which translates into higher possible precision.
I did our RS and ST; Mike Loescher, the LASER system inventor, did my F3 at the Deadwood Three Wheel Rally in Aug. The discussion I had with him about steering and alignment was worth more that the wheel alignment.
Wayne
pauly1 - SpyderDeb's 'wrench'
IBA #48220 SS1000 BB1500
Mine was bout 1/2"in on both sides. Tracked good I thought glad I had done & will make yearly thing. Too bad no one local but more reason to spyderfest
I don't think we have laser alignment here, wish we did though, not sure what can be done about alignment here in Mexico? Go to a car joint? or ??
SpyderLovers Sponsor
Las Vegas
Come on up - we can Square You Away! I doubt car equipment would work properly. Las Vegas is not too far, and as good as an excuse as any to visit our little city! Joe
Joe Meyer
Mine was out 1 1\4 inch. Had it done at Maximum Motorsports in Peru, IN. Was amazed at the differance it made.
