Results 1 to 8 of 8
    Nov 2022
    North Carolina
    Default Shifting Issues - F3 won't always shift out of 1st - anyone else?
    2018 F3 Limited 6,000 miles, just serviced ... So, I took my "new" F3 out for our first serious ride today. On three separate occasions after coming to a stop, it wouldn't shift out of 1st gear. After sitting beside the road fussin' and cussin' for a few minutes and several restarts it was fine until the next time it happened. Kind of feels like a heat/temp issue to me. Checked the oil and it is in normal range. Anyone else been through this?
    Last edited by Peter Aawen; 11-23-2022 at 03:43 PM. Reason: Expanded Title to briefly ask the question ;-)
    Nov 2022
    North Carolina
    That's a little different than mine. I was able to get in neutral, then it wouldn't go into any gear for 10- 15 minutes. That's why heat/temp comes to mind. Modules/electronics can be bothered by heat or overheat themselves, I think. At least they used to back in my hot-rodding days. Will check for codes tomorrow.
    Happy Thanksgiving everyone!
    Quote Originally Posted by cjr00 View Post
    There have been quite a few reports of problems with the " paddle shifters ", so I think this is a possibility .....good luck ... Mike
    Jun 2011
    Near Lexington, NC
    Make sure your coolant is topped off. If it get very low, it plays heck with the sensors.
    2016 F3T (as of 7/11/20)
    Active Member ottawa-rider's Avatar
    Sep 2012
    Casselman, Ontario, Canada
    Yes, this, there was a service recall for this very same problem affecting the 2018's.
    2018 RT LTD , Black
    Nov 2022
    North Carolina
    Update... service tech texted me. Replacement shifter switch has been ordered. No ETA, but it's progress!
    Active Member Isopedella's Avatar
    Feb 2022
    New Zealand
    Yup. Progress.
    Ta for the update.
