Results 1 to 9 of 9
    Mar 2021
    LAKE PLACID , FL
    Default What is the difference between an F3L and an F3T ?????
    I have a 2016 F3 Limited and I don't know or can find out the difference between the F3L and a F3T ??
    My bags say F3Limited but my title says F3T..
    I have looked but I guess not in the right places...
    T.I.A
    TJ
    TJ
    TJRANCH
    2016 F3L
    The F3L is the most "upline" version of the F3. It has a few more "bells and whistles." Real chrome for the "chrome" package. I believe the main difference between the F3T and the F3L was the addition of a "travel trunk" on the back. The T model just came with saddle bags. Since we are talking 2016 here, I am guessing the tittle has the correct description of the model. Previous owners may have added F3L bags instead of the standard bags on the T model. I believe the only difference was the "F3L logo."
    If I am not correct, others will correct what is wrong.
    Mar 2013
    Maumelle, AR
    In 2016 I bought an F3 Limited, had it 3 1/2 years and put 52,000 (maybe 54K, I forget) miles on it. That was my favorite Spyder.
    The 2016 F3 Limited did not come with a top box. That wasn't introduced till 2017. What color is it? The biggest and most noticeable difference is the chrome. You'll have a lot of it, wheels, muffler heat shield and end cap, you'll have a chrome piece on both sides by the driver floorboards. You'll also have floorboards (the T has pegs). And the saddlebag will say Limited. And in the grill, there'll be a small label that says Limited.
    On the T, there will be foot pegs and no chrome. Also, depending on the color, the tail piece and where your gas tank is, will be black.
    Post a few pictures.
    2020 RT Limited , Chalk
    Mar 2021
    LAKE PLACID , FL
    Quote Originally Posted by Copperman View Post
    .... < snip> .... What color is it? The biggest and most noticeable difference is the chrome. You'll have a lot of it, wheels, muffler heat shield and end cap you'll have a chrome piece on both sides by the driver floorboards. You'll also have floorboards (the T has pegs). And the saddlebag will say Limited. And in the grill, there'll be a small label that says Limited.
    It's WHITE...
    TJ
    TJRANCH
    2016 F3L
    May 2013
    Apex, N.C.
    You indeed do have a Limited. In addition to the chrome pieces and floorboards, you should have heated grips, which is an option on the F3T. By having a 2016 F3L, you also get the larger rear sprocket. The later year F3L have the smaller one.
    Mar 2021
    LAKE PLACID , FL
    Thanks to everyone for the answers.. still don't know why title says F3T..
    Guess I'm not going to worry about it now...
    TJ
    TJRANCH
    2016 F3L
    Mar 2013
    Maumelle, AR
    Yes, that's a Limited.
    Active Member PURPLEON3's Avatar
    Aug 2021
    Shippenville, PA
    Quote Originally Posted by tjranch9 View Post
    I had a 2018 F3T that I bought used the end of 2019. The previous owner (who worked at my Can-Am dealership) turned it into a Limited by adding the floorboards and trunk. He also added the heated grips. Trying to remember if he added anything else. So that is why my title indicated F3T, not F3L. For all intents and purposes mine was a Limited but it didn't start out that way. Hope that helps.
    2023 F3Limited SES
    Sold my beautiful 2018 F3L "Spyder Girl" July 2024..we made a lot of memories together!
    Vermont
    T.I.A
    TJ
    HI tjranch9,
    I have a 2023 F3 LTD SS (brought brand new at the end of May this year).
    It has fog lights, top case with luggage rack, automatic air ride suspension, U-fit system, comfort seat, and adjustable handlebars.
    Deanna
    Current Spyder - 2023 F3 LTD Special - Mineral Blue
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Front Fairing Service Access Door Covers (Carbon Fiber Domed Black)
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    A-arm Daytime Dual Color LED Running Lights with Blinker Module
    Marinco 12 Volt Power Receptacle with polarized leads & slide lock
    Show Chrome Trunk Shock
    LED'S - Run/Turn/Brake Rear
    Former Spyder - 2014 RTS SE6 Cognac - SOLD
    First Spyder - 2012 RTS-SE5 Quantum Metallic Blue - TRADED UP
