Results 1 to 12 of 12
Thread: Brake Pedal
    Active Member TheCajun1957's Avatar
    Jun 2016
    Kilgore Tx.
    Default Brake Pedal
    Well I got tired of trying to find the brake pedal with my big ole foot, I ordered the full pedal from spyderpops. Got it and installed it. A lot larger then orginal.
    Took bike for a ride and found the pedal took up a lot of the floorboard and no place to put my foot!
    So I took the pedal off and found the band saw and a finishing sander with 220 grid paper.
    I cut the pedal at an angle about a 1/4 in from the line imprinted on the pedal and then used the sander to roll the edges. Its longer then an original and not as hard to find now!
    2018 White F3 Limited
    F4 25" Windshield with vent, UltraGuard 1/2 Cover, Rivco Flag holders, Show Chrome Rear 0rganizer, FOBO Spyder TPMS,
    GMax OF Helmets with Sena 20s, Air Force A10 Gremlin Pewter Bell.
    LAMonster:
    Spyder Cuff with X grip, Rear Cup Holder, Belt Tensioner, Position 4 Brake Bar.
    SpyderPOPS:
    Top Case Seat Extender, Top Case Brake Modulator, Foam Grips, Missing Belt Guard, Wolo Horn
    Default Well done...
    Looks like a great solution and nicely done...congrats... Did something similar though not having flooorboards not a problem....
    ​2012 RS sm5
    Sep 2015
    Parkesburg,Pa
    nice job,I was going to get one of those but it looked too big.Liked the way you cut it down,I am going to rethink ordering one and do the same.
    Jun 2016
    Kilgore Tx.
    Quote Originally Posted by slick999 View Post
    Just plan it out how you want to cut it and what with, then take your time.
    LAMonster:
    SpyderPOPS:
    Active Member wd8ajj's Avatar
    Jul 2014
    Las Cruces NM
    Good Idea. Was not sure if that could be done. Like to take about 3/4" off of mine and that also might drop enough weight that the brake lights will not stay on due to the weight of mine.
    washington state
    I did mine (DIY) and never have any problem.
    2012 Spyder RT SE5 Brake pedal mod
    Jun 2016
    Kilgore Tx.
    Quote Originally Posted by wd8ajj View Post
    The metal plate at the core is trough out the pedal, so when you cut the pedal shorter you will see metal at the end, use some fine sandpaper and polish the metal, gives it a little classy look, if you have chrome floorboards, it kinda blends in.
    LAMonster:
    SpyderPOPS:
    Active Member FlyBoy2121's Avatar
    Aug 2018
    Canada
    Cajun1957
    I too have a brake pedal 4 '' wide, the why of this pedal wide, these I have arthritis to the toes, the little pedal origin it is very small immediate foot pains, Problem I could not put my foot properly on the floorborrd.
    Here is what I did, I machined an aluminum block of 1 '' 1/4 x 1 '' 1/4 x 2 '' 1/4 make holes in the block, buy bolts longer, a little locktite on the bolts, and you can put your foot under the brake pedal, these SUPER.
    FlyBoy2121
    May 2018
    millsboro,delaware
    Looks good but what happens when you slam your foot for hard stop,will the floorboard still drop away or does it hit the board and keep you from getting full brake pressure?
    2017 RTL ORBITAL BLUE
    Active Member MeudtPG's Avatar
    Aug 2018
    Monroe, WI
    Great improvement and nice job theCajun! I was thinking this big brake pedal was extreme in length also and plan to do your mod on mine. Thanks.
    Quote Originally Posted by TheCajun1957 View Post
    2018 SPYDER RT LTD SE6 BLUE/CHROME
    Aug 2018
    Monroe, WI
    I tried the new large pedal and it still drops the floorboard like the original in my opnion. Is everyone here on the same page regarding this major safety question?
    I don't want to compromise anything as important as brakes for sure!
    Here is Spyderpops SPY208 info:
    THIS NEW BRAKE PEDAL IS BIG ENOUGH TO GET YOUR FOOT ON REAL GOOD. IT'S 4" WIDE AND MATCHES THE FACTORY FLOORBOARDS. THIS IS THE ANSWER FOR WHEN YOU CAN'T SEEM TO FIND THE PEDAL IN A HURRY.
    IT JUST BOLTS ON WITH THE FACTORY BOLTS IN THE FACTORY HOLES, EASY AS IT GETS.
    FITS ALL SPYDERS. DO NOT USE WITH NON STOCK FLOORBOARDS THAT WILL RESTRICT THE TRAVEL OF THE PEDAL!!!!
    MADE BY SHOW CHROME
    Quote Originally Posted by spyder01 View Post
    Got mine done! Painted the end BLUE to match my Spyder so no rust later on.
    Jul 2008
    Natchez, Ms
    I put a lamonster pedal on my new rtl. Great
    Replaced my Lamonster Certified RT Limited #1874 With a 2018 RTL.
