Results 1 to 4 of 4
    May 2022
    Alberta
    Default 2013 CAN-AM SPYDER ST - Stalling
    Hi, my gf Spyder originally went to the shop with a check engine code P1174, Other than that it was running fine. Code = Too lean Bank 2. She thinks she may not have had the gas tank cap on properly. After 3 weeks in the shop and many parts later it is now stalling. Changed purge valve, replaced some vacuum hoses, spark plugs, fuel filter, air filter, intake manifolds, air intake boots, o rings, intake flange. In the meantime it had codes P1171 and P1172 come up. They were going to test ride it over the next few days and if it still stalls and they suggest the next step is to replace the entire throttle body assembly which apparently is pretty pricey.
    Anyone ever gone down the path of this type of Spyder with stall issues? Will replacing the throttle body assembly fix this?
    The machine has less than 25,000 miles (38,000km) on it.
    Any sage advice would be appreciated.
    Thanks
    Quote Originally Posted by skywalker View Post
    Thanks
    I'm sending many ..... I don't have a good feeling about your Dealer Tech ..... I had a GS that very often was lit up like a Christmas tree ..... but ran fine , so I didn't do anything. Never gave a LIMP mode except once on the New Jersey T-Pike when the temp was 101 F ..... kept riding to my sisters house and the next day it was fine ..... good luck ... Mike
    Nov 2016
    Upstate NY
    You didnt change the oxygen sensor. The one part that is usually responsible for a lean code.
    2021 Sea to Sky RT , Highland green
    Bossier LoUiSiAna
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
