Results 1 to 25 of 26
    Sep 2015
    lumberton,tx
    Default Battery Location
    I really feel like a newb. I have looked around on my '14 RT Limited and am having no luck spotting the dang battery.
    Sep 2015
    Tri-Cities, Tennessee
    Quote Originally Posted by txhood View Post
    I have a 15 and it is in the frunk behind a zipped in liner then behind the plastic compartment
    Suggest you read your owner's manual. You can learn a lot from it.
    Default Two steps....
    step one...read the manual cover to cover...
    step two...try to prove its wrong...
    Or...ask us, we will rib you but tell you anyway...
    Sep 2015
    lumberton,tx
    To all you wise guys, you can keep the comments to yourself. I have read the owners manual and it does a very poor job of explaining how to get ot the battery. Maybe in my next life I will be a brilliant wrench like you jerks.
    Jun 2010
    Las Vegas
    Wow, you probably aren't going to make a bunch of friends here with a comment like that. On page 125 of the 2015 RT owners manual they give pretty clear instructions on how to access the battery. "Battery LocationThe battery is located in the front storagecompartment.To access the battery, open the frontstorage compartment. Open the access cover.Unzip the liner if applicable. Loosen the screws and open the batteryaccess pan" They even have pictures.
    So to recap, open the front trunk, unzip the liner, loosen the screws and open the battery access panel. Here's a freebie, the screws are Torx 30. Good luck. Sorry I couldn't get the pictures to post here
    Edit: I thought you had a 15 but I'm pretty sure the exact same info is in the 14 manual on or around the same page.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    and welcome to the madness.
    Three possibilities:
    : Its under the seat
    : Its hidden at the back of the frunk behind the liner.
    : You got one of those prototype solar 's The give away is that rear air wing deflector--its really a solar panel.
    More information to come on the solar when the embargo is lifted on 3/31/16.
    .....Three possibilities:
    : Its under the seat pre 2014's.....
    Shouldn't that be 'pre 2013's'?? My 2013 RT Ltd has the battery in the frunk behind the liner & screwed in panel. The 2012's & earlier had it under the seat.
    I defer if you say so. What's a year or two among friends.
    Active Member GeorgiaBill's Avatar
    Aug 2015
    Marietta, GA
    Default Page 130 on the 2014 RT Manual
    I just had to look.
    -Bill
    2019 Black F3-T
    Sep 2014
    Riverview, FL
    As an owner of a 14 RTL, may I suggest that you buy a battery tender. If the battery tender comes with a separate battery connector with 1/4" clips, cut a small hole in the frunk zipper lining (large enough to slide the connector through), and connect the red and black clips to the matching battery terminal, leaving the connecting end of the tender connector exposed on the outside of the zippered lining. By doing this you now have the ability to easily connect the battery tender to the battery and charge your battery after each use. Enjoy your Spyder.
    Ah; what the Hell...
    You'll get the hang of it!
    Invalid Emails
    May 2011
    Austin,Kentucky
    I have a 2014 Limited and the battery is up front in the frunk behind the zippered compartment
    Very Active Member OverHillAndDale's Avatar
    Sep 2014
    United States
    Ribbing, jokes and sarcasm are a standard here, mixed with some pretty good advice. Only a couple of real people on the forum.
    2020- RT Limited
    Chalk White, Can-Am rear passenger armrests, Comfort Seat, Grip puppies, RAM Cup Holders, Providence RAM Mount
    FOBO2 TPMS
    Aluma MCTXL trailer
    BRP hitch
    Big Bike Parts wiring harness
    Permanent Smile!!!
    Jul 2011
    Mitchell, Ontario, Canada
    The battery on all 2013 to 2016 RS, ST and RT is located behind the front trunk. It accessible by access panel located in the lower rear of the front trunk.
    Jun 2015
    Maryland
    i heard that was the 2016 Roadster BTL Edition ( Battery Tender Limited ) for charging on the go as you roll prototype
    2014 RT Limited , Burgandy and Silver
    Apr 2014
    Beloit Kansas
    the only crazy question is the one that isn't asked.
    I've read my owner manual, and STILL....sometimes.....
    Sep 2015
    lumberton,tx
    Sorry guys. I had read the manual but when I unzipped the liner in the frunk I was having problems knowing for sure what screws they were talking about. A couple of the comments came off as condescending and since I have the "short-fuse" disease, I typed first and thought later.
    No apology is necessary...
    It's okay for families to squabble a little bit...
    We all pull together when it counts!
    I actually thought that Gene's response:
    "step one...read the manual cover to cover...
    Or...ask us, we will rib you but tell you anyway..."
    Was pretty accurate... AND funny!
    Jul 2011
    Quote Originally Posted by 4 MARIE View Post
    Of course you're not expected to remember every detail of the owner's manual. But from my experience. If you just give an answer to the question. The OP often gets confused by a lot of answers from others that are wrong. If you give an answer and say it is in the owner's manual and then often the OP takes it as some sort of insult. I have been thinking that this is a no win and not to bother answering questions from newbies at all.
    Oct 2014
    Fort Mill, SC
    Default Quiz
    OK class, now that we are all playing nicely in the sandbox together, there will be an Owner's Manual quiz in the morning.
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    Member: American Legion
    Jul 2010
    Las Vegas, NV
    Default Hmmmmmmm
    There are no dumb questions. Just because we get used to crazy stuff, it is still crazy stuff! Perfect example: "to change the oil in a 2014 RT, begin by removing the right mirror"!!!!
    To the OP, just ask. The alternatives are to pay a shop to do everything, do nothing, or read and learn to do things yourself. I learn a lot here, and have met or know most of the folks who replied. I have a feeling you will fit right in! Joe
    Joe Meyer
    Here's a picture of what your battery access door looks like and is a little clearer than the one on page 131 of the 2014 manual. The two access bolts are on the left and right sides of the picture that, in this case also has a Bluetooth dongle on a bracket that is held in place by the access bolts. The double strand wire hanging down from the upper center of the door is the battery tender pigtail that is bolted to the battery terminals.
    Apr 2013
    Atkins, Arkansas
    Interesting, I have a 2013RT and my Battery is in the left rear compartment.
    Sep 2015
    lumberton,tx
    I found it. Another example of over thinking something. I was trying to figure out how to remove the zippered cover, when all I had to do was unzip it and take out the two screws and remove plastic cover.
