Results 1 to 10 of 10
    Active Member ff73148's Avatar
    Jun 2018
    New Jersey
    Default Any problems with battery charging due to Electric Clothing?
    I own a 2022 RT Limited. Has anyone had a problem with their battery charging when you have an electric jacket liner plugged in while the heated grips and seat were on?
    Last edited by Peter Aawen; 03-16-2023 at 06:06 PM. Reason: Expanded title to briefly ask the question... ;-)
    Frank Ferrante
    2022 Can Am Spyder RT Limited Deep Marsala Metallic Dark
    2016 Moto Guzzi Eldorado
    Sep 2020
    Middletown, NJ
    I run my 20 RT with heated grips and seat on low and power my jacket & gloves as well. I haven't had any problems in 3 winters of riding almost every Sunday.
    2020 RT base , Chalk White
    Aug 2007
    Greeneville, TN
    Should not be a problem even with full electric gear. Especially the current products with pulse heating. We sell the Warm & Safe product and have had zero issues. Even on the early Spyders that don't have as much charging current as the 1330 machines.
    Jan 2021
    Descanso, CA
    The 1330cc engine's alternator outputs 1250W@1720RPM, 850W@2910RPM. Nominal operating load is probably 300W. !00W of heated gear will keep you at warm summer day temperatures. So plenty of reserve capacity in traffic or on the highway.
    2014 Can-Am Spyder RT-S SE6 Freeway Commuter Pod
    2016 Royal Enfield Classic 500 Fair-Weather Mountain Bike
    Vermont
    I have a 2014 RTS-SE6 with the "1330" Ace Engine.
    I run/use the Heated hand grips+ my heated Jacket liner( which is 90 Watts) on my Spyder. I haven't had any problems.
    I use the following http://Thewarmingstore.com/warm-n-sa...s-heated-liner
    I am also using the above on my sled.
    I run/and use the FirstGear Heat-Troller Version CMB Remote - Designed and Manufactured by Warm and Safe Heated Gear, LLC.
    When I use the above, I run the red knob at about a quarter turn, and the yellow knob about a quarter turn as well, (that controls the heated pants, when I am on the sled/or Spyder).
    I hope the above info helps.
    Deanna
    I also use/run the following on my sled: http://revzilla.com/motorcycle/gerbi...?sku-id=716682
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Northern Kalifornia
    My 1330 ran two full sets of heated clothing, charged a cell phone and sena headsets along with running both driver and passenger heated hand grips. The alternator ran all that without any issues. I'm also going to try and add a heated coffee mug holder.
    Active Member Jesster72's Avatar
    Oct 2021
    IL
    Add a coffee maker, and you are in Goldwing territorry.
    2022 Sea to Sky
    Aug 2007
    Greeneville, TN
    Can I get a Laptop and Printer with that?
    Quote Originally Posted by Jesster72 View Post
    Don't forget the hot tub on a trailer.
    Oct 2021
    Wichita, KS
    Peter Pan has struck again!
