Made rear trunk organizer for 2021 RTL S2S
Made this handy rear trunk organizer for my 2021 RTL S2S for $10.00.
Garden tool belt from Amazon.
https://www.amazon.com/dp/B08QG7HPX8...roduct_details
and a couple snaps. No more taking everything out of the trunk to find the thing I know is in there.
Reason: Changed header
2021 RTL S2S, BRP arm rests, smart mount backrest, Pedal Commander, F3 position B handlebars, adj side vents.
How did you install the snaps for the Spyder?
Peter Pan has struck again!
The snap base uses a small screw to secure it to the surface. Drilled small hole thru hinge cavity on each side.
Thanks for the reply. Do the snaps have to be installed into the canvas bag or does the lip hold it in? I was thinking I would need some special grommet tool or something.
The top snap is in 2 pieces installed thru the material and crimped over by means of shaped anvil and punch. Was snap kit I purchased at Walmart or a hardware store, I don't remember.
Like this one at Amazon.
https://www.amazon.com/30sets-Canvas...%2C146&sr=8-62
I just purchased the belt and snap kit from Amazon through your links. Thank you very much sir!
Neat idea!!!! Good job!!!!
