Results 1 to 17 of 17
    Active Member Escorial's Avatar
    Jun 2021
    Chicago il
    Question 2020 RTL HELI BARS (not enough forward adjustment at the clamp)
    I have the above year model and I'm not able to move the bars forward enough. The issue is the lowest part of your bars that are clamped to the triple tree, so the bars are just too low to close.
    The other part of your bars that also allow forward adjustment and at the furthest point, that is not the issue.
    Do they offer a different lower piece separately that would let me move the bars more forward?
    The piece I'm talking about is the one that has the tiny hole on the bottom that fits in the clamps?
    Tia,
    Last edited by Peter Aawen; 12-25-2021 at 09:24 PM. Reason: Removed Prefix - not engine/size related!
    Harrington, Australia
    Quote Originally Posted by Escorial View Post
    Tia,
    Escorial, I have the Helibars on my 2021. That slot is effectively an alignment slot to fit into the nub to ensure your bars are centred. If you want to move your bars away from you a bit more, just use a Dremel to elongate the hole a little. You wonít need much (maybe 1/8Ē) to get an inch or two further forward at the top of the bars.
    I did that to my last bars but havenít needed to do it to the Helibars as I have found a comfortable position.
    HeliBars Handlebars (elongated handlebar bar slot to get more height)
    Highway pegs bolted under floorboards.
    Brake rubber removed to lower pedal for easier long leg/15 boot access.
    Kenda Kanine Fronts (Rears unavailable in Oz ATM).
    RabbitWorks (Aussie) Dual Setting Stabiliser Bar (Lamonster links)
    Ikon (Aussie) shocks all round (setting 2 of 4 for pothole smoothing with improved handling)
    Russell Daylong seat (in Sunbrella for Aussie heat & water resistance)
    Feb 2020
    N. Wilkesboro, NC
    What Pete said.
    Jun 2021
    Chicago il
    How necessary is that pin in the bottom of the clamp?
    I ask could it be simpler just to remove the pin?
    Aug 2019
    Stoughton, WI
    The pin nub also acts as a safety mechanism to prevent the bars from unexpectedly pivoting forward or back. As others said, just using a Dremel tool to elongate the hole is a safer option.
    2019 F3-S SE6 Monolith Black
    Comfort: Madstad 14" dk gray-20" lt gray windshields/Seth Laam seat/Ultimate floorboards/Helibars/Heated grips/Backrest
    Ride-Handling: Spyder Extras sway bar/Vredestein Q5 front tires/Goodyear Ultra Grip rear tire/Wilber 640 HPA rear shock/Laser aligned/15" Widow PPA wheels/Podium 1.5 front shocks
    Performance: DynoJet PV3 (custom mapped by Fuel Moto)/modded intake/Pedal Commander/EBC HH brake pads/TBR exhaust
    Convenience: Shad detachable luggage/Garmin Zumo XT GPS-Touratech lock/Lamonster Packrack-80L top case/JBL speakers
    Safety/Protection: H4 LED headlights/TricLED driving lights/TricLED run-brake-turn rear light/Frunk lip LED light strip/Spyder Extras bumper guard grill/ Chopped rear fender/FOBO 2 TPMS/TricLED sequential front signals & run/turn fog covers/Motohorn
    2019 F3-S , Monolith black
    Jun 2021
    Chicago il
    I really do not know about that, as would all motorcycles have it? The clamps alone have a lot of force and I strongly doubt that is the reason for it.
    More like its there so you are limited in the options of installing aftermarket bars.
    It also would save a lot of disassembly time to get at the lower bar to elongate the hole in the bar which also may weaken it somehow.
    Im going to run this by helibars and see what they think.
    Sep 2020
    Middletown, NJ
    As already stated, the pin helps in centering the bar. slightly elongating the hole in the bar will not weaken it. The clamp is full length and provides more than enough stiffness.
    '20 Spyder RT: Bajaron swaybar. Q5 tires, Pedal Commander, PV3, Elka front shocks, GPS/USB/12V handlebar mount, Heli-Bars, XM, Radar Detector, KOTT grills & vents, Shad top case, chin & DRL LEDs.
    2020 RT base , Chalk White
    Jun 2021
    Chicago il
    As I thought the pin is useless for safety , never heard of such a thing.
    This is helibars response!
    Here is the response from our engineering team:
    "Most people want the bars closer so that’s why we favor that range. Tapping the factory dowel pin, in the lower handlebar clamp, down will allow you to rotate the bars farther forward. Just make sure the handlebar clamp screws remain torqued."
    Please contact us if you have any questions or need any additional information.
    Escorial, sometimes people do not tighten their bars to the correct torque, meaning the bars can rotate forward and back if sudden pressure is applied. The nub/slot stop them rotating very far. That’s what Troop meant by “safety feature”. The nub also ensures the bars are aligned dead centre.
    p.s. it’s never a good idea to scoff at those who are trying to help you …. They may not bother in future
    Jun 2021
    Chicago il
    Its extremely rare that it's done if or if so probably by a novice.
    After all with all the makes of bikes on the road for the past xx years I never heard of a pin.
    When in doubt leave it for a qualified dealer.
    Just a after thought if the pin can be tapped down it may be able to be pulled out and reused if needed.
    Oct 2021
    Wichita, KS
    The risers manufactured and sold by BRP do away with the pin completely.
    2022 Petrol Metallic RT Limited 'PYDER'
    There's no place like G28 X0 Y0 Z0
    Jun 2021
    Chicago il
    Great to know, so it's pretty useless otherwise to confuse me :-)
    Would you have the install instructions ? I ask because would like to know if they suggest pulling the dowl pin out or just tapping it down?
    Oct 2021
    Wichita, KS
    Would you have the install instructions ? I ask because would like to know if they suggest pulling the dowl pin out or just tapping it?
    I haven't installed mine because I don't even have my Spyder yet. I bought my risers used off of this site, so no instructions. I watched a video or read some instructions or both. In any case the area where that pin would locate the bars is open space in the casting. Top and bottom. The pin is completely gone because the factory casting that has the pin is removed from the bike. I would say the lack of the pin is no big deal obviously since that is how BRP designed the factory risers.
    Dec 2021
    GA
    I have a 2022 RTL. I tried to install the Helibars, everything was easy enough, but I could not get the required length on the cables and had to put the original bars back on. I did remove the bracket at the bar clamp.
    Mar 2013
    Maumelle, AR
    Quote Originally Posted by Bcleland2 View Post
    The cables are zip tied and you have to cut the tie to be able to pull out enough cable. Once the handlebars are off, look closely and you'll see the zip ties about an inch below where it goes under. Snip it and there's plenty to pull out.
    2016 F3 Limited , Pearl White
    When you say the “bracket at the bar clamp”, is that the wire loom made out of what looks like metal coat hanger wire where the cables emerge under the dash, Bcleland2? Like Copperman, I also clipped the ties and it all works perfectly.
    Dec 2021
    GA
    Yes that is the "bracket at the bar clamp" I am referring to. Thank you and Copperman for your response.
    I will give that a try.
Tags for this Thread
