Results 1 to 8 of 8
    Oct 2015
    Lynden, WA
    Smile Help Needed - F3 Air Intake Modification
    2016 F3T. It has a Cat Delete and K&N air filter. It has a burble when closing the throttle on deceleration.
    Has anyone modified the intake system to get more cold air into the system?
    What did you do??? Pictures???
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Aug 2019
    Stoughton, WI
    The only mod I know of is drilling (2) 1” holes on the air filter cover, like what Monster does with their stage 2 flash. This was on my past F3S with PV3 custom tune. 1" plastic hole plugs pop right in. However, the Spyder will pop like crazy on decel with stock ecu tune.
    2022 RT Sea To Sky
    Nov 2015
    Chardon, OH
    Quote Originally Posted by Haze View Post
    A burble. So what? And please don’t say that this means it’s running lean. It’s not. If it was, you’d get the code. There’s no carburetors anymore. That’s in the past. The ECM automatically controls the AFR. Train yourselves up on Closed Loop and Open Loop operation. You're in Closed Loop at this point. Here, courtesy of AI:
    Here's how closed-loop fuel injection works:
    Fuel calculation
    The Electronic Control Unit (ECU) calculates how much fuel the engine needs based on programmed fuel tables and sensor input.
    Air/fuel ratio comparison
    The ECU compares the target air/fuel ratio to the actual ratio measured by the O2 sensor.
    Fuel adjustment
    If the ratios don't match, the ECU adds or subtracts fuel to equalize them.
    It’s all automatic. The ECM will correct before you can blink twice. If there was a problem, you’d get the code. I bet that you can simply hear the sound better because of the cat delete. But, if you REALLY want to drill holes in your intake plenum, it’s your machine.
    Doug
    ”Freedom is not a loophole”
    F4 Customs SWCV, Ultimate, Lidlox, Adjustable Side Vents, Leather Like Grips, SS Grills, Centramatic, Garmin XT2, BajaRon Original Sway Bar w/ Lamonster links, RLS CD w/ baffle, P238
    Oct 2015
    Lynden, WA
    Thank You to the respondents.
    I was worried about running lean.
    I now understand the action of the ECU and feel relaxed with the burble...
    No codes and no worries.
    Cheers David C.
    David C
    2016 F3T
    Rear IPS Pack Rack
    Mar 2015
    forrest above Reno, Nv
    Hi Dave,
    Did you get the answer you needed? My solution probably won't work for you as the intake tube is different on the RT. I'm going to look on a parts page to see what the intake snorkel looks like on your ryde.
    I looked on the parts diagram, found your intake, and it looks like the end that doesn't attach to the air box attaches to " something". IDK what, but it might be baffled somehow. I removed the baffle and opened the intake on mine, but IDK how yours is configured. I'd try to find where the air comes into the system (hopefully from the front of your F3T).
    Lew L
    2014 RTS , Circuit Yellow
    Sep 2024
    Virginia
    Wouldn't drilling holes there let more hot air into the airbox?
    And most filters flow from the outside in, so that would let unfiltered air bypass the filter.
    Last edited by Peter Aawen; 12-02-2024 at 03:29 AM. Reason: Please only use the forum supplied emojis. ;)
    2015 Spyder F3-S - SM6, Can-Am Red (Looks orange to me)
    Pre-muffler delete.
    BajaRon's Ultra Sway Bar.
    ... so far!
    Aug 2019
    Stoughton, WI
    Quote Originally Posted by Cobranut View Post
    1.) That has been debated in the past.
    2.) No. The bottom of the air filter is seated into the chamber.
    2022 RT Sea To Sky
    Jun 2011
    Near Lexington, NC
    My 16 F3 was totally standard and it had the "burble" as well. I recall others saying the same. Personally I liked the sound of it.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
