Results 1 to 14 of 14
    Active Member gerald37's Avatar
    Jul 2017
    Woodbine, Iowa
    Default Head Lights - Are these a standard automotive bulb?
    I have a 2019 Spyder RT. I just had a head light bulb burn out. Are these a standard automotive bulb? I know how to get get the bulbs out I just would like to have a replacement before I tear it apart. Where can I purchase a bulb?
    2019 RT Limited
    Asphalt Grey
    Lamonster RT Spyder Cuff For Phone
    Sena SMH-10
    Doran Tire Monitoring System
    Magic Mirrors
    Set of Centramatic Balancers From Lamonster Garage Bump Skid Plate Lamonster Belt Tensioner w/ larger roller Driver Hiway Pegs
    Northern Kalifornia
    Any automotive parts or supply store.
    Jul 2014
    Mint Hill, NC
    You would be well served to replace both of them at the same time. Once one goes the clock is ticking fast on the second one.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Northern Kalifornia
    Been there done that. Sometimes I think BURP designed and built their spyder around a headlight bulb.
    Feb 2019
    Portland, Oregon
    If you don't already have LED headlight bulbs, now is a good time to put that in. You have to remove panels anyway.
    ...yours now are Halogens .... if you stick with them they have versions of your size designated as Motorcycle .... they are more shock resistant .... you could also think Sylvania Super Brites .... good lucl ... Mike
    Jul 2014
    Mint Hill, NC
    Another +1 for LED headlights.
    Cognac 2014 RT-S
    Oct 2020
    Arizona
    Another vote +2, I put in Tricled 360 LEDs which are much brighter!
    https://tricledusa.com/collections/s...anbus-approved
    2018 RT Limited Chrome - Champagne Metallic - East Valley of Phoenix
    Magic Mirrors, 360 LED head lights, dual USB with volt meter, GPS, phone and drink holders, Front tires = Formoza's, General out back, BajaRon sway bar & Adjuster, dash cam, foam grips, 2 sizes of windshields, Ikea sheep skin, HW pegs, third brake light 4 LED strobe for 7 seconds and then on steady, rear LED turn signals/8 ohm 50W resistors and driver back rest.
    Sep 2017
    Wa.
    I went an looked at the tric led led light bulbs. Those are pricey bulbs with only a 1 yr warranty - that I could find. I try not to ride at night. When it comes time to replace my headlight bulbs I'l stick to Halogen bulbs, for motorcycles. Worked good in the motorcycles I had, should work good in my Spyder. JMO
    Oct 2020
    Arizona
    Night time riding is not the complete picture. LEDs make you much more visible during day light hours.
    Feb 2019
    Portland, Oregon
    Something like 77% of bike/car crashes are caused by cages turning left in the bike's path. I want as much attention getting light on the front of my Spyder as I can get. There are 8 LEDs; 2 fender/marker lights, 2 headlights (Slingmods Tricled), 2 fog/DRL lights (also Slingmods), and 2 "can you see me now 3,000 lumen road lights mounted on the insides of the front fenders. Decades of adding extra (and bright) lights on the front of bikes has avoided me getting hit a few times. Don't trust to luck Gerald, it's a jungle out there and you want to survive it. BTW, I do very little to none night riding too.
    Member Gekko's Avatar
    May 2019
    Huntington Beach, California, USA
    Quote Originally Posted by gerald37 View Post
    From page 157 of the Operator's Guide for the 2019 Spyder RT:
    Gekko (Larry)
    2019 Spyder RT SE6
    Jul 2017
    Woodbine, Iowa
    Thanks for everybody's come back.i just went to an auto parts store and replaced it with the original bulb. I do very little night riding.
    2019 RT Limited
    Asphalt Grey
    Sena SMH-10
    Magic Mirrors
    Active Member Fat Baxter's Avatar
    Sep 2014
    Central Alabama
    A few years back, I installed LED bulbs (from a company recommended here). Six rides later, one of the bulbs died. So I reinstalled the original bulbs. I'd had similar lousy results with various aftermarket bulbs with my BMW RT, so I figured the headlight gods were tapping me on the shoulder to remind me of their presence.
